Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Is it possible to create image & text button
Is it possible to create image & text button [message #370565] Tue, 03 June 2003 11:16 Go to next message
Originally posted by: mobiko.lycos.com
I know we can create image button using the setImage(). My question is can
we also create an "image+text" button in ToolBar? There is an API
setText() in the Button class, but somehow, it doesn't work. Here's
snippet of my code.
item = new ToolItem(toolBar, SWT.FLAT);
item.setImage(ImageCache.stockImages[Constants.UNDERLINEIMAG E]);
item.setToolTipText(Resource.getI18NString("app.toolbar.tooltips.underline ",
null));
Thanks in advance.
cheers,
mobiko
Re: Is it possible to create image & text button [message #370593 is a reply to message #370565] Tue, 03 June 2003 23:13 Go to previous messageGo to next message
Have you pasted the correct code?
Looking at your code, you're not calling the setText() method on the
ToolItem.
You call setToolTipText(), which defines what pops up on a mouseover (a
tooltip). Calling setText() instead would define the text to display
(depending on the ToolBar's style) beside/under the image in the ToolItem .
Nick Maynard
ncm99@doc.ic.ac.uk
"mobiko" <mobiko@lycos.com> wrote in message
news:bbie40$qju$1@rogue.oti.com...
> snippet of my code.
> null));
> Thanks in advance.
> cheers,
> mobiko
Re: Is it possible to create image & text button [message #370617 is a reply to message #370593] Wed, 04 June 2003 11:12 Go to previous messageGo to next message
Sorrie... see this code snippet. IT seems that when I set the layout for
Tool Bar using Grid Layout, the numColumns fields does not really
necessary mean NO. of COLUMNS, but it actually means no. of PIXELs.
I can't seem to align my buttons correctly, in particular the Preview
Button occupies quite a large space, it's width is equal to the width of
the widest button (e.g. Upload - a button with image and text). This is
despite me already setting "makeColumnsEqualWidth" to false. What is wrong
with my code?
Does ToolBar needs to define its layout first before we start to populate
the tool items?
Many thanks!
Code Snippet
toolBar = new ToolBar(shell, SWT.FLAT | SWT.RIGHT);
GridLayout layout = new GridLayout();
layout.numColumns = 400;
layout.marginHeight = 1;
layout.marginWidth = 1;
layout.horizontalSpacing = 1;
layout.makeColumnsEqualWidth = false;
toolBar.setLayout(layout);
item = new ToolItem(toolBar, SWT.NONE);
item.setText("Blogs");
// Create Combo Box - Populate with Blogs IDs
item = new ToolItem(toolBar, SWT.SEPARATOR);
Combo combo = new Combo(toolBar, SWT.READ_ONLY);
combo.setBackground(Constants.WHITE);
combo.setLayoutData(new GridData());
item.setWidth(100);
item.setControl(combo);
// Upload Button
item = new ToolItem(toolBar, SWT.FLAT | SWT.PUSH);
item.setImage(ImageCache.stockImages[Constants.UPLOADIMAGE]) ;
item.setToolTipText(Resource.getI18NString("app.toolbar.tooltips.upload ",
null));
item.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
// TODO: Upload
item.setText("Upload");
// Preview Button
item.setImage(ImageCache.stockImages[Constants.PREVIEWIMAGE] );
item.setToolTipText(Resource.getI18NString("app.toolbar.tooltips.preview ",
null));
// TODO: Preview
// Post Button
item.setImage(ImageCache.stockImages[Constants.POSTIMAGE]);
item.setToolTipText(Resource.getI18NString("app.toolbar.tooltips.post ",
null));
// TODO: POST
item.setText("Post");
// Pack Tool Bar
toolBar.pack();
> ToolItem.
Re: Is it possible to create image & text button [message #370672 is a reply to message #370617] Thu, 05 June 2003 13:30 Go to previous messageGo to next message
Others please feel free to step in and correct any mistakes...
Unfortunately it seems (according to others on the newsgroup, and my own
experiments) that ToolItems that belong to a ToolBar will always take their
image width to be that of the image of the first ToolItem. The same with
text, unfortunately.
All this means is that you can't have a mix of image- and text-based
ToolItems on a ToolBar, as they'll look stupid.
Personally I think this is silly, but that's how it goes.
Also, I don't think you want to be using a Layout for your toolbar... here's
a little snippet of what I do...
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.ToolBar;
import org.eclipse.swt.widgets.ToolItem;
* @author Nick
public class Test {
Display display = new Display();
// Create the main window (Shell)
Shell shell = new Shell(display);
shell.setText("Cows Rule");
shell.setSize(640, 480);
// Create a very basic layout to contain our canvas for now
layout.numColumns = 2;
shell.setLayout(layout);
// Funky toolbar
GridData toolbarData = new GridData(GridData.FILL_HORIZONTAL);
toolbarData.horizontalSpan = 2;
ToolBar toolBar = new ToolBar(shell, SWT.FLAT);
ToolItem toolItem;
toolItem = new ToolItem(toolBar, SWT.PUSH);
toolItem.setText("Cows");
toolItem.setText("Rule");
toolBar.pack();
// Open our window
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
As you can see, we have a GridLayout for the Shell, then we pop a ToolBar
into a new GridData, where we set the correct number of column spans (in
this case 2).
Hope this helps a little,
Nick
news:bbl29k$4v1$1@rogue.oti.com...
> with my code?
> the tool items?
> Many thanks!
> Code Snippet
> item.setWidth(100);
> // Upload Button
> null));
> // TODO: Upload
> // Preview Button
> null));
> // TODO: Preview
> // Post Button
> null));
> // TODO: POST
> // Pack Tool Bar
> toolBar.pack();
> > ToolItem.
ToolItem .
Re: Is it possible to create image & text button [message #370691 is a reply to message #370672] Fri, 06 June 2003 07:38 Go to previous messageGo to next message
This must be a bug then. Why can\'t Toolbar use GridLayout when there is
an API provided in the class to set Layout.
Your test reveals some interesting findings.
I tried using GridLayout for my toolbar, thinking that I can then do a
\"setLayoutData\" on the components to adjust the width/height.
> All this means is that you can\'t have a mix of image- and text-based
> ToolItems on a ToolBar, as they\'ll look stupid.
> Personally I think this is silly, but that\'s how it goes.
> Also, I don\'t think you want to be using a Layout for your toolbar...
here\'s
Re: Is it possible to create image & text button [message #370748 is a reply to message #370691] Mon, 09 June 2003 09:16 Go to previous messageGo to next message
I found my solution in CLabel. Yes, you can set Text + Image button in
ToolBar... see this code snippet.
CLabel label = new CLabel(toolBar, SWT.SHADOW_NONE);
label.setText(Resource.getI18NString("app.toolbar.blog", null));
label.setImage(ImageCache.stockImages[Constants.BLOGIMAGE]);
label.setAlignment(SWT.CENTER);
item.setControl(label);
item.setWidth(80);
> here\'s
Re: Is it possible to create image & text button [message #370758 is a reply to message #370748] Mon, 09 June 2003 11:38 Go to previous message
I'm glad you managed to solve your problem!
news:bc21bc$8gq$1@rogue.oti.com...
> item.setWidth(80);
own
their
with
> > here\'s
Previous Topic:Irregular shaped windows with SWT
Next Topic:Eclipse 3 M1, button with text and image still no improvement~
Current Time: Sun Sep 21 18:48:53 EDT 2025
Powered by FUDForum. Page generated in 0.03861 seconds
