| Export Data - Available Columns [message #368864] |
Wed, 01 July 2009 10:32  |
I understand that the columns shown in the export list are all the columns
listed under the binding tab.
I do not want the aggregation bindings to show up in the export.
So I use the following code as a work around:
Modifed the BirtSimpleExportDataDialog.js file in the ajax directory of
the viewer.in the __bind method I modified and added an if statement.
for ( var k = 0; k < resultSets.length; k++ )
var resultSet = resultSets[k];
var queryNames = resultSet.getElementsByTagName( 'QueryName' );
oSelects[0].options.add( new Option( queryNames[0].firstChild.data ) );
this.availableResultSets[k] = {};
var columns = resultSet.getElementsByTagName( 'Column' );
for( var i = 0; i < columns.length; i++ )
var column = columns[i];
var columnName = column.getElementsByTagName( 'Name' );
var label = column.getElementsByTagName( 'Label' );
if (columnName != 'ORDERDATE')
this.availableResultSets[k][label[0].firstChild.data] =
columnName[0].firstChild.data;
After saving the above code. I run the report in birt viewer and use the
export data options. The column ORDERDATE still exists and shows up in the
export document.
Am I doing something incorrect?
| Re: Export Data - Available Columns [message #676050 is a reply to message #675952] |
Thu, 02 June 2011 10:49  |
That is the right file. look at the __bind function. For example I
could modify it to leave out columns name CUSTOMERTOTAL like:
if( columnName[0].firstChild.data != "CUSTOMERTOTAL" ){
Jason
On 6/2/2011 2:26 AM, pratim wrote:
> Hi Jason,
> Even i have a requirement, where i don't want to show a column item in
> the export data dialogue box.
> I tried the above steps, but that does not help.
> Then, i try by removing the "BirtSimpleExportDataDialog.js" file itself,
> and building my application using tomcat server. But still, export data
> dialogue box shows up all the column item.
> So, my question is does this file handle which column item to show up or
> not !! Or, there is some other files which handle this?
FUDForum. Page generated in 0.03774 seconds
