Home » Archived » BIRT » "dataSetRow" is not defined
"dataSetRow" is not defined [message #368633] Tue, 16 June 2009 12:00 Go to next message
Originally posted by: hoe.zurich.ibm.com
I'm running into the following error (with BIRT 2.3.0 engine). Who knows
how to resolve this? (BTW, I'm using a report design that has an EMF
Data Source/Set with a Row Mapping, and a Column Mapping "name" defined).
Many thanks,
Christian
-- SNIP
org.eclipse.birt.report.engine.api.EngineException: There are errors
evaluating script "dataSetRow["name"]": ReferenceError: "dataSetRow" is
not defined. (<inline>#1)
org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1121)
org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1085)
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:88)
org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34)
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:64)
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:157)
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:70)
-- SNIP
Re: "dataSetRow" is not defined [message #368635 is a reply to message #368633] Tue, 16 June 2009 12:45 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Christian,
Are you by chance using openJDK?
Jason
> Many thanks,
> Christian
> -- SNIP
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> -- SNIP
Re: "dataSetRow" is not defined [message #368641 is a reply to message #368635] Wed, 17 June 2009 02:27 Go to previous messageGo to next message
Jason,
Nops, I'm using IBM's J9 VM (1.6.0) in this instance. Do you have an
idea what could be amiss?
Christian
Jason Weathersby wrote:
> Christian,
> Jason
>> knows how to resolve this? (BTW, I'm using a report design that has an
>> EMF Data Source/Set with a Row Mapping, and a Column Mapping "name"
>> defined).
>> Many thanks,
>> Christian
>> -- SNIP
>> is not defined. (<inline>#1)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> -- SNIP
Re: "dataSetRow" is not defined [message #368646 is a reply to message #368641] Wed, 17 June 2009 09:48 Go to previous messageGo to next message
Christian,
I have seen a similar error when the system has conflicting versions of
Rhino.jar. Does the simple test report work in your environment? How
are you deploying it?
Jason
> Jason,
> Christian
>> Christian,
>> Jason
>>> an EMF Data Source/Set with a Row Mapping, and a Column Mapping
>>> "name" defined).
>>> Many thanks,
>>> Christian
>>> -- SNIP
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> -- SNIP
Re: "dataSetRow" is not defined [message #368899 is a reply to message #368646] Fri, 03 July 2009 11:53 Go to previous messageGo to next message
Jason and Dear All,
I was busy with other things, but have now returned to this problem.
If I do a simple report with an EMF data source that's based on the
example library model (from org.eclipse.emf.examples.library) this works
fine.
I now suspect that the problem here might have to do with one of these
two causes:
(1) My meta-model, since its application-specific, does not reside in
an Eclipse plug-in (such as org.eclipse.emf.examples.library), but in a
plug-in project in the Eclipse workspace. There it defines extensions
org.eclipse.emf.ecore.generated_package as usual for EMF models, but
perhaps BIRT does not pick up these package registrations.
I've tried report generation also in a PDE environment (i.e. after Run
As / Eclipse Application), but that does not seem to make a difference.
(2) My model is currently split across two XMI files, again using
normal EMF conventions. I specify both as instance models in the EMF
data source.
I've tried to combine them into one, but that does not seem to make a
difference either.
Does (1) or (2) ring any further bells?
Christian
>>>> "name" defined).
>>>> -- SNIP
>>>> at
Re: "dataSetRow" is not defined [message #368904 is a reply to message #368899] Mon, 06 July 2009 03:44 Go to previous messageGo to next message
I think I've been able to resolve this now. Here's for future reference
what seems to be the case:
(1) Just placing the EMF model in an appropriate Eclipse project in the
workspace is not enough. In order for the models to become visible to
BIRT, the model registrations in the project's plugin.xml (extension
point org.eclipse.emf.ecore.generated_package) have to be activated.
This can be done e.g. by starting and working inside a nested/PDE
version of Eclipse (Run As / Eclipse Application).
(2) The row query expressions for EMF data sources follow XPath syntax.
In the case of my example I had to switch from "NODE" to "//NODE".
(Somewhat expensive, but justified in my case, because NODEs can be
nested at arbitrary levels below the models's root object.)
Once this is done, e.g. Preview Results for the EMF Data Set works for
an EMF instance model (*.xmi) and metamodel (*.ecore).
Hope this helps others as well,
Christian
>>>>> "name" defined).
>>>>> -- SNIP
>>>>> errors evaluating script "dataSetRow["name"]": ReferenceError:
>>>>> "dataSetRow" is not defined. (<inline>#1)
>>>>> at
Re: "dataSetRow" is not defined [message #368913 is a reply to message #368904] Mon, 06 July 2009 10:50 Go to previous messageGo to next message
Christian,
Thanks for posting.
Jason
> reference what seems to be the case:
> the workspace is not enough. In order for the models to become visible
> to BIRT, the model registrations in the project's plugin.xml (extension
> syntax. In the case of my example I had to switch from "NODE" to
> "//NODE". (Somewhat expensive, but justified in my case, because NODEs
> can be nested at arbitrary levels below the models's root object.)
> for an EMF instance model (*.xmi) and metamodel (*.ecore).
> Christian
>>>>>> has an EMF Data Source/Set with a Row Mapping, and a Column
>>>>>> -- SNIP
>>>>>> at
Re: "dataSetRow" is not defined [message #1798595 is a reply to message #368913] Tue, 20 November 2018 14:02 Go to previous message
The answer is simple.
You have a redundant data_binding somewhere.
1. Look for the indicated ID in the error message then switch to XML_Source tab to find the element it's using.
2. Return back to the Layout and click Binding TAB under the Property Editor.
3. Remove redundant binding.
Previous Topic:Preview tab is missing
Next Topic:bottom border in table header
Current Time: Wed Oct 22 03:51:49 EDT 2025
Powered by FUDForum. Page generated in 0.13299 seconds
