Home » Archived » BIRT » Oraclethin.jar+Cripted DataSource
Oraclethin.jar+Cripted DataSource [message #368364] Tue, 26 May 2009 05:31 Go to next message
Hi!
We are using a scripted Datasource to connect over Oracle JDBC with Oracle
DB! With Birt-Version 2.2 everything works OK (copy oraclethin.jar into
lib directory of birt-viewer) but now we are using BIRT 2.3/2.5!
I always got the error, "Class not found exception:
oracle.jdbc.driver.OraclDriver
when previewing in Eclipse.
I already tried to copy the jar-files into:
eclipse\plugins\org.eclipse.birt.report.viewer_2.3.2.r232_20 090212\birt\WEB-INF\lib
)eclipse\plugins\org.eclipse.birt.report.viewer_2.3.2.r232_2 0090212\birt\WEB-INF\classes
)eclipse\plugins\org.eclipse.birt.report.viewer_2.3.2.r232_2 0090212\birt\scriptlib
Problem still remains!!!
Is this a bug with BIRT Version 2.3/2.5?? Does anybody know, where to
place a *.jar file, so I can call it with JavaScript in a Scripted
Datasource??
My Sourcecode in initialize Method of the Report:
importPackage(xyz.report.script);
mxReportScriptContext = ReportScriptDS.getDesigntimeConnection();
Code in ReportScriptDS Class:
public static Connection getDesigntimeConnection() throws Exception {
String url = "jdbcracle:thin:@localhost:1521:instance";
String userName = "user";
String password = "pwd";
String schemaOwner = "pwd";
String driver = "oracle.jdbc.driver.OracleDriver";
Class.forName(driver);
Connection connection = DriverManager.getConnection(url, userName,
password);
return connection;
Thanks a lot for your help
Chris
Re: Oraclethin.jar+Cripted DataSource [message #368373 is a reply to message #368364] Tue, 26 May 2009 11:23 Go to previous messageGo to next message
Originally posted by: jasonweathersby.windstream.net
Chris,
This should be working if you put it in the scriptlib dir. Can you try
one of two other methods:
1 - Create a java project in the same workspace as your report project.
In this java project create your scripted data source code. Make sure
to add the thin driver to your classpath by configuring the build path.
Set an example report in the report project to point to the scripted
ds and preview.
2 - Add the jar to the report using add jar button on the reports
resources tab in the property editor. You will need to move it into the
resource folder to see it.
Also does your report work in the deployed webviewer.
Jason
vollerchris wrote:
> Hi!
> Oracle DB! With Birt-Version 2.2 everything works OK (copy
> oraclethin.jar into lib directory of birt-viewer) but now we are using
> BIRT 2.3/2.5!
> Datasource??
> password);
> return connection;
> Chris
Re: Oraclethin.jar+Cripted DataSource [message #368386 is a reply to message #368373] Wed, 27 May 2009 08:05 Go to previous messageGo to next message
Hi Jason!
Thanks a lot for your help!!!!
Part 1 is working with preview, however not with the javascript debugger
(already tried to add classpath in the report debugger view) :-)
But main problem is solved!
thanks
chris
Re: Oraclethin.jar+Cripted DataSource [message #368393 is a reply to message #368386] Wed, 27 May 2009 12:49 Go to previous message
Chris,
To get the debugger to work look at the classpath tab in the debug
configuration and add the project that contains the scripted ds.
Jason
vollerchris wrote:
> Hi Jason!
> thanks
> chris
Previous Topic:desired output format: CSV
Next Topic:Operations between DataSets
Current Time: Sat Nov 08 23:11:39 EST 2025
Powered by FUDForum. Page generated in 0.04978 seconds
