Home » Archived » BIRT » MySQL Longtext datatype
MySQL Longtext datatype [message #368256] Thu, 14 May 2009 12:26 Go to next message
I have added a longtext field to my MySQL database and I am trying to
use this field in two reports. First I have added this field to the view
I use.
In the first report (showing all the rows in the database), the field is
displayed normal.
The second report should display only single rows from the database
(filtered with a report paramater).
The simple action of adding the longtext-field to the query in the
dataset, results in the following message:
org.eclipse.birt.report.exception.ViewerValidationException: The
parameter "RP_Applicatie" cannot be blank.
The stacktrace is:
at org.eclipse.birt.report.utility.DataUtil.validate(DataUtil.j ava:175)
org.eclipse.birt.report.utility.BirtUtility.handleOperation( BirtUtility.java:560)
org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(BirtRunReportActionHandler.java:77)
org.eclipse.birt.report.service.actionhandler.BirtGetPageAct ionHandler.__checkDocumentExists(BirtGetPageActionHandler.ja va:58)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.prepareParameters(AbstractGetPageActionHandle r.java:119)
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(AbstractGetPageActionHandler.java:1 04)
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(BirtDocumentProcessor.java:87)
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 )
org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:616)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
The parameter-section in the XML-file is as follows:
<scalar-parameter name="RP_Applicatie" id="959">
<property name="valueType">dynamic</property>
<property name="dataType">decimal</property>
<property name="paramType">simple</property>
<property name="concealValue">false</property>
<property name="isRequired">false</property>
<property name="controlType">list-box</property>
<property name="dataSetName">UR applicaties</property>
<expression name="valueExpr">dataSetRow["apl_id"]</expression>
<expression
name="labelExpr">dataSetRow["applicatie"]</expression>
<property name="mustMatch">true</property>
<property name="fixedOrder">true</property>
<property name="distinct">true</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
Removing the just added field from the query makes no difference
How can I use a longtext field in a report that is filtered with a
report parameter?
Ben
Re: MySQL Longtext datatype [message #368268 is a reply to message #368256] Fri, 15 May 2009 10:07 Go to previous messageGo to next message
Ben,
Are you only having problems with the second report?
Can you post the entire report?
If you are passing in the value why are you setting the value to a
dataset value
dataSetRow["apl_id"].
Jason
> I use.
> displayed normal.
> The stacktrace is:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <expression
> </structure>
> </scalar-parameter>
> report parameter?
> Ben
Re: MySQL Longtext datatype [message #368274 is a reply to message #368268] Fri, 15 May 2009 20:21 Go to previous messageGo to next message
Jason Weathersby schreef:
> Ben,
> dataset value
> Jason
Yes.
The two reports are nearly identical. The only difference is that the
first one shows all the tupples whereas the second only displays one tupple.
The value that is needed to select the tupple comes from a list of
values The method I use is identical to the one that is explained in the
Birt-tutorial.
The complete report is nearly 4000 lines. Should I really post all those
lines or are there lines you don't need?
Ben
Re: MySQL Longtext datatype [message #368279 is a reply to message #368274] Mon, 18 May 2009 11:09 Go to previous messageGo to next message
Ben,
You may have to open a bug for this. Dont paste the 4000 lines :>
Can you alter the second report to take a string parameter instead of
making it dynamic?
Jason
>> Ben,
>> dataset value
>> Jason
> Yes.
> tupple.
> Birt-tutorial.
> Ben
Re: MySQL Longtext datatype [message #368288 is a reply to message #368279] Mon, 18 May 2009 12:34 Go to previous messageGo to next message
I am quite willing to help you but any help about how to do that would
be kindly appreciated :-)
Ben
(I have no further knowledge of BIRT then the tutorial - but I am
thinking of buying the book :-)
> Ben,
> making it dynamic?
> Jason
>>> Ben,
>>> dataset value
>>> Jason
>> Yes.
>> tupple.
>> the Birt-tutorial.
>> those lines or are there lines you don't need?
>> Ben
Re: MySQL Longtext datatype [message #368289 is a reply to message #368288] Mon, 18 May 2009 12:38 Go to previous messageGo to next message
Ben,
Thanks a lot. Take a look at the bugzilla entry under:
http://www.eclipse.org/birt/phoenix/community.php
Jason
> Ben
>> Ben,
>> making it dynamic?
>> Jason
>>>> Ben,
>>>> dataset value
>>>> Jason
>>> Yes.
>>> tupple.
>>> the Birt-tutorial.
>>> Ben
Re: MySQL Longtext datatype [message #368306 is a reply to message #368289] Tue, 19 May 2009 17:25 Go to previous messageGo to next message
Jason,
I have used bugzilla before but what I meant was how to take the string
parameter instead of using dynamic :-)
Ben
> Ben,
> Jason
>> Ben
Re: MySQL Longtext datatype [message #368311 is a reply to message #368306] Wed, 20 May 2009 12:37 Go to previous messageGo to next message
Ben,
Sorry about that :>.
On the detail report (second one) just setup a string parameter and link
that to a dataset parameter to modify the query. Or use the beforeOpen
script of the dataset to modify the query.
Take a look at this:
http://www.eclipse.org/birt/phoenix/examples/reports/birt2.1 /drill/index.php
and
http://www.eclipse.org/birt/phoenix/examples/reports/birt2.1 /querymod/index.php
Jason
Ben Engbers wrote:
> Jason,
> Ben
>> Ben,
>> Jason
>>> would be kindly appreciated :-)
>>> Ben
Re: MySQL Longtext datatype [message #368379 is a reply to message #368311] Tue, 26 May 2009 17:50 Go to previous message
With Deltawalker I have compared a working version to a malfunctioning
version of the rptdesign.
What I did was:
first I made a working report that showed all the records.
Then I added a parametersection to this rptdesicgn that should select
just one record. No other changes were introduced.
Amongst many other changes in the rptdesign, I found the following
section which had been introduced:
<parameters>
<property name="isRequired">true</property>
<expression
</structure>
</scalar-parameter>
</parameters>
This report functioned fine.
After adding another field to the query I used, suddenly Birt showed the
following message:
Even after restoring the report to its original content, the error remained.
With deltawalker, I noticed that after removing the changes to the
query, the only difference between the 'good' and the 'bad' rptdesign
was that in the parameters-section the line <property
name="isRequired">true</property> had changed to <property
name="isRequired">false</property>.
After changing true to false, the report functioned again and I was even
able to insert the new fields from the query in the report.
I have tried now several times but it's just enough to change the
'isRequired' setting from false to true to recover from the error.
Ben
> Ben,
> and
> Jason
> Ben Engbers wrote:
>> Jason,
>> string parameter instead of using dynamic :-)
>> Ben
>>> Ben,
>>> Jason
>>>> Ben
Previous Topic:Format Number using a Style
Next Topic:desired output format: CSV
Current Time: Sat Nov 08 21:46:04 EST 2025
Powered by FUDForum. Page generated in 0.04939 seconds
