Home » Archived » BIRT » Print at bottom of page
Print at bottom of page [message #367893] Wed, 15 April 2009 16:01 Go to next message
BIRT 2.2.2
My report consists of two datasets. There main table element which is
bound to one dataset based on a scripted data source and another nested
table bound to another dataset. This report is an work order type report
with the main table having a Group on Order Number. And the nested table
contains Order Detials.
Each order on the main table has a Note. I have added the Note field on
the Order Number group footer section.
I want the notes to start printing at the bottom of the page for that each
order number group. So if I have multiple detailed items for the order
spanning more than a page, then the notes for that order should start
printing at the bottom of page 2. The notes can grow from 1 line to n
lines.
Note: that the notes field comes from the main dataset.
Please advice how can I get this to work, I did not fine a solution for
this issue anywhere.
Thank you.
Re: Print at bottom of page [message #367911 is a reply to message #367893] Thu, 16 April 2009 12:05 Go to previous messageGo to next message
I am not certain this is what you want, but the attached report puts
comments(if they exist in the group footer). I set the page break
interval for the inner table to 5 to illustrate that the footer only
shows when all the rows are processed.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.2.r232_20090202 Build &lt;2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<property name="displayName">ORDERDATE</property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<property name="displayName">REQUIREDDATE</property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<property name="displayName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<property name="displayName">STATUS</property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<property name="displayName">COMMENTS</property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<property name="displayName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">STATUS</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
<property name="queryText">select *
from orders</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set1" id="9">
<structure>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="nativeName"></property>
<expression name="defaultValue">10101</expression>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
from orderdetails
where ordernumber = ?</property>
<model:DesignValues
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
<style name="table-header" id="56">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
<property name="fontSize">small</property>
<property name="fontWeight">bold</property>
<property name="color">#FFFFFF</property>
<property name="paddingTop">0px</property>
<property name="paddingLeft">0px</property>
<property name="paddingBottom">0px</property>
<property name="paddingRight">0px</property>
</style>
<style name="table-footer" id="57">
</style>
<style name="table-detail" id="58">
<property name="backgroundColor">#E6ECFF</property>
<property name="fontSize">x-small</property>
<property name="color">#000080</property>
</style>
<style name="table-group-header-1" id="59">
<property name="backgroundColor">#809FFF</property>
</style>
<style name="table-group-footer-1" id="60">
</style>
<style name="special-header" id="61">
<property name="fontSize">medium</property>
</style>
<style name="crosstab-detail" id="62">
</style>
<style name="crosstab-header" id="63">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["STATUS"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["COMMENTS"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
</list-property>
<column id="49"/>
<column id="50"/>
<column id="88"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">ORDERDATE</text-property>
</label>
</cell>
<cell id="83"/>
</row>
</header>
<group id="64">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr">row["ORDERNUMBER"]</expression>
<structure name="toc">
<expression
name="expressionValue">row["ORDERNUMBER"]</expression>
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">always</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="65">
<cell id="66">
<data id="81">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="67"/>
<cell id="84"/>
</row>
</header>
<footer>
<row id="73">
<cell id="74">
<label id="123">
<text-property
name="text">Comments:</text-property>
</label>
</cell>
<cell id="75">
<data id="82">
<property
name="resultSetColumn">COMMENTS</property>
</data>
</cell>
<cell id="86"/>
</row>
</footer>
</group>
<detail>
<row id="26">
<cell id="27">
<data id="28">
<property
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">ORDERDATE</property>
</data>
</cell>
<cell id="85">
<table id="89">
<property name="dataSet">Data Set1</property>
<list-property name="paramBindings">
<structure>
<property
name="paramName">param_1</property>
<expression
name="expression">row["ORDERNUMBER"]</expression>
</structure>
</list-property>
<structure>
<property
<property
<expression
<property
</structure>
<structure>
<property
<property
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
<property
</structure>
<structure>
<property
<property
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
<property
</structure>
<structure>
<property
<property
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
<property
</structure>
<structure>
<property
<property
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
<property
</structure>
</list-property>
<property name="pageBreakInterval">5</property>
<column id="118"/>
<column id="119"/>
<column id="120"/>
<column id="121"/>
<column id="122"/>
<header>
<row id="90">
<cell id="91">
<label id="92">
<text-property
</label>
</cell>
<cell id="93">
<label id="94">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="95">
<label id="96">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="97">
<label id="98">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="99">
<label id="100">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="101">
<cell id="102">
<data id="103">
<property
</data>
</cell>
<cell id="104">
<data id="105">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="106">
<data id="107">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="108">
<data id="109">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="110">
<data id="111">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="112">
<cell id="113"/>
<cell id="114"/>
<cell id="115"/>
Re: Print at bottom of page [message #367913 is a reply to message #367911] Thu, 16 April 2009 12:10 Go to previous messageGo to next message
If you want to push the group footer further down the page set the
height for the row like:
id="1">
<data-sources>
<oda-data-source
id="7">
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
<oda-data-set
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
<model:DesignValues
<design:attributes>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="10">
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
</list-property>
<column id="49"/>
<column id="50"/>
<column id="88"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
</label>
</cell>
<cell id="83"/>
</row>
</header>
<group id="64">
<expression
</structure>
<header>
<row id="65">
<cell id="66">
<data id="81">
<property
</data>
</cell>
<cell id="67"/>
<cell id="84"/>
</row>
</header>
<footer>
<row id="73">
<cell id="74">
<label id="123">
<text-property
</label>
</cell>
<cell id="75">
<data id="82">
<property
</data>
</cell>
<cell id="86"/>
</row>
</footer>
</group>
<detail>
<row id="26">
<property name="height">9in</property>
<cell id="27">
<data id="28">
<property
</data>
</cell>
<cell id="29">
<data id="30">
<property
</data>
</cell>
<cell id="85">
<table id="89">
<structure>
<property
<expression
</structure>
</list-property>
<structure>
<property
<property
<expression
<property
</structure>
<structure>
<property
<property
<expression
<property
</structure>
<structure>
<property
<property
<expression
<property
</structure>
<structure>
<property
<property
<expression
<property
</structure>
<structure>
<property
<property
<expression
<property
</structure>
</list-property>
<column id="118"/>
<column id="119"/>
<column id="120"/>
<column id="121"/>
<column id="122"/>
<header>
<row id="90">
<cell id="91">
<label id="92">
<text-property
</label>
</cell>
<cell id="93">
<label id="94">
<text-property
</label>
</cell>
<cell id="95">
<label id="96">
<text-property
</label>
</cell>
<cell id="97">
<label id="98">
<text-property
</label>
</cell>
<cell id="99">
<label id="100">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="101">
<cell id="102">
<data id="103">
<property
</data>
</cell>
<cell id="104">
<data id="105">
<property
</data>
</cell>
<cell id="106">
<data id="107">
<property
</data>
</cell>
<cell id="108">
<data id="109">
<property
</data>
</cell>
<cell id="110">
<data id="111">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="112">
<cell id="113"/>
<cell id="114"/>
<cell id="115"/>
<cell id="116"/>
Re: Print at bottom of page [message #367967 is a reply to message #367913] Thu, 23 April 2009 10:53 Go to previous messageGo to next message
Thanks for the example but I am using Eclipse BIRT Designer Version 2.2.2
and version="3.2.15", I changed the version on your example and I can see
the layout but I cannot see any of the properties for the objects.
Note that my report is based on a Scripted Data Source and this is the
dynamic text field I have used on the master page footer:
row["clob_ORDERNUMFOOTER"] with no binding that that element on the master
page. This works fine except for two issues: 1. The notes do not print on
the first Order 2. If the Order spans two pages the notes are being
printed on both the pages. I want it to print only on the last page for
that order.
Please advice.
Re: Print at bottom of page [message #367992 is a reply to message #367967] Mon, 27 April 2009 00:21 Go to previous messageGo to next message
Instead of using the masterpage footer, which is created before the
actual data is placed on it, can you set the detail row for the outer
table to be say 10 inches and use the outer table group footer as the
page footer?
Jason
> 2.2.2 and version="3.2.15", I changed the version on your example and I
> can see the layout but I cannot see any of the properties for the objects.
> master page. This works fine except for two issues: 1. The notes do not
> print on the first Order 2. If the Order spans two pages the notes are
> being printed on both the pages. I want it to print only on the last
> page for that order.
> Please advice.
Re: Print at bottom of page [message #368026 is a reply to message #367992] Tue, 28 April 2009 09:48 Go to previous messageGo to next message
Yes I tried what you suggested. I did set the details section height to 10
in. and added the notes to the outer group footer section, which is the
group on ordernum. But with this there are two issues:
1. The report shows the notes at the bottom if the page as expected in
only the HTML view and not on PDF.
2. What if I have too many items in the details section of the order that
span more than 10 in., will the details then get cut off?
Please advice.
Re: Print at bottom of page [message #368045 is a reply to message #368026] Tue, 28 April 2009 14:51 Go to previous messageGo to next message
Can you change the height to 8 inches just to check pdf again?
If the footer is to long it will add another page just for the extended
footer information.
Jason
> 10 in. and added the notes to the outer group footer section, which is
> the group on ordernum. But with this there are two issues:
> only the HTML view and not on PDF. 2. What if I have too many items in
> the details section of the order that span more than 10 in., will the
> Please advice.
Re: Print at bottom of page [message #368046 is a reply to message #368045] Tue, 28 April 2009 16:19 Go to previous messageGo to next message
Once I change the details section height to 8 in, the data in the detail
section does not show at all on the pdf, but it does on the html page.
(note: using birt 2.2.2)
Re: Print at bottom of page [message #368059 is a reply to message #368046] Wed, 29 April 2009 10:23 Go to previous messageGo to next message
There may be another approach but it would depend on how you are running
BIRT. Are you using the viewer or the api? If you are using the viewer
do you use the frameset mapping? If you are using the api are you using
a runtask and then a rendertask or the runandrendertask.
Jason
Re: Print at bottom of page [message #368071 is a reply to message #368059] Wed, 29 April 2009 15:40 Go to previous messageGo to next message
Jason,
If I understand your question, yes, we are using the frameset.
Ex:
http://localhost:8080/birt-viewer/frameset?__report=reports/ TestReport.rptdesign
Re: Print at bottom of page [message #368074 is a reply to message #368071] Wed, 29 April 2009 16:52 Go to previous messageGo to next message
James,
So then the user exports the report to pdf?
The reason I ask this is if report generation is broken into two phases
like the frameset mapping does, then the onreder event for elements in
the footer can be overridden to supply a variable that is populated
during the first phase(generation).
Jason
James Koch wrote:
> Jason,
> Ex:
Re: Print at bottom of page [message #368082 is a reply to message #368074] Thu, 30 April 2009 10:32 Go to previous messageGo to next message
Yes, the user then exports the report to pdf.
Re: Print at bottom of page [message #368083 is a reply to message #368082] Thu, 30 April 2009 11:51 Go to previous messageGo to next message
Take a look at this report. I put the comments in the group footer and
using the visibility I hide the row. I put an oncreate event on the
comments field to write them to a persistent global variable that I then
use in the page footer's text element to read in the onrender event.
Note this report will not work if a runandrender task is used, such as
when using the /run or /preview mappings.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.15"
id="1">
2.2.2.r222_v20071226 Build &lt;2.2.2.v20080227-1131></property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<data-sources>
<oda-data-source
id="6">
<text-property name="displayName"></text-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
name="Data Set" id="7">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="Data Set1" id="72">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
</property>
<model:DesignValues
<design:attributes>
<design:defaultScalarValue>10101</design:defaultScalarValue >
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
</style>
<style name="crosstab-cell" id="5">
</style>
<style name="table-header" id="54">
</style>
<style name="table-footer" id="55">
</style>
<style name="table-detail" id="56">
</style>
<style name="table-group-header-1" id="57">
</style>
<style name="table-group-footer-1" id="58">
</style>
<style name="special-header" id="59">
</style>
<style name="crosstab-detail" id="60">
</style>
<style name="crosstab-header" id="61">
</style>
</styles>
<page-setup>
<page-footer>
<text id="113">
<method name="onRender"><![CDATA[newpagestr =
reportContext.getPersistentGlobalVariable("pgstr"+pageNumber);
this.text = newpagestr;]]></method>
<property name="contentType">auto</property>
</text>
</page-footer>
</page-setup>
<body>
<table id="8">
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
<structure>
<expression
</structure>
</list-property>
<column id="47"/>
<column id="48"/>
<column id="78"/>
<header>
<row id="9">
<cell id="10">
<label id="11">
<text-property
</label>
</cell>
<cell id="12">
<label id="13">
<text-property
</label>
</cell>
<cell id="73"/>
</row>
</header>
<group id="62">
<expression
</structure>
<header>
<row id="63">
<cell id="64">
<data id="71">
<property
</data>
</cell>
<cell id="65"/>
<cell id="74"/>
</row>
</header>
<footer>
<row id="67">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression
name="valueExpr">true</expression>
</structure>
</list-property>
<cell id="68">
<data id="36">
<method name="onCreate"><![CDATA[var
currcomments = this.getRowData().getColumnValue("COMMENTS").toString();
reportContext.setPersistentGlobalVariable("pgstr"+pageNumber,
currcomments);]]></method>
<property
</data>
</cell>
<cell id="69"/>
<cell id="76"/>
</row>
</footer>
</group>
<detail>
<row id="24">
<cell id="25">
<data id="26">
<property
</data>
</cell>
<cell id="27">
<data id="28">
<property
</data>
</cell>
<cell id="75">
<table id="79">
<structure>
<property
<expression
</structure>
</list-property>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
<structure>
<property
<expression
<property
</structure>
</list-property>
<column id="108"/>
<column id="109"/>
<column id="110"/>
<column id="111"/>
<column id="112"/>
<header>
<row id="80">
<cell id="81">
<label id="82">
<text-property
</label>
</cell>
<cell id="83">
<label id="84">
<text-property
</label>
</cell>
<cell id="85">
<label id="86">
<text-property
</label>
</cell>
<cell id="87">
<label id="88">
<text-property
</label>
</cell>
<cell id="89">
<label id="90">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="91">
<cell id="92">
<data id="93">
<property
</data>
</cell>
<cell id="94">
<data id="95">
<property
</data>
</cell>
<cell id="96">
<data id="97">
<property
</data>
</cell>
<cell id="98">
<data id="99">
<property
</data>
</cell>
<cell id="100">
<data id="101">
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="102">
<cell id="103"/>
<cell id="104"/>
<cell id="105"/>
<cell id="106"/>
<cell id="107"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="39">
<cell id="40"/>
<cell id="41"/>
<cell id="77"/>
</row>
</footer>
</table>
</body>
</report>
Re: Print at bottom of page [message #368084 is a reply to message #368083] Thu, 30 April 2009 14:42 Go to previous messageGo to next message
Jason,
Thank you. I think we are headed in the right direction, it works great
except for the outstanding issues:
1. Until now the group footer was using a dynamic text element
row["footer"] as the expression with the content type being HTML. Now I
have replaced that with datasetrow["footer"] and added the oncreate script
as you suggested. And added the text element on the master page as you
did. But now I see HTML elements like <p> <br/> ect. Is there any way to
remove the HTML elements from this?
2. For a two page Order the notes are showing on the bottom of the first
page. Is there any way to have it print on the second page for that Order?
3. The HTML view of the report does not show the data at the bottom of the
page, is there a way to have both the views consistent?
Please advice.
Re: Print at bottom of page [message #368477 is a reply to message #368084] Tue, 02 June 2009 15:52 Go to previous message
I was able to resolve #1. by Changing the ContentType to HTML for the
Dynamic Text Element on the master page.
But I am still looking for some help on issue #2. For a two page order the
notes are repeating on each page I want it to appear only on the last page
of each order.
Any ideas?
Previous Topic:Rotated label and DEAPI
Next Topic:Birt Viewer i18n
Current Time: Mon Sep 01 13:50:48 EDT 2025
Powered by FUDForum. Page generated in 0.07280 seconds
