Home » Archived » BIRT » Property Binding (Home folder field) doen't work with crosstabs
Re: Property Binding (Home folder field) doen't work with crosstabs [message #367084 is a reply to message #367072] |
Tue, 17 February 2009 20:06 |
Chris,
Are you saying if the datasource is used in a crosstab the property
binding doesnt work? What happens if you use a table? then a table and
a crosstab (table first). Also what version of BIRT are you using?
Jason
Chris wrote:
> Hi guys,
> I am sure you are the best of the best BIRT experts...
> Do you know why Property Binding doen't work with crosstabs? It's ok
> with another report items.
> In fact I try to use the field "Home Folder" in a Flat file datasource.
> If the field "Home Folder" has the value 'C:\test', so it's working.
> But if the field "Home Folder" has a dynamic value like
> 'params["DataSourcePath"].value' , so it's ko !!!
> PS : DataSourcePath is a Report Parameters.
> The selected folder that contains the flat files is always "C:\test" :-(
> Thanks in advance.
Re: Property Binding (Home folder field) doen't work with crosstabs [message #367096 is a reply to message #367084] |
Wed, 18 February 2009 10:09 |
Christophe Messages: 15 Registered: July 2009 |
Junior Member |
--------------000204090002080801060306
Yeah Jason,
When I use a table, it's ok.
When I use a table and a crosstab (or only a crosstab), it's ko.
Version of BIRT : 2.3.1
Eclipse : 3.4.0
The fisrt error occured is the following :
org.eclipse.birt.report.engine.api.EngineException: An exception
occurred during processing. Please see the following message for details:
exception.error
Failed to prepare the following query for the data set type
org.eclipse.datatools.connectivity.oda.flatfile.dataSet.
[select "code", "label", "pourcent" from data.csv :
{"code","code",STRING;"label","label",STRING;"pourcent ","pourcent",INT}]
Invalid table name:data.csv
org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1109)
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.d oPrepareQuery(AbstractDataEngine.java:210)
You can have a look to my attached report if you want.
Thanks.
Jason Weathersby a
Re: Property Binding (Home folder field) doen't work with crosstabs [message #367104 is a reply to message #367096] |
Wed, 18 February 2009 17:25 |
Chris,
Can you log a bug for this?
Also as a work around try to move the property binding to the before
Open script for the data set.
Jason
Chris wrote:
> Yeah Jason,
> Eclipse : 3.4.0
> exception.error
> at
> at
> Thanks.
> Jason Weathersby a écrit :
>> Chris,
>> and a crosstab (table first). Also what version of BIRT are you using?
>> Jason
>> Chris wrote:
>>> Hi guys,
>>> Thanks in advance.
Re: Property Binding (Home folder field) doen't work with crosstabs [message #367133 is a reply to message #367104] |
Fri, 20 February 2009 09:40 |
Junior Member |
The bug 265475 has been logged.
> Chris,
> Jason
> Chris wrote:
>> Yeah Jason,
>> Eclipse : 3.4.0
>> exception.error
>> at
>> at
>> Thanks.
>>> Chris,
>>> Jason
>>> Chris wrote:
>>>> Hi guys,
>>>> Thanks in advance.
Current Time: Thu Sep 19 21:28:55 GMT 2024
Powered by FUDForum. Page generated in 0.03739 seconds
