Home » Archived » BIRT » PDF / HTML Print feature as Print Preview page
PDF / HTML Print feature as Print Preview page [message #366938] Tue, 10 February 2009 06:44 Go to next message
I wanted to invoke the pdf / html print functionality from my eclipse
plugin. I found a few similar requirements in some of the previous
newsgroup posts.
One solution was to use BirtUtility.doPrintAction(). But I don't find the
javadocs on how to use this method. When I traced for this class, the
BirtUtility.class is available in viewer.jar which is placed in the plugin
"org.eclipse.birt.report.viewer". Its a jar instead of a plugin!!!
Another solution which I found in the previous newsgroup post is
"If your not able or willing to use OSGi in your application, then you can
do the same thing manually using the Report Engine API. All your doing is
a basic Run task, and Rendering the pages to be previewed, or doing a
RunAndRender task and showing the whole document, sans pagination."
Since I am a newbie to BIRT, the solution is very vague for me to
understand. How can I use the Report Engine API? What is RunAndRender
task?
I have a requirement to use the BIRT print feature as a print preview page
in my application.
Any help is appreciated.
Thanks in advance,
Madhu
Re: PDF / HTML Print feature as Print Preview page [message #366956 is a reply to message #366938] Tue, 10 February 2009 19:44 Go to previous messageGo to next message
Madhu,
The RE API is explained here:
http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
If you preview needs to work like the current designer you can just
include the viewer plugin in your app. Take a look at this example:
http://wiki.eclipse.org/RCP_Example_%28BIRT%29_2.1
Jason
Madhu Samuel wrote:
> Hello,
> newsgroup posts.
> the javadocs on how to use this method. When I traced for this class,
> the BirtUtility.class is available in viewer.jar which is placed in the
> plugin "org.eclipse.birt.report.viewer". Its a jar instead of a plugin!!!
> can do the same thing manually using the Report Engine API. All your
> doing is a basic Run task, and Rendering the pages to be previewed, or
> doing a RunAndRender task and showing the whole document, sans pagination."
> understand. How can I use the Report Engine API? What is RunAndRender task?
> page in my application.
> Thanks in advance,
> Madhu
Re: PDF / HTML Print feature as Print Preview page [message #366960 is a reply to message #366956] Wed, 11 February 2009 00:12 Go to previous message
Jason,
Thanks for those links.
Previous Topic:Joint Data Set not returning any columns
Next Topic:Refresh report in HTML
Current Time: Wed Nov 05 04:37:34 EST 2025
Powered by FUDForum. Page generated in 0.05061 seconds
