Home » Archived » BIRT » GROUP on using the engine?
GROUP on using the engine? [message #366747] Tue, 27 January 2009 17:49 Go to next message
Originally posted by: sadsdfd.asds.com
When a field in a table is group'ed on its added to the TOC. But how is a
field group'ed on using the BIRT Engine? In the below code I would like to
group on firstName:
PropertyHandle computedSet = table.getColumnBindings( );
DataItemHandle data = null;
RowHandle detail = null;
ComputedColumn cs1, cs2, cs3 = null;
// Create Detail for first column.
cs1 = StructureFactory.createComputedColumn( );
cs1.setName("firstName");
cs1.setExpression( "dataSetRow[\"firstName\"]" );//$NON-NLS-1$
computedSet.addItem( cs1 ); //Add an item to the end of a list property
// Add First Column to report.
detail = (RowHandle) table.getDetail( ).get( 0 ); //returns the first
slot.
tcell = (CellHandle) detail.getCells( ).get( 0 );
data = elementFactory.newDataItem( null );
data.setResultSetColumn( cs1.getName( ) );
tcell.getContent( ).add( data );
I have tried something like:
tcell.setEventHandleClass("firstName");
But it seems that the kind of grouping I want is not defined for the object
CellHandle.
Re: GROUP on using the engine? [message #366748 is a reply to message #366747] Wed, 28 January 2009 00:19 Go to previous message
Take a look at this code, specifically the TableGroupHandle.
TableHandle table = elementFactory.newTableItem( null, 3, 1, 1, 1 );
table.setProperty( IStyleModel.TEXT_ALIGN_PROP,
DesignChoiceConstants.TEXT_ALIGN_CENTER );
table.setWidth( "80%" );//$NON-NLS-1$
table.setProperty( IReportItemModel.DATA_SET_PROP, "ds" );//$NON-NLS-1$
ColumnHandle ch = (ColumnHandle)table.getColumns().get(0);
//ch.setProperty("Width", "3in");
ch.getWidth().setStringValue("3in");
cs2 = StructureFactory.createComputedColumn( );
cs3 = StructureFactory.createComputedColumn( );
cs4 = StructureFactory.createComputedColumn( );
cs5 = StructureFactory.createComputedColumn( );
cs1.setName("ORDERNUMBER");
cs1.setExpression( "dataSetRow[\"ORDERNUMBER\"]" );
cs1.setDataType("Integer");
cs2.setName("Product");
cs2.setExpression( "dataSetRow[\"PRODUCTCODE\"]" );
cs2.setDataType("String");
computedSet.addItem( cs2 );
cs3.setName("Amount");
cs3.setExpression( "dataSetRow[\"QUANTITYORDERED\"]");
cs3.setDataType("Integer");
computedSet.addItem( cs3 );
cs4.setName("TotalAmount");
cs4.setExpression( "Total.sum(dataSetRow[\"QUANTITYORDERED\"])" );
cs4.setDataType("Integer");
//cs4.setAggregateOn("All");
computedSet.addItem( cs4 );
cs5.setName("GroupTotalAmount");
cs5.setExpression( "Total.sum(dataSetRow[\"QUANTITYORDERED\"])" );
cs5.setDataType("Integer");
cs5.setAggregateOn("MyGroup");
computedSet.addItem( cs5 );
// Header
RowHandle header = (RowHandle) table.getHeader( ).get( 0 );
CellHandle tcell = (CellHandle) header.getCells( ).get( 0 );
tcell.getWidth().setStringValue("3in");
LabelHandle label = elementFactory.newLabel( null );
label.setText( "Order" );//$NON-NLS-1$
tcell.getContent( ).add( label );
tcell = (CellHandle) header.getCells( ).get( 1 );
label.setText( "Product" );//$NON-NLS-1$
tcell = (CellHandle) header.getCells( ).get( 2 );
label.setText( "Amount" );//$NON-NLS-1$
// Table Group
TableGroupHandle group = elementFactory.newTableGroup( );
group.setName("MyGroup");
group.setKeyExpr( "row[\"ORDERNUMBER\"]" );
group.setInterval("none");
group.setSortDirection("asc");
table.getGroups( ).add( group );
RowHandle groupHeader = elementFactory.newTableRow( 3 );
tcell = (CellHandle) groupHeader.getCells( ).get( 0 );
DataItemHandle data = elementFactory.newDataItem( null );
group.getHeader( ).add( groupHeader );
RowHandle groupFooter = elementFactory.newTableRow( 3 );
tcell = (CellHandle) groupFooter.getCells( ).get( 2 );
data.setResultSetColumn( cs5.getName( ) );
group.getFooter( ).add( groupFooter );
// Detail
RowHandle detail = (RowHandle) table.getDetail( ).get( 0 );
//tcell = (CellHandle) detail.getCells( ).get( 0 );
//data = elementFactory.newDataItem( null );
//data.setResultSetColumn( cs1.getName( ) );
//tcell.getContent( ).add( data );
tcell = (CellHandle) detail.getCells( ).get( 1 );
data.setResultSetColumn( cs2.getName( ) );
tcell = (CellHandle) detail.getCells( ).get( 2 );
data.setResultSetColumn( cs3.getName( ) );
RowHandle footer = (RowHandle) table.getFooter( ).get( 0 );
tcell = (CellHandle) footer.getCells( ).get( 2 );
data.setResultSetColumn( cs4.getName( ) );
reportDesignHandle.getBody( ).add( table );
Jason
> a field group'ed on using the BIRT Engine? In the below code I would
> like to group on firstName:
> slot.
> object CellHandle.
Previous Topic:Modifying a .rptdesign file?
Next Topic:Rotate of log files of the Birt reportEngine
Current Time: Fri Nov 07 10:13:24 EST 2025
Powered by FUDForum. Page generated in 0.03877 seconds
