Re: Does BIRT Report Viewer have zoom in/out function [message #366638 is a reply to message #366637] |
Fri, 16 January 2009 17:32 |
Originally posted by: jasonweathersby.alltel.net
Gavin,
You may be able to add some code like the follow, which does a zoom on a
specific report.
<script language="javascript">
var orginal =screen.width;
function zoomX()
var x= document.getElementById("Document" );
var lst = document.getElementById("ZL");
var zl = lst.options[lst.selectedIndex].value;
x.style.zoom = zl;
</script>
<FORM name="Fm">
<CENTER>
<BR>
<BR>
<SELECT ID=ZL Name=ZoomLevel onChange="zoomX()">
<OPTION Value=.75>75%</OPTION>
<OPTION Value=1 selected>100%</OPTION>
<OPTION Value=1.25>125%</OPTION>
<OPTION Value=1.50>150%</OPTION>
<OPTION Value=2.0>200%</OPTION>
</SELECT>
<BR>
</CENTER>
</FORM>
I just added the code in a text element and set the the type to HTML.
Jason
gavin wrote:
> Hi all,
> I want to add a toolbar like zoom(+) and zoom(-) on the BIRT Report
> Viewer to change size of my report.How can I do? please help me.......
> Thanks in advance.
> Gavin Cao.
Re: Does BIRT Report Viewer have zoom in/out function [message #366659 is a reply to message #366644] |
Tue, 20 January 2009 00:40 |
Gavin,
You may be able to modify the viewer plugins webcontent directory, which
contains css, js, and jsp files to create to the viewer to add the
scroll bars. You can always use the visibility property to hide the
text element containing the code for every output except html.
Jason
gavin wrote:
> Jason,
> Thanks for you reply,I try the code,but the scroll is undisplay,how
> can i do?
> I want to add the code when generate html from the .rptdesign file,would
> you give me some advise?
> thanks again.
> Gavin
Re: Does BIRT Report Viewer have zoom in/out function [message #366664 is a reply to message #366662] |
Tue, 20 January 2009 05:11 |
Gavin,
What is it doing? What did you change in the style.css
Jason
gavin wrote:
> Hi Jason,
> I have changed the
> plugins\org.eclipse.birt.report.viewer_2.3.1.v20080908\birt\ webcontent\birt\styles\style.css,and
> the scroll bar has been display.But,the scroll bar join zoom in/out in
> IE7,and the scroll bar is not correct in BIRT Report Viewer 2.3.1 when
> change the zoom value.Why is it so different? How can i do? pl help me....
> Thanks honestly
> Gavin
Re: Does BIRT Report Viewer have zoom in/out function [message #366669 is a reply to message #366667] |
Tue, 20 January 2009 06:22 |
Gavin,
I tried to do this as well and could not get it.
Look at
// workaround for bug 165750, overflow-x and overflow-y only used in IE
if( BrowserUtility.__isIE( ) )
container.style.overflowX = "visible";
container.style.overflowY = "visible";
in AbstractReportComponent.js. You could try changing that.
Jason
gavin wrote:
> Jason,
> If I don't change the "overflow:auto;" to
> "overflow-x:scroll;overflow-y:scroll;" ,the horizontal scroll bar is
> never display in IE7. Are there some other way to do for me?
> I run the report in BIRT Report Viewer the scroll bar always display
> even though i change the zoom value is 0.1.
> IE7 or BIRT Report Viewer , which I should choose?
Re: Does BIRT Report Viewer have zoom in/out function [message #656864 is a reply to message #656841] |
Mon, 28 February 2011 19:21 |
What browser are you using to test?
Also you could try changing the function to use:
document.body.style.zoom=newZoom;
I do not think the zoom property is supported in all browsers.
Jason
On 2/28/2011 1:37 PM, eminaguil@gmail.com wrote:
> Hi, I have tried your code and it works in the report, but i want this
> function in the viewer toolbar so i put the code in ToolbarFragment.jsp
> but it doesn´t work
> i put the js before the toolbar
> function zoomX()
> x.style.zoom = zl;
> </script>
> <TD COLSPAN='2'>
> <DIV ID="toolbar">
> and add a column after the print button
> <TD WIDTH="6px"/>
> <TD WIDTH="45px">
> <SELECT ID="ZL" Name="ZoomLevel" onChange="zoomX()">
> <OPTION Value=".50">50%</OPTION>
> <OPTION Value=".75">75%</OPTION>
> <OPTION Value=".90">90%</OPTION>
> <OPTION Value="1" selected>100%</OPTION>
> <OPTION Value="1.25">125%</OPTION>
> <OPTION Value="1.50">150%</OPTION>
> </SELECT>
> </TD>
> I´ve used firebug to check if the Document element exists in this
> context and it does.
> Can somebody give me a tip?
Re: Does BIRT Report Viewer have zoom in/out function [message #656887 is a reply to message #656877] |
Mon, 28 February 2011 21:53 |
What version of BIRT are you using?
On 2/28/2011 4:06 PM, Edwin wrote:
> Thanks for your answer Jason.
> I'm using IE8 and FF3.6 but the style.zoom don´t work.
> I tried changing the zoom in the document body like you said, or using
> the style sizeFont but nothing
> ________________
> Edwin
Re: Does BIRT Report Viewer have zoom in/out function [message #657150 is a reply to message #656896] |
Tue, 01 March 2011 18:09 |
eminaguil Messages: 8 Registered: February 2011 |
I've done it using css3 . I´ve tested in FF 3.6, Chrome 9.059 and Opera 11.01,
I don't have IE9 for testing, but maybe I will try using the Microsoft's Matrix Filter for compatibility issues.
Here is the code to insert in the ToolbarFragment.jsp
the script (just before the toolbar) is
var zoomData = [
{scl: ".4", tra: "-76%"},
{scl: ".5", tra: "-50%" },
{scl: ".6", tra: "-33%" },
{scl: ".7", tra: "-21.5%" },
{scl: ".8", tra: "-12.5%" },
{scl: ".9", tra: "-5.5%" },
{scl: "1.0", tra: "0%" },
{scl: "1.1", tra: "4.5%" },
{scl: "1.2", tra: "8.5%" },
{scl: "1.3", tra: "11.5%" }
function zoomX()
var x = document.getElementById("Document");
var tra = "scale(" + zoomData[zl].scl + ") translate(" + zoomData[zl].tra + "," + zoomData[zl].tra + ")";
x.style.OperaTransform = tra;
x.style.msTransform = tra;
x.style.MozTransform = tra;
x.style.webkitTransform = tra;
</script>
<TD COLSPAN='2'>
<DIV ID="toolbar">
and the control after the print button
<TD WIDTH="6px"/>
<TD WIDTH="45px">
<OPTION Value="1">50%</OPTION>
<OPTION Value="2">60%</OPTION>
<OPTION Value="3">70%</OPTION>
<OPTION Value="4">80%</OPTION>
<OPTION Value="5">90%</OPTION>
<OPTION Value="6" selected>100%</OPTION>
<OPTION Value="7">110%</OPTION>
<OPTION Value="8">120%</OPTION>
<OPTION Value="9">130%</OPTION>
</SELECT>
</TD>
Best regards
______________
Edwin
FUDForum. Page generated in 0.14980 seconds
