| Home » Archived » BIRT » embedding BIRT in a stand alone java application
 Goto Forum:|
| embedding BIRT in a stand alone java application [message #366451] | Fri, 02 January 2009 10:26  |  |
| Eclipse User  |  |  |  |  | I'm trying to embed BIRT 2.2.2 in a stand alone Java application (1.6). I'm not getting far using the examples at:
 http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
 I would first like to point out that there are many syntax errors in the example source codes, like "final config = new EngineConfig( );", or duplicate variables. But I can work around that, no problem.
 What is problematic is that the code is not running. Below my current test class which just tries to generate a PDF of a report that runs correctly in the designer:
 import java.util.logging.Level;
 import org.eclipse.birt.core.framework.Platform;
 import org.eclipse.birt.report.engine.api.EngineConfig;
 import org.eclipse.birt.report.engine.api.EngineConstants;
 import org.eclipse.birt.report.engine.api.IPDFRenderOption;
 import org.eclipse.birt.report.engine.api.IRenderOption;
 import org.eclipse.birt.report.engine.api.IRenderTask;
 import org.eclipse.birt.report.engine.api.IReportDocument;
 import org.eclipse.birt.report.engine.api.IReportEngine;
 import org.eclipse.birt.report.engine.api.IReportEngineFactory;
 import org.eclipse.birt.report.engine.api.PDFRenderOption;
 import org.eclipse.birt.report.engine.api.RenderOption;
 public class FirstTest
 * @param args
 public static void main(String[] args)
 try{
 final EngineConfig config = new EngineConfig( );
 config.setEngineHome( "C:/tmp/birt-runtime-2_2_2/birt-runtime-2_2_2/ReportEngine" );
 config.setLogConfig("c:/tmp/", Level.FINEST);
 Platform.startup( config );  //If using RE API in Eclipse/RCP application this is not needed.
 IReportEngineFactory factory = (IReportEngineFactory) Platform.createFactoryObject( IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
 IReportEngine engine = factory.createReportEngine( config );
 engine.changeLogLevel( Level.WARNING );
 //Open a report document
 IReportDocument iReportDocument = engine.openReportDocument(" C:/tmp/birt-rcp-report-designer-2_2_2/birt-rcp-report-design er-2_2_2/workspace/new_report.rptdesign ");
 IRenderOption options = new RenderOption();
 options.setOutputFormat("pdf");
 options.setOutputFileName("c:/tmp/test.pdf");
 PDFRenderOption pdfOptions = new PDFRenderOption( options );
 pdfOptions.setOption( IPDFRenderOption.FIT_TO_PAGE, new Boolean(true) );
 pdfOptions.setOption( IPDFRenderOption.PAGEBREAK_PAGINATION_ONLY, new Boolean(true) );
 IRenderTask task = engine.createRenderTask(iReportDocument);
 task.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOA DER_KEY, FirstTest.class.getClassLoader());
 task.setRenderOption(options);
 //task.setPageRange("1-2");
 task.render();
 iReportDocument.close();
 engine.destroy();
 Platform.shutdown();
 System.out.println("done");
 catch( Exception ex){
 ex.printStackTrace();
 This results in:
 at nl.reinders.birt.FirstTest.main(FirstTest.java:38)
 Line 38 is the "factory.createReportEngine" line. There is no logging output in the "c:/tmp/" directory, so I'm a bit clueless on what is going wrong.
 Any suggestions?
| Re: embedding BIRT in a stand alone java application [message #366455 is a reply to message #366451] | Fri, 02 January 2009 12:57   |  |
| Eclipse User  |  |  |  |  | Hi tbee,
 There are a couple of examples at
 http://www.birt-exchange.com/devshare/deploying-birt-reports /568-execute-birt-reports-from-java-class/#description
 Virgil Dodson
 >      * @param args
 >         try{
 > Boolean(true) );
 >             IRenderTask task =
 >             task.render();
 >             engine.destroy();
 > This results in:
 > java.lang.NullPointerException
 > going wrong.
 > Any suggestions?
| Re: embedding BIRT in a stand alone java application [message #366465 is a reply to message #366462] | Sat, 03 January 2009 07:12   |  |
| Eclipse User  |  |  |  |  | Originally posted by: johnw.innoventsolutions.com
 What version of BIRT are you using? 2.2.2?
 Also, the BIRT_HOME variable is required because BIRT runs as a plugin,
 not a purely Java object. So, even though you are using it in a Java
 project, the BIRT runtime is executed through some sort of Eclipse-like
 plugin environment, which is what the Platform.startup call is doing. If
 you  were to run this as an RCP or OSGi project, you could omit the BIRT
 home setting and Platform.startup calls.
 John
 > Well, I copied the "RenderReport" class exactly and only replaced the
 > paths.
 > package nl.reinders.birt;
 > import org.eclipse.birt.report.engine.api.EngineException;
 > import org.eclipse.birt.report.engine.api.HTMLRenderOption;
 > import org.eclipse.birt.report.engine.api.IReportRunnable;
 > import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
 > import org.eclipse.birt.report.model.elements.olap.Level;
 > public class RenderReport
 >         try
 >             renderReport();
 >         catch (Exception e)
 >             e.printStackTrace();
 >     static void renderReport() throws EngineException
 >         IReportEngine engine = null;
 >         EngineConfig config = null;
 >         try
 >             config = new EngineConfig();
 > config.setBIRTHome(" C:\\tmp\\birt-runtime-2_2_2\\birt-runtime-2_2_2\\ReportEngin e ");
 >             config.setLogConfig("c:\\tmp\\",
 > java.util.logging.Level.FINEST);
 >             Platform.startup(config);
 >  Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
 >             engine = factory.createReportEngine(config);
 >             // Open a report document
 >             IReportDocument document =
 > engine.openReportDocument(" C:\\tmp\\birt-rcp-report-designer-2_2_2\\birt-rcp-report-des igner-2_2_2\\workspace\\new_report.rptdesign ");
 >             // Create Render Task
 >             IRenderTask task = engine.createRenderTask(document);
 >             // Set parent classloader report engine
 > RenderTaskExample.class.getClassLoader());
 >             PDFRenderOption pdfOptions = new PDFRenderOption();
 >             pdfOptions.setOption(IPDFRenderOption.FIT_TO_PAGE, new
 > Boolean(true));
 >             // pdfOptions.setOption(
 >             pdfOptions.setOutputFormat("pdf");
 >             pdfOptions.setOutputFileName("c:\\tmp\\test.pdf");
 >             task.setRenderOption(pdfOptions);
 >             task.render();
 >             document.close();
 >             task.close();
 >             engine.destroy();
 >         catch (Exception ex)
 >         finally
 > I still get an exception on the createReportEngine; createFactoryObject
 > returns a null.
 >     at  nl.reinders.birt.RenderReport.renderReport(RenderReport.java :52)
 >     at nl.reinders.birt.RenderReport.main(RenderReport.java:31)
 > If only BIRT would log why, but there are no log files in c:\tmp.
 > Tom
 > PS: why is the "setBIRTHome" required? If all JARS have been included in
 > the classpath...  I usually get cautious when I see such a construct.
| Re: embedding BIRT in a stand alone java application [message #366469 is a reply to message #366462] | Sat, 03 January 2009 18:06   |  |
 Give this a try instead of using the EngineConfig to pass into the
 Platform. Using the PlatformConfig might have been deprecated (I cant
 remember off hand), but it should still work in 2.2.2. this is from a
 recent project I worked on, and I dont have any issues with it. Just
 make sure your BIRT_HOME is pointing to the root folder containing the
 /plugins, /lib, and /configuration directories.
 //initialize the Eclipse platform, plugins, and report engine
 PlatformConfig platformConfig = new PlatformConfig();
 platformConfig.setBIRTHome(BIRT_HOME);
 Platform.startup(platformConfig);
 //create a new report engine factory
 EngineConfig engineConfig = new EngineConfig();
 engineConfig.setBIRTHome(BIRT_HOME); //will replace with configuration file
 engine = factory.createReportEngine(engineConfig);
 > paths.
 >         try
 >             renderReport();
 >         catch (Exception e)
 >         try
 > Boolean(true));
 >             task.render();
 >             document.close();
 >             task.close();
 >             engine.destroy();
 >         finally
 > returns a null.
 > Tom
| Re: embedding BIRT in a stand alone java application [message #366470 is a reply to message #366469] | Sun, 04 January 2009 02:23   |  |
| Eclipse User  |  |  |  |  | > Give this a try instead of using the EngineConfig to pass into the > Platform. Using the PlatformConfig might have been deprecated (I cant
 factory=null
 at  nl.reinders.birt.RenderReport.renderReport(RenderReport.java :60)
 at nl.reinders.birt.RenderReport.main(RenderReport.java:32)
 As you can see, the factory still is null.
 I have triple checked that the directory I use as the BIRT_HOME indeeds points to the one with the plugins. I'm wondering why there is no trace information at all. Not even an empty log file.
 platformConfig.setBIRTHome(" C:\\tmp\\birt-runtime-2_2_2\\birt-runtime-2_2_2\\ReportEngin e ");
 IReportEngineFactory factory = (IReportEngineFactory)  Platform.createFactoryObject(IReportEngineFactory.EXTENSION_ REPORT_ENGINE_FACTORY);
 System.out.println("factory=" + factory);
 engineConfig.setLogConfig("c:\\tmp\\", java.util.logging.Level.FINEST);
 engineConfig.setBIRTHome(" C:\\tmp\\birt-runtime-2_2_2\\birt-runtime-2_2_2\\ReportEngin e "); //will replace with configuration file
 From a DOS console:
 Microsoft Windows XP [Version 5.1.2600]
 (C) Copyright 1985-2001 Microsoft Corp.
 C:\Documents and Settings\user>cd C:\tmp\birt-runtime-2_2_2\birt-runtime-2_2_2\R
 eportEngine
 C:\tmp\birt-runtime-2_2_2\birt-runtime-2_2_2\ReportEngine>dir
 Volume in drive C has no label.
 Volume Serial Number is B4FA-7086
 Directory of C:\tmp\birt-runtime-2_2_2\birt-runtime-2_2_2\ReportEngine
 04-01-2009  08:16    <DIR>          .
 04-01-2009  08:16    <DIR>          ..
 04-01-2009  08:16    <DIR>          configuration
 27-02-2008  13:08             2.907 genReport.bat
 27-02-2008  13:08             2.703 genReport.sh
 27-02-2008  13:08    <DIR>          lib
 27-02-2008  13:08    <DIR>          plugins
 27-02-2008  13:08    <DIR>          samples
 02-01-2009  16:09    <DIR>          workspace
 2 File(s)          5.610 bytes
 7 Dir(s)  10.625.540.096 bytes free
| Re: embedding BIRT in a stand alone java application [message #366471 is a reply to message #366465] | Sun, 04 January 2009 02:29   |  |
| Eclipse User  |  |  |  |  | > Also, the BIRT_HOME variable is required because BIRT runs as a plugin, > not a purely Java object. So, even though you are using it in a Java
 Ok, but I still find such external references, ehm, uncomfortable; plugin logic can be written using the classpath alone.
 But never mind, it is not up to me -at this time- to have an opinion on the chosen architecture. Especially since I do understand what an RCP or OSGi project is, but have not technical experience with them at all. Another point I intend to remedy sometime; the JRE seems to be going OSGi as well in favor of the intended new JAR jsr.
| Re: embedding BIRT in a stand alone java application [message #366473 is a reply to message #366471] | Sun, 04 January 2009 04:23  |  |
 The BIRT_HOME variable just tells the launcher where the plugins are
 located. I suppose there is a way to do it with a configuration to avoid
 having to set BIRT_HOME, but I've never needed to do so in Java projects
 so I couldn't tell you how.
 John
 >> plugin, not a purely Java object. So, even though you are using it in
 >> a Java project, the BIRT runtime is executed through some sort of
 >> Eclipse-like plugin environment, which is what the Platform.startup
 >> call is doing. If you  were to run this as an RCP or OSGi project, you
 >> could omit the BIRT home setting and Platform.startup calls.
 Current Time: Fri Oct 31 19:14:08 EDT 2025
 Powered by FUDForum . Page generated in 0.55991 seconds |
