WebViewer - RCP - AppContext [message #366289] |
Sat, 13 December 2008 03:21  |
Originally posted by: anupgokhale.rediffmail.com
Hi all.
I am using the report viewer plug-in within my RCP app. All my reports
use scripted dataset. In this case, how do I pass my POJOs (objects) to
the webviewer?
When using the RE API I achieve the above by:
engine.getConfig().setAppContext( contextmap );
where contextmap is a hashmap that containes my object(s). I can then
use reportContext.getAppContext().get( "OBJName" ) to retrieve my passed
object.
I have read that when used in a JSP app, we can set theapp context ny
using request.setAttribute(), but in this case as my application is RCP
how do I set the app context?
Anup Gokhale
Re: WebViewer - RCP - AppContext [message #366316 is a reply to message #366298] |
Mon, 15 December 2008 22:56   |
Jason Weathersby wrote:
> Anup,
> Using the appcontext extension point is a great way to do this.
> That extension point was added to allow what you are trying to do. It
> allows users to simulate there web environment from the designer. In
> your case you not simulating but the extension point is still valid for
> this operation.
> Jason
> Anup Gokhale wrote:
>> Anup Gokhale wrote:
>>> Hi all.
>>> reports use scripted dataset. In this case, how do I pass my POJOs
>>> (objects) to the webviewer?
>>> passed object.
>>> RCP how do I set the app context?
>>> Regards,
>>> Anup Gokhale
>> I have been able to achieve the above by extending the
>> "org.eclipse.birt.report.viewer.appcontext" extension point. Is this
>> teh correct way? Also is there some other way of passing the app
>> context in a RCP app - web viewer combination?
>> Regards,
>> Anup Gokhale
Jason,
Apart from using the appcontext extension point, is there any other way
to achieve the above?
Anup Gokhale
Re: WebViewer - RCP - AppContext [message #366327 is a reply to message #366316] |
Tue, 16 December 2008 13:59  |
Anup,
You can always export the viewer src and import into your project and
modify it. But that may be more than you want to do.
Jason
>> Anup,
>> for this operation.
>> Jason
>> Anup Gokhale wrote:
>>> Anup Gokhale wrote:
>>>> Hi all.
>>>> then use reportContext.getAppContext().get( "OBJName" ) to retrieve
>>>> my passed object.
>>>> ny using request.setAttribute(), but in this case as my application
>>>> is RCP how do I set the app context?
>>>> Regards,
>>>> Anup Gokhale
>>> Regards,
>>> Anup Gokhale
> Jason,
> Anup Gokhale
FUDForum. Page generated in 0.03607 seconds
