Home » Archived » BIRT » how to make sum of percentile = 100
how to make sum of percentile = 100 [message #365648] Tue, 21 October 2008 04:56 Go to next message
Hello to all ,
I'm a new Birt user and I'm trying to do a report which display financial
analysis with a crosstab and a datacube.
There is a column that shows percentiles of a quantity .
I have created a group whith in the total sum is the sum of the
percentiles.
In many cases the total sum is 100 ,
in a few cases , cause the approximation to two decimal digits , the sum
is 99.99.
To solve this , I have to add 0.01 to the last percentile row of the group
Do you know how can I do that ??
I guess with javascript for example ...
I wonder if there is a function like
data["percentile"].getLastRow().value ,
so I can adjust the last percentile doing this:
=data["percentile"].getLastRow().value+0.01
Hope I well explained the problem .
Many thanks ,
Alessio
Re: how to make sum of percentile = 100 [message #365660 is a reply to message #365648] Tue, 21 October 2008 12:43 Go to previous messageGo to next message
Alessio,
Can you not just modify the sum expression to round or fixed decimal digits?
ie
xyz = 99.99;
xyz.toFixed(0);
Jason
Alessio Lai wrote:
> Hello to all ,
> financial analysis with a crosstab and a datacube.
> percentiles.
> is 99.99.
> group ,
> Many thanks ,
> Alessio
Re: how to make sum of percentile = 100 [message #365812 is a reply to message #365660] Tue, 04 November 2008 11:12 Go to previous messageGo to next message
Jason Weathersby wrote:
> Alessio,
> ie
> xyz = 99.99;
> xyz.toFixed(0);
> Jason
> Alessio Lai wrote:
>> Hello to all ,
>> percentiles.
>> is 99.99.
>> group ,
>> Many thanks ,
>> Alessio
Jason , many thanks for the reply , and I apologize for resurrecting a
dead thread but I've already setted up the sum of singles percentiles =
100 , by literally doing a compColumn.setExpression(100) in the total.
What I'm trying to achieve is , supposing that I have a table similar to
this :
Data1 Perc
148.960,00 1,31
2.985.200,00 26,32
247.520,00 2,18
4.270.560,00 37,65
1.328.320,00 11,71
2.360.960,00 20,82
Tot: 11.341.520,00 100
Here's a real example of a report generated from me.
Perc column is a ComputedColumn with an expression setted up of this kind :
Finance.percent(data["Data1"],data["Data1_Group/LEV1"]); (where
Data1_Group/LEV1 is defined as the sum of Data1's data.)
The tot value of column Perc isn't calculated as the sum of the singles
percentiles , but is setted directly to 100.
The problem is that the sum of the single percentiles isn't 100 but 99.99
In other cases 100.01 .
Is there a way (in some report phase) to handle the last row of the column
Perc to sum in it the difference between the effective column's sum
(99.99) and 100 ?
Many thanks ,
Greetings
Alessio
Re: how to make sum of percentile = 100 [message #365813 is a reply to message #365812] Tue, 04 November 2008 11:32 Go to previous messageGo to next message
Alessio,
In you example what should be the total value?
Jason
>> Alessio,
>> digits?
>> ie
>> xyz = 99.99;
>> xyz.toFixed(0);
>> Jason
>> Alessio Lai wrote:
>>> Hello to all ,
>>> percentiles.
>>> sum is 99.99.
>>> group ,
>>> Many thanks ,
>>> Alessio
> this :
> Data1 Perc
> 148.960,00 1,31
> 2.985.200,00 26,32
> 247.520,00 2,18
> 4.270.560,00 37,65
> 1.328.320,00 11,71
> 2.360.960,00 20,82
> 99.99 In other cases 100.01 .
> column Perc to sum in it the difference between the effective column's
> sum (99.99) and 100 ?
> Many thanks ,
> Greetings
> Alessio
Re: how to make sum of percentile = 100 [message #365841 is a reply to message #365813] Thu, 06 November 2008 10:44 Go to previous messageGo to next message
Hi , jason ,
the total value should be 100.
But this isn't a problem , since I set it to 100 simply by doing
via java a
'compColumn.setExpression("100");'
where compColumn is a ComputedColumn object.
Now I found an (ugly) solution , making a javascript global var , i.e.
'realSum = 0'
sum in it the real partial percentiles during the report factory phase .
At the end , the variable realSum will be 99.99.
Then I only have to add to the last perc column row , 100-99.99 , to make
the column sum = 100.
Now the question is : is there a way to handle via javascript the last cell
of the column Perc to add in it the value 0.01 ?
Thanks ,
Greetings
Alessio
> Alessio,
> Jason
>>> Alessio,
>>> digits?
>>> ie
>>> xyz = 99.99;
>>> xyz.toFixed(0);
>>> Jason
>>> Alessio Lai wrote:
>>>> Hello to all ,
>>>> percentiles.
>>>> sum is 99.99.
>>>> group ,
>>>> Many thanks ,
>>>> Alessio
>> this :
>> Data1 Perc
>> 148.960,00 1,31
>> 2.985.200,00 26,32
>> 247.520,00 2,18
>> 4.270.560,00 37,65
>> 1.328.320,00 11,71
>> 2.360.960,00 20,82
>> Many thanks ,
>> Greetings
>> Alessio
Re: how to make sum of percentile = 100 [message #365887 is a reply to message #365841] Mon, 10 November 2008 11:33 Go to previous messageGo to next message
Alessio,
I apologize for the late reply. I did not see your post. Did you get
an answer to this question? If you use a global JS var, you should be
able to access it in the expression builder for any data item.
ie (example expression)
row["mydatavalue"]+ myglobablvar;
Jason
Alessio Lai wrote:
> Hi , jason ,
> via java a 'compColumn.setExpression("100");'
> 'realSum = 0' sum in it the real partial percentiles during the report
> factory phase .
> make the column sum = 100.
> Thanks ,
> Greetings
> Alessio
> where compColumn is a Jason Weathersby wrote:
>> Alessio,
>> Jason
>>>> Alessio,
>>>> digits?
>>>> ie
>>>> xyz = 99.99;
>>>> xyz.toFixed(0);
>>>> Jason
>>>> Alessio Lai wrote:
>>>>> Hello to all ,
>>>>> percentiles.
>>>>> the sum is 99.99.
>>>>> the group ,
>>>>> Many thanks ,
>>>>> Alessio
>>> a dead thread but I've already setted up the sum of singles
>>> percentiles = 100 , by literally doing a
>>> to this :
>>> Data1 Perc
>>> 148.960,00 1,31
>>> 2.985.200,00 26,32
>>> 247.520,00 2,18
>>> 4.270.560,00 37,65
>>> 1.328.320,00 11,71
>>> 2.360.960,00 20,82
>>> kind :
>>> singles percentiles , but is setted directly to 100.
>>> column's sum (99.99) and 100 ?
>>> Many thanks ,
>>> Greetings
>>> Alessio
Re: how to make sum of percentile = 100 [message #365899 is a reply to message #365887] Tue, 11 November 2008 02:44 Go to previous message
Thank you , Jason ,for the suggest. I'll try that.
Best regards ,
Alessio
> Alessio,
> Jason
> Alessio Lai wrote:
>> Hi , jason ,
>> factory phase .
>> Thanks ,
>> Greetings
>> Alessio
>>> Alessio,
>>> Jason
>>>>> Alessio,
>>>>> digits?
>>>>> ie
>>>>> xyz = 99.99;
>>>>> xyz.toFixed(0);
>>>>> Jason
>>>>> Alessio Lai wrote:
>>>>>> Hello to all ,
>>>>>> percentiles.
>>>>>> the sum is 99.99.
>>>>>> the group ,
>>>>>> Many thanks ,
>>>>>> Alessio
>>>> to this :
>>>> Data1 Perc
>>>> 148.960,00 1,31
>>>> 2.985.200,00 26,32
>>>> 247.520,00 2,18
>>>> 4.270.560,00 37,65
>>>> 1.328.320,00 11,71
>>>> 2.360.960,00 20,82
>>>> kind :
>>>> Many thanks ,
>>>> Greetings
>>>> Alessio
Previous Topic:Execute From Report
Next Topic:Error on report (preview tab) "The report contains errors, would you like to continue for previ
Current Time: Tue Nov 04 01:03:17 EST 2025
Powered by FUDForum. Page generated in 0.05111 seconds
