Home » Archived » BIRT » Problem exporting to excel
Problem exporting to excel [message #365617] Thu, 16 October 2008 10:15 Go to next message
I am on the BIRT 2.2.2 version
The report contains two nested table elements. And each nested table
contains fields from a single dataset.
When I preview the report in the webviewer, html, pdf it runs perfectly.
However when I run it as XLS it gives me the following window:
Problems During Load
Problems came up in the following areas during load:
Table
This file cannot be opened because of errors. Errors are listed in
C:\Documents and Settings\username\Local Settings\Temporary Internet
Files\Content.MSO\C4DD6BO.log
But I was not able to find Content.MSO file in that folder. I even made
sure that all the hidden files are also shown.
Please advice whats wrong here. Does BIRT not support exporting nested
tables to excel? Because when I removed the two nested table the export
goes through fine. Is there a workaround to using nested tables?
icon5.gif  Re: Problem exporting to excel [message #755368 is a reply to message #365617] Tue, 08 November 2011 04:44 Go to previous messageGo to next message
Has anyone found a solution for this bug?
Re: Problem exporting to excel [message #755557 is a reply to message #755368] Tue, 08 November 2011 14:40 Go to previous message
Have you tried a later version of BIRT?
Is this the same error?
https://bugs.eclipse.org/bugs/show_bug.cgi?id=262386
Jason
Previous Topic:How to switch between crosstab view / chart view
Next Topic:Dynamic HTML formatted tooltip in crosstab
Current Time: Mon Sep 01 13:47:05 EDT 2025
Powered by FUDForum. Page generated in 0.03065 seconds
