Home » Archived » BIRT » Having birt.war & other application running on same application server
Having birt.war & other application running on same application server [message #365010] Fri, 05 September 2008 06:24 Go to next message
Originally posted by: moi.toto.com
When using Birt-viewer and another war application which use BIRT API,
I've got this error based on those steps :
.. Access application which is using birt API
.. Access to birt viewer
Error :
12:10:15,654 INFO [STDOUT] at
org.eclipse.birt.report.model.api.DesignEngin
e.newSessionHandle(DesignEngine.java:108)
12:10:15,656 INFO [STDOUT] at
org.eclipse.birt.report.engine.parser.ReportP
arser.getDesignHandle(ReportParser.java:143)
12:10:15,657 INFO [STDOUT] at
org.eclipse.birt.report.engine.api.impl.Repor
tEngineHelper.openReportDesign(ReportEngineHelper.java:251)
12:10:15,661 INFO [STDOUT] at
tEngine.openReportDesign(ReportEngine.java:550)
12:10:15,665 INFO [STDOUT] at
org.eclipse.birt.report.service.ReportEngineS
ervice.openReportDesign(ReportEngineService.java:366)
12:10:15,668 INFO [STDOUT] at
org.eclipse.birt.report.utility.BirtUtility.g
etRunnableFromDesignFile(BirtUtility.java:590)
12:10:15,671 INFO [STDOUT] at
org.eclipse.birt.report.context.ViewerAttribu
teBean.getDesignHandle(ViewerAttributeBean.java:641)
12:10:15,673 INFO [STDOUT] at
teBean.__init(ViewerAttributeBean.java:227)
12:10:15,676 INFO [STDOUT] at
org.eclipse.birt.report.context.BaseAttribute
Bean.init(BaseAttributeBean.java:243)
12:10:15,679 INFO [STDOUT] at
teBean.<init>(ViewerAttributeBean.java:112)
12:10:15,681 INFO [STDOUT] at
org.eclipse.birt.report.context.BirtContext._
_init(BirtContext.java:44)
12:10:15,683 INFO [STDOUT] at
org.eclipse.birt.report.context.BaseContext.<
init>(BaseContext.java:69)
12:10:15,686 INFO [STDOUT] at
org.eclipse.birt.report.context.BirtContext.<
init>(BirtContext.java:30)
12:10:15,687 INFO [STDOUT] at
org.eclipse.birt.report.servlet.ViewerServlet
..__getContext(ViewerServlet.java:150)
12:10:15,689 INFO [STDOUT] at
org.eclipse.birt.report.servlet.BirtSoapMessa
geDispatcherServlet.doGet(BirtSoapMessageDispatcherServlet.j ava:137)
12:10:15,691 INFO [STDOUT] at
javax.servlet.http.HttpServlet.service(HttpSe
rvlet.java:697)
12:10:15,693 INFO [STDOUT] at
org.apache.axis.transport.http.AxisServletBas
e.service(AxisServletBase.java:327)
12:10:15,696 INFO [STDOUT] at
rvlet.java:810)
12:10:15,697 INFO [STDOUT] at
geDispatcherServlet.service(BirtSoapMessageDispatcherServlet .java:112)
12:10:15,698 INFO [STDOUT] at
org.apache.catalina.core.ApplicationFilterCha
in.internalDoFilter(ApplicationFilterChain.java:237)
12:10:15,702 INFO [STDOUT] at
in.doFilter(ApplicationFilterChain.java:157)
12:10:15,703 INFO [STDOUT] at
org.eclipse.birt.report.filter.ViewerFilter.d
oFilter(ViewerFilter.java:68)
12:10:15,704 INFO [STDOUT] at
in.internalDoFilter(ApplicationFilterChain.java:186)
12:10:15,707 INFO [STDOUT] at
12:10:15,709 INFO [STDOUT] at
org.jboss.web.tomcat.filters.ReplyHeaderFilte
r.doFilter(ReplyHeaderFilter.java:75)
12:10:15,712 INFO [STDOUT] at
12:10:15,714 INFO [STDOUT] at
12:10:15,718 INFO [STDOUT] at
org.apache.catalina.core.StandardWrapperValve
..invoke(StandardWrapperValve.java:214)
12:10:15,720 INFO [STDOUT] at
org.apache.catalina.core.StandardValveContext
..invokeNext(StandardValveContext.java:104)
12:10:15,721 INFO [STDOUT] at
org.apache.catalina.core.StandardPipeline.inv
oke(StandardPipeline.java:520)
12:10:15,725 INFO [STDOUT] at
org.apache.catalina.core.StandardContextValve
..invokeInternal(StandardContextValve.java:198)
12:10:15,727 INFO [STDOUT] at
..invoke(StandardContextValve.java:152)
12:10:15,728 INFO [STDOUT] at
12:10:15,729 INFO [STDOUT] at
org.jboss.web.tomcat.security.CustomPrincipal
Valve.invoke(CustomPrincipalValve.java:44)
12:10:15,730 INFO [STDOUT] at
..invokeNext(StandardValveContext.java:102)
12:10:15,731 INFO [STDOUT] at
org.jboss.web.tomcat.security.SecurityAssocia
tionValve.invoke(SecurityAssociationValve.java:169)
12:10:15,734 INFO [STDOUT] at
12:10:15,735 INFO [STDOUT] at
12:10:15,736 INFO [STDOUT] at
org.apache.catalina.core.StandardHostValve.in
voke(StandardHostValve.java:137)
12:10:15,738 INFO [STDOUT] at
12:10:15,740 INFO [STDOUT] at
org.apache.catalina.valves.ErrorReportValve.i
nvoke(ErrorReportValve.java:118)
12:10:15,741 INFO [STDOUT] at
12:10:15,743 INFO [STDOUT] at
org.jboss.web.tomcat.tc5.jca.CachedConnection
Valve.invoke(CachedConnectionValve.java:139)
12:10:15,745 INFO [STDOUT] at
12:10:15,748 INFO [STDOUT] at
12:10:15,749 INFO [STDOUT] at
org.apache.catalina.core.StandardEngineValve.
invoke(StandardEngineValve.java:109)
12:10:15,751 INFO [STDOUT] at
12:10:15,754 INFO [STDOUT] at
12:10:15,756 INFO [STDOUT] at
org.apache.catalina.core.ContainerBase.invoke
(ContainerBase.java:929)
12:10:15,757 INFO [STDOUT] at
org.apache.coyote.tomcat5.CoyoteAdapter.servi
ce(CoyoteAdapter.java:160)
12:10:15,760 INFO [STDOUT] at
org.apache.coyote.http11.Http11Processor.proc
ess(Http11Processor.java:799)
12:10:15,761 INFO [STDOUT] at
org.apache.coyote.http11.Http11Protocol$Http1
1ConnectionHandler.processConnection(Http11Protocol.java:705 )
12:10:15,763 INFO [STDOUT] at
org.apache.tomcat.util.net.TcpWorkerThread.ru
nIt(PoolTcpEndpoint.java:577)
12:10:15,766 INFO [STDOUT] at
org.apache.tomcat.util.threads.ThreadPool$Con
trolRunnable.run(ThreadPool.java:683)
12:10:15,767 INFO [STDOUT] at java.lang.Thread.run(Thread.java:619)
war application code :
String reportName = req.getParameter("report_name");
EngineConfig engConfig = new EngineConfig();
engConfig.setEngineHome("");
IPlatformContext context = new PlatformServletContext(
getServletContext() );
Platform.startup(engConfig);
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
IReportEngine engine = factory.createReportEngine( engConfig );
engine.changeLogLevel( Level.WARNING );
IReportRunnable report = engine.openReportDesign("c:/" +
reportName);
//Create task to run and render the report,
IRunAndRenderTask task = engine.createRunAndRenderTask(report);
//Set parent classloader for engine
task.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOA DER_KEY,
this.getClass().getClassLoader());
//Setup rendering to HTML/Excel
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputStream(resp.getOutputStream());
options.setOutputFormat("html");
resp.setContentType("dummyNameForSaveDialogOpening/Test");
options.setImageDirectory(c:/images);
options.setBaseImageURL("http://localhost/images");
options.setImageHandler(new HTMLServerImageHandler());
options.setEmbeddable(false);
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
Platform.shutdown();
If I remove the Platform.shutdown() it works but there are some memory
leaks.
So do you have a solution to have a WAR application which is using Birt
API and birt viewer on the same application server (jboss or tomcat) ?
Blured.
Re: Having birt.war & other application running on same application server [message #365027 is a reply to message #365010] Fri, 05 September 2008 12:31 Go to previous messageGo to next message
Moi,
I have not tried this, but you may be able to point the API BIRT_HOME to
the location of the Platform directory for the webviewer and do not use
a PlatformServletContext. BTW Platform start up and shutdown should
only happen once for your app. It is very inefficient to start and stop
for every request. Also only destroy the engine on shutdown of the app.
Can you give some more detail on the memory leak?
Jason
moi wrote:
> Hello,
> Error :
> rvlet.java:697)
> rvlet.java:810)
> reportName);
> task.run();
> task.close();
> engine.destroy();
> leaks.
> Blured.
Re: Having birt.war & other application running on same application server [message #365042 is a reply to message #365027] Mon, 08 September 2008 05:01 Go to previous messageGo to next message
I'm making more test to see if the memory leak is still there or not.
The platform start up & shutdown also occurs with web viewer each time
it is launched is'nt it ? If it is the case how can I modify it to
launch the platform only on the startup of application and close it when
the application is powered off ?
Is the Birt engine shared by all application (war) on an application
server if we use
Or does it launch a specific engine instance ?
It seems that as soon as I call
engine.destroy();
>> in my specific war, there is something missing for the birt-viewer.
Blured.
Jason Weathersby a écrit :
> Moi,
> Jason
> moi wrote:
>> Hello,
>> Error :
>> rvlet.java:697)
>> rvlet.java:810)
>> reportName);
>> task.run();
>> task.close();
>> engine.destroy();
>> leaks.
>> Birt API and birt viewer on the same application server (jboss or
>> tomcat) ?
>> Regards,
>> Blured.
Re: Having birt.war & other application running on same application server [message #365048 is a reply to message #365042] Mon, 08 September 2008 11:44 Go to previous messageGo to next message
Moi,
Take a look at this example:
http://wiki.eclipse.org/Servlet_Example_%28BIRT%29_2.1
Jason
moi wrote:
> Hello,
> server if we use
> engine.destroy();
> Blured.
>> Moi,
>> to the location of the Platform directory for the webviewer and do not
>> use a PlatformServletContext. BTW Platform start up and shutdown
>> should only happen once for your app. It is very inefficient to start
>> and stop for every request. Also only destroy the engine on shutdown
>> of the app. Can you give some more detail on the memory leak?
>> Jason
>> moi wrote:
>>> Hello,
>>> API, I've got this error based on those steps :
>>> Error :
>>> rvlet.java:697)
>>> rvlet.java:810)
>>> reportName);
>>> task.run();
>>> task.close();
>>> engine.destroy();
>>> memory leaks.
>>> tomcat) ?
>>> Regards,
>>> Blured.
Re: Having birt.war & other application running on same application server [message #365053 is a reply to message #365048] Mon, 08 September 2008 12:49 Go to previous messageGo to next message
Thanks a lot for this servlet example.
So I can presume that the birt engine is not the same having this
servlet and birt-viewer on the same application server ?
The "Platform.startup(config)" applied to 2 servlets with the same
informations in config object will generate 2 runtime of birt platform
or will it use the same runtime ?
Blured.
> Moi,
> Jason
> moi wrote:
>> Hello,
>> when the application is powered off ?
>> server if we use
>> engine.destroy();
>> Regards,
>> Blured.
>>> Moi,
>>> not use a PlatformServletContext. BTW Platform start up and
>>> shutdown should only happen once for your app. It is very
>>> inefficient to start and stop for every request. Also only destroy
>>> the engine on shutdown of the app. Can you give some more detail on
>>> the memory leak?
>>> Jason
>>> moi wrote:
>>>> Hello,
>>>> Error :
>>>> rvlet.java:697)
>>>> rvlet.java:810)
>>>> reportName);
>>>> task.run();
>>>> task.close();
>>>> engine.destroy();
>>>> memory leaks.
>>>> tomcat) ?
>>>> Regards,
>>>> Blured.
Re: Having birt.war & other application running on same application server [message #365057 is a reply to message #365053] Mon, 08 September 2008 13:40 Go to previous message
Moi,
If you set the birt home to the same in both, and you startup just one
of them, the second one should be bale to use the static Platform class
to make calls including creating the report engine.
Jason
> Blured.
>> Moi,
>> Jason
>> moi wrote:
>>> Hello,
>>> time it is launched is'nt it ? If it is the case how can I modify it
>>> to launch the platform only on the startup of application and close
>>> it when the application is powered off ?
>>> server if we use
>>> engine.destroy();
>>> Regards,
>>> Blured.
>>>> Moi,
>>>> BIRT_HOME to the location of the Platform directory for the
>>>> webviewer and do not use a PlatformServletContext. BTW Platform
>>>> start up and shutdown should only happen once for your app. It is
>>>> very inefficient to start and stop for every request. Also only
>>>> destroy the engine on shutdown of the app. Can you give some more
>>>> Jason
>>>> moi wrote:
>>>>> Hello,
>>>>> Error :
>>>>> rvlet.java:697)
>>>>> rvlet.java:810)
>>>>> engConfig );
>>>>> reportName);
>>>>> task.run();
>>>>> task.close();
>>>>> engine.destroy();
>>>>> memory leaks.
>>>>> tomcat) ?
>>>>> Regards,
>>>>> Blured.
Previous Topic:Can not get entry named /DataEngine/NamingRelation because the archive file has,been closed. System
Next Topic:Error EMF when trying RE API + BirtViewer but not When accessing birt viewer first
Current Time: Wed Nov 05 23:26:19 EST 2025
Powered by FUDForum. Page generated in 0.08289 seconds
