Home » Archived » BIRT » Dynamic Page Width on Crosstab
Dynamic Page Width on Crosstab [message #364996] Thu, 04 September 2008 12:47 Go to next message
Is it possible to dynamically resize the page width of a crosstab report
based on a determination of the number of columns to be displayed?
I've experimented with setting the width property on
SimpleMasterPageHandle, but this only seems to work in the report
initialization event. Unfortunately the number of columns to be displayed
is unknown at that time.
Any help on this issue would be greatly appreciated.
Re: Dynamic Page Width on Crosstab [message #365020 is a reply to message #364996] Fri, 05 September 2008 11:14 Go to previous messageGo to next message
Doug,
I do not know of a way to do what you want, but you could set a page
break on every column in the cross tab. Select the column area in the
properties editor and then select page break, choose the dimension and
set page break after to always.
Jason
> displayed is unknown at that time.
> Thanks
Re: Dynamic Page Width on Crosstab [message #365032 is a reply to message #365020] Fri, 05 September 2008 20:40 Go to previous message
Jason,
Thanks. Will give that a shot.
Doug S.
Previous Topic:How to drop table while rendering takes place
Next Topic:How to use rptlibrary from a common folder for various reports
Current Time: Thu Nov 06 10:58:42 EST 2025
Powered by FUDForum. Page generated in 0.08590 seconds
