Home » Archived » BIRT » Report Document Error
Report Document Error [message #364816] Mon, 25 August 2008 04:08 Go to next message
i came accross a strange problem using BIRT 2.3.0.
I use the all-in-one.
For a specific report (whith a chart and a crosstab) i get an exception
from time to time (not reproducable, at least not for me).
The exception comes up if i use the report Viewer in a tomcat 5.5.25
Version.
Here's the exception:
org.eclipse.birt.data.engine.core.DataException: A report document error
occurred when getting the save stream.
Can not get entry named /DataEngine/NamingRelation because the archive
file has been closed. System ID: null
org.eclipse.birt.data.engine.api.DataEngineContext.getOutput Stream(DataEngineContext.java:292)
org.eclipse.birt.data.engine.impl.document.BaseSave.saveNami ngRelation(BaseSave.java:53)
org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelpe r.saveNamingRelation(ResultIterator.java:1115)
org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelpe r.access$2(ResultIterator.java:1112)
org.eclipse.birt.data.engine.impl.ResultIterator.saveNamingR elation(ResultIterator.java:892)
org.eclipse.birt.data.engine.impl.ResultIterator.close(Resul tIterator.java:846)
org.eclipse.birt.data.engine.impl.ResultIterator.finalize(Re sultIterator.java:874)
at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
at java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
at java.lang.ref.Finalizer.access$100(Finalizer.java:14)
at java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:1 60)
Caused by: java.io.IOException: Can not get entry named
/DataEngine/NamingRelation because the archive file has been closed.
System ID: null
org.eclipse.birt.core.archive.compound.ArchiveFile.getEntry( ArchiveFile.java:294)
org.eclipse.birt.core.archive.compound.ArchiveWriter.openRan domAccessStream(ArchiveWriter.java:63)
org.eclipse.birt.data.engine.api.DataEngineContext.getOutput Stream(DataEngineContext.java:283)
... 10 more
I already googled for the description but only found one post in this
newslist which dealt with the configuration of timezones.
I have two date-fields as report-parameters linked with
dataset-parameters, but nothing in relation to a timezone.
I already logged the viewer with the log level parameter 'ALL' but there
was no entry in the log-file giving me a hint.
Has anybody an idea where to look depending on the exception?
By the way, i rebuildt the report from scratch two times, but i couldn't
find the reason for the problem.
Appreciate any hint,
Andreas
Re: Report Document Error [message #364818 is a reply to message #364816] Mon, 25 August 2008 04:12 Go to previous messageGo to next message
Andreas wrote:
> Version.
> at
> at
> at
> at
> at
> at
> at
> System ID: null
> at
> at
> at
> ... 10 more
> Andreas
What i forgot to mention is, that the report runs correctly with correct
results .
Andreas
Re: Report Document Error [message #364845 is a reply to message #364818] Mon, 25 August 2008 19:21 Go to previous messageGo to next message
Andreas,
Can you log a bug for this?
Jason
Andreas wrote:
> Andreas wrote:
>> exception from time to time (not reproducable, at least not for me).
>> Version.
>> error occurred when getting the save stream.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> System ID: null
>> at
>> at
>> at
>> ... 10 more
>> there was no entry in the log-file giving me a hint.
>> couldn't find the reason for the problem.
>> Andreas
> results .
> Andreas
Re: Report Document Error [message #364859 is a reply to message #364845] Tue, 26 August 2008 04:15 Go to previous message
Logged a bug under
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245218
Andreas
Jason Weathersby wrote:
> Andreas,
> Jason
> Andreas wrote:
>> Andreas wrote:
>>> Hi,
>>> Version.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> System ID: null
>>> at
>>> at
>>> at
>>> ... 10 more
>>> Andreas
>> results .
>> Andreas
Previous Topic:problem in chart
Next Topic:Installation problem in birt 2.1.3
Current Time: Wed Aug 20 17:48:55 EDT 2025
Powered by FUDForum. Page generated in 0.03211 seconds
