Home » Archived » XML Schema Definition (XSD) » ClassCastException in XSDSchemaImpl
ClassCastException in XSDSchemaImpl [message #37282] |
Fri, 13 February 2004 21:20 |
Dennis Fuglsang Messages: 77 Registered: July 2009 |
Member |
Ed or Frank,
I encountered the following CCE when editing an XML schema model via the
editor
Get this ClassCaseException when node.getParentNode() returns a DocumentImpl
instance.
Thread [main] (Suspended (exception ClassCastException))
XSDSchemaImpl$5.handleEvent(Event) line: 2792
DocumentImpl.dispatchEvent(NodeImpl, Event) line: 749
DocumentImpl.insertedNode(NodeImpl, NodeImpl, boolean) line: 1056
ElementNSImpl(ParentNode).internalInsertBefore(Node, Node, boolean) line:
494
ElementNSImpl(ParentNode).insertBefore(Node, Node) line: 322
XSDSchemaImpl(XSDConcreteComponentImpl).forceNiceInsertBefor e(Node, Node,
Node) line: 1535
XSDSchemaImpl(XSDConcreteComponentImpl).niceInsertBefore(Nod e, Node, Node)
line: 1481
XSDSchemaImpl(XSDConcreteComponentImpl).handleElementForAdop t(EReference,
XSDConcreteComponent) line: 1334
XSDSchemaImpl(XSDConcreteComponentImpl).adoptContent(ERefere nce,
XSDConcreteComponent) line: 1362
XSDSchemaImpl.adoptContent(EReference, XSDConcreteComponent) line: 1725
XSDSchemaImpl(XSDConcreteComponentImpl).eNotify(Notification ) line: 1125
NotificationChainImpl.dispatch(Notification) line: 115
NotificationChainImpl.dispatch() line: 103
EObjectContainmentEList(NotifyingListImpl).addAllUnique(int, Collection)
line: 342
EObjectContainmentEList(BasicEList).addAll(int, Collection) line: 729
AddCommand.doExecute() line: 318
AddCommand(AbstractOverrideableCommand).execute() line: 132
CreateChildCommand(CommandWrapper).execute() line: 180
CreateChildCommand.execute() line: 250
BasicCommandStack.execute(Command) line: 93
CreateSiblingAction(StaticSelectionCommandAction).run() line: 227
CreateSiblingAction(Action).runWithEvent(Event) line: 842
Re: ClassCastException in XSDSchemaImpl [message #37316 is a reply to message #37282] |
Fri, 13 February 2004 22:05 |
What sample do I need to edit and what steps can I follow to reproduce this?
dfuglsang wrote:
> Ed or Frank,
> editor
> instance.
> 494
> Node) line: 1535
> line: 1481
> line: 342
Re: ClassCastException in XSDSchemaImpl [message #37349 is a reply to message #37316] |
Tue, 17 February 2004 16:44 |
Member |
Sorry. I attached the xsd that I was editing when I encountered the
problem. The steps to reproduce this are
(1) Open the xsd in the editor.
(2) Add a new child element under the root schema via the syntax tab in the
editor.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:402D4A31.F4DBF1AD@ca.ibm.com...
this?
> dfuglsang wrote:
> > Ed or Frank,
> > editor
DocumentImpl
> > instance.
line:
> > 494
Node,
> > Node) line: 1535
Node)
> > line: 1481
1125
Collection)
> > line: 342
Attachment: Books.xsd
(Size: 7.85KB, Downloaded 307 times)
Re: ClassCastException in XSDSchemaImpl [message #37383 is a reply to message #37349] |
Tue, 17 February 2004 17:24 |
I can't reproduce this. Should I expect to see this error in my
workspace/.metadata/.log after I try?
> editor.
> this?
> > dfuglsang wrote:
> > > Ed or Frank,
> > > editor
> DocumentImpl
> > > instance.
> line:
> > > 494
> Node,
> > > Node) line: 1535
> Node)
> > > line: 1481
> 1125
> Collection)
> > > line: 342
> Books.xsd Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
Re: ClassCastException in XSDSchemaImpl [message #37417 is a reply to message #37383] |
Wed, 18 February 2004 15:52 |
Member |
I do not know if the exception is logged but you will hit it when running
Eclipse in the debug mode with
a ClassCastException java exception breakpoint enabled (caught and
uncaught).
news:40324E66.C471C82E@ca.ibm.com...
the
> > editor.
> > this?
> > > dfuglsang wrote:
> > > > Ed or Frank,
the
> > > > editor
> > DocumentImpl
> > > > instance.
> > line:
> > > > 494
> > Node,
> > > > Node) line: 1535
Node,
> > Node)
> > > > line: 1481
1725
> > 1125
> > Collection)
> > > > line: 342
729
Re: ClassCastException in XSDSchemaImpl [message #37451 is a reply to message #37417] |
Wed, 18 February 2004 17:13 |
Okay, I'll try again. Does it show up in the .log for you?
> uncaught).
> the
> > > editor.
> > > this?
> > > > dfuglsang wrote:
> > > > > Ed or Frank,
> the
> > > > > editor
> > > DocumentImpl
> > > > > instance.
> > > line:
> > > > > 494
> > > Node,
> > > > > Node) line: 1535
> Node,
> > > Node)
> > > > > line: 1481
> 1725
> > > 1125
> > > Collection)
> > > > > line: 342
> 729
Re: ClassCastException in XSDSchemaImpl [message #37555 is a reply to message #37451] |
Mon, 01 March 2004 15:13 |
Member |
No. The runtime exception does not show up in the .log file. The exception
might be swallowed somewhere in the event processing framework.
news:40339D36.9F4E1A8D@ca.ibm.com...
running
> > uncaught).
in
> > the
> > > > editor.
reproduce
> > > > this?
> > > > > dfuglsang wrote:
> > > > > > Ed or Frank,
via
> > the
> > > > > > editor
> > > > DocumentImpl
> > > > > > instance.
1056
boolean)
> > > > line:
> > > > > > 494
> > > > Node,
> > > > > > Node) line: 1535
> > Node,
> > > > Node)
> > > > > > line: 1481
line:
> > 1725
line:
> > > > 1125
> > > > Collection)
> > > > > > line: 342
line:
> > 729
227
Re: ClassCastException in XSDSchemaImpl [message #37585 is a reply to message #37555] |
Mon, 01 March 2004 15:18 |
Sorry, I still haven't had time to look at this. It's probably best to open a
bugzilla defect to track this.
> running
> > > uncaught).
> in
> > > the
> > > > > editor.
> reproduce
> > > > > this?
> > > > > > dfuglsang wrote:
> > > > > > > Ed or Frank,
> via
> > > the
> > > > > > > editor
> > > > > DocumentImpl
> > > > > > > instance.
> 1056
> boolean)
> > > > > line:
> > > > > > > 494
> > > > > Node,
> > > > > > > Node) line: 1535
> > > Node,
> > > > > Node)
> > > > > > > line: 1481
> line:
> > > 1725
> line:
> > > > > 1125
> > > > > Collection)
> > > > > > > line: 342
> line:
> > > 729
> 227
Re: ClassCastException in XSDSchemaImpl [message #583481 is a reply to message #37282] |
Ed Merks Messages: 33142 Registered: July 2009 |
dfuglsang wrote:
> Ed or Frank,
> editor
> instance.
> 494
> Node) line: 1535
> line: 1481
> line: 342
Ed Merks
Re: ClassCastException in XSDSchemaImpl [message #583492 is a reply to message #37316] |
Member |
editor.
this?
> dfuglsang wrote:
> > Ed or Frank,
> > editor
DocumentImpl
> > instance.
line:
> > 494
Node,
> > Node) line: 1535
Node)
> > line: 1481
1125
Collection)
> > line: 342
(Size: 7.85KB, Downloaded 239 times)
Re: ClassCastException in XSDSchemaImpl [message #583507 is a reply to message #37349] |
> editor.
> this?
> > dfuglsang wrote:
> > > Ed or Frank,
> > > editor
> DocumentImpl
> > > instance.
> line:
> > > 494
> Node,
> > > Node) line: 1535
> Node)
> > > line: 1481
> 1125
> Collection)
> > > line: 342
Ed Merks
Re: ClassCastException in XSDSchemaImpl [message #583518 is a reply to message #37383] |
Member |
uncaught).
the
> > editor.
> > this?
> > > dfuglsang wrote:
> > > > Ed or Frank,
the
> > > > editor
> > DocumentImpl
> > > > instance.
> > line:
> > > > 494
> > Node,
> > > > Node) line: 1535
Node,
> > Node)
> > > > line: 1481
1725
> > 1125
> > Collection)
> > > > line: 342
729
Re: ClassCastException in XSDSchemaImpl [message #583528 is a reply to message #37417] |
> uncaught).
> the
> > > editor.
> > > this?
> > > > dfuglsang wrote:
> > > > > Ed or Frank,
> the
> > > > > editor
> > > DocumentImpl
> > > > > instance.
> > > line:
> > > > > 494
> > > Node,
> > > > > Node) line: 1535
> Node,
> > > Node)
> > > > > line: 1481
> 1725
> > > 1125
> > > Collection)
> > > > > line: 342
> 729
Ed Merks
Re: ClassCastException in XSDSchemaImpl [message #583577 is a reply to message #37451] |
Member |
running
> > uncaught).
in
> > the
> > > > editor.
reproduce
> > > > this?
> > > > > dfuglsang wrote:
> > > > > > Ed or Frank,
via
> > the
> > > > > > editor
> > > > DocumentImpl
> > > > > > instance.
1056
boolean)
> > > > line:
> > > > > > 494
> > > > Node,
> > > > > > Node) line: 1535
> > Node,
> > > > Node)
> > > > > > line: 1481
line:
> > 1725
line:
> > > > 1125
> > > > Collection)
> > > > > > line: 342
line:
> > 729
227
Re: ClassCastException in XSDSchemaImpl [message #583581 is a reply to message #37555] |
> running
> > > uncaught).
> in
> > > the
> > > > > editor.
> reproduce
> > > > > this?
> > > > > > dfuglsang wrote:
> > > > > > > Ed or Frank,
> via
> > > the
> > > > > > > editor
> > > > > DocumentImpl
> > > > > > > instance.
> 1056
> boolean)
> > > > > line:
> > > > > > > 494
> > > > > Node,
> > > > > > > Node) line: 1535
> > > Node,
> > > > > Node)
> > > > > > > line: 1481
> line:
> > > 1725
> line:
> > > > > 1125
> > > > > Collection)
> > > > > > > line: 342
> line:
> > > 729
> 227
Ed Merks
Current Time: Sat Apr 27 04:09:55 GMT 2024
Powered by FUDForum. Page generated in 0.04840 seconds
