Re: PDE Build fails on Linux with Java returned: 13 [message #37478 is a reply to message #37376] |
Fri, 12 December 2008 19:22 |
Originally posted by: nikolai.raitseb.gmail.com
Hi Andrew,
thank you for the answer.
In /home/nikolai/Programme/eclipse 3.4/configuration I see no .log file.
in configuration/config.ini the instance area is set to
osgi.instance.area.default=@user.home/workspace
if I look at ~/workspace/.metadata/.log I see following exception:
<begin>
!SESSION 2008-12-12 11:04:20.975
eclipse.buildId=M20080911-1700
java.version=1.6.0_10
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Framework arguments: -application org.eclipse.ant.core.antRunner
-buildfile /home/nikolai/Programme/eclipse
3.4/plugins/org.eclipse.pde.build_3.4.1.R34x_v20080805/scrip ts/build.xml
-Dbuilder=/home/nikolai/Projekte/JTerms/SVN_Assembla/TRUNK/P DEBuilder/scripts
-init
Command-line arguments: -application org.eclipse.ant.core.antRunner
-init -clean
!ENTRY org.eclipse.osgi 4 0 2008-12-12 11:04:29.879
!MESSAGE Application error
!STACK 1
at
at
Caused by: java.lang.IllegalArgumentException
at java.net.URI.create(URI.java:842)
Caused by: java.net.URISyntaxException: Illegal character in path at
index 36: file:/home/nikolai/Programme/eclipse
3.4/plugins/org.apache.ant_1.7.0.v200803061910/lib/ant.jar
at java.net.URI$Parser.fail(URI.java:2809)
at java.net.URI$Parser.checkChars(URI.java:2982)
<end>
maybe its have problems with blank in "eclipse 3.4"? I'm try it to
rename or to copy my eclipse instance with names without blanks..
Nikolai
Andrew Niefer schrieb:
> Exit code 13 means there was a problem starting eclipse, it never got as
> far as running your build.
> Try looking under
> for a .log file that would have some detail about what went wrong.
> -Andrew
> Nikolai Raitsev wrote:
>> Hello,
>> I'm trying to run my PDEBuilder on Linux. The PDEBuilder works fine on
>> Windows XP and Eclipse 3.4. I call PDEBuilder with following ant-Task:
>> <target name="build" description="Build Eclipse Product">
>> <java jar="${eclipse.launcher}"
>> fork="true"
>> failonerror="true"
>> <arg line="-application ${eclipse.antRunner} "/>
>> <arg line="-buildfile ${pde.buildfile} "/>
>> <arg line="-Dbuilder=${pde.builder.scripts} "/>
>> </java> </target>
>> And I get this with -verbose option:
>> build:
>> [echo] eclipse.launcher /home/nikolai/Programme/eclipse
>> 3.4/plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080 819.jar
>> [echo] -application org.eclipse.ant.core.antRunner
>> [echo] -buildfile "/home/nikolai/Programme/eclipse
>> 3.4/plugins/org.eclipse.pde.build_3.4.1.R34x_v20080805/scrip ts/build.xml "
>> [echo] -Dbuilder
>> " /home/nikolai/Projekte/JTerms/SVN_Assembla/TRUNK/PDEBuilder/ scripts "
>> [java] Executing '/usr/lib/jvm/java-6-sun-1.6.0.10/jre/bin/java'
>> with arguments:
>> [java] '-jar'
>> [java] '/home/nikolai/Programme/eclipse
>> 3.4/plugins/org.eclipse.equinox.launcher_1.0.101.R34x_v20080 819.jar'
>> [java] '-application'
>> [java] 'org.eclipse.ant.core.antRunner'
>> [java] '-buildfile'
>> 3.4/plugins/org.eclipse.pde.build_3.4.1.R34x_v20080805/scrip ts/build.xml'
>> [java]
>> '-Dbuilder=/home/nikolai/Projekte/JTerms/SVN_Assembla/TRUNK/ PDEBuilder/scripts'
>> [java] '-init'
>> [java] '-clean'
>> [java] [java] The ' characters around the executable and
>> arguments are
>> [java] not part of the command.
>> Execute:Java13CommandLauncher: Executing
>> '/usr/lib/jvm/java-6-sun-1.6.0.10/jre/bin/java' with arguments:
>> '-jar'
>> '-application'
>> '-buildfile'
>> '-init'
>> '-clean'
>> The ' characters around the executable and arguments are
>> BUILD FAILED
>> /home/nikolai/Projekte/JTerms/SVN_Assembla/TRUNK/PDEBuilder/ scripts/build.xml:40:
>> Java returned: 13
>> at org.apache.tools.ant.taskdefs.Java.execute(Java.java:108)
>> at
>> org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at java.lang.reflect.Method.invoke(Method.java:597)
>> at
>> org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
>> at org.apache.tools.ant.Task.perform(Task.java:348)
>> at org.apache.tools.ant.Target.execute(Target.java:357)
>> at org.apache.tools.ant.Target.performTasks(Target.java:385)
>> at
>> org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
>> at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
>> at
>> org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
>> at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
>> at org.apache.tools.ant.Main.runBuild(Main.java:758)
>> at org.apache.tools.ant.Main.startAnt(Main.java:217)
>> at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
>> at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
>> whats going wrong here?
>> Many thanks for any help.
>> Best regards,
>> Nikolai
FUDForum. Page generated in 0.04667 seconds
