Home » Archived » BIRT » Trying to use REAPI: Report engine can not create HTML emitter
Trying to use REAPI: Report engine can not create HTML emitter [message #363730] |
Mon, 07 July 2008 19:59 |
Originally posted by: Rich.Court.gmail.com
Hi-
I'm attempting to run a report from a java application using the Report
Engine API. I've looked over the examples and some of the messages
posted here, and believe I am correctly calling the code.
However, I am receiving the error "Jul 7, 2008 3:45:46 PM
org.eclipse.birt.report.engine.api.impl.EngineTask createContentEmitter
SEVERE: Report engine can not create HTML emitter." so I am doing
something wrong.
I'm wondering if someone could point me to a checklist of standard
things I should be checking?
[When I trace this using the debugger, the failure seems to be caused by
a null return value when I am testing whether the emitter is an instance
of IContentEmitter...]
-Rich
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363731 is a reply to message #363730] |
Mon, 07 July 2008 20:18 |
I seem to be missing a required library.
Could someone point me to what is supposed to be installed where?
-R
Rich Court wrote:
> Hi-
> something wrong.
> -Rich
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363734 is a reply to message #363731] |
Mon, 07 July 2008 23:09 |
Originally posted by: jasonweathersby.alltel.net
Rich,
Are you using the runtime download? Are you setting BIRT_HOME correctly?
Jason
> -R
> Rich Court wrote:
>> Hi-
>> Report Engine API. I've looked over the examples and some of the
>> messages posted here, and believe I am correctly calling the code.
>> something wrong.
>> by a null return value when I am testing whether the emitter is an
>> instance of IContentEmitter...]
>> Thanks,
>> -Rich
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363764 is a reply to message #363734] |
Tue, 08 July 2008 14:31 |
Yes, I'm using the runtime download. I believe I am setting BIRT_HOME
correctly. The application seems to correctly startup the platform,
opens the .rptdesign file and successfully retrieves info from that. I
seem to be unsuccessful at executing a task.run() call.
Here's the source that I am attempting to use:
public class BIRTStandaloneTest {
private String BIRT_HOME =
" C:\\birt_2.3_final_runtime\\birt-runtime-2_3_0\\ReportEngine ";
private String REPORT_DESIGN_FILE =
"C:\\temp\\reports\\Demo_DB_with_Chart_2.3.rptdesign";
private String OUTPUT_FILE_LOCATION_RENDER =
"C:\\temp\\output\\myTestOutputRender_2.3.html";
private String OUTPUT_FILE_LOCATION_RUN_RENDER =
"C:\\temp\\output\\myTestOutputRunRender_2.3.html";
private IReportEngine engine;
public BIRTStandaloneTest( )
String designName = "Demo_DB_with_Chart_2.3.rptdesign";
designName = REPORT_DESIGN_FILE;
IReportEngine engine = null;
EngineConfig config = null;
config = new EngineConfig();
config.setBIRTHome(BIRT_HOME);
config.setLogConfig("C:\\temp\\output\\birt_2_3_final\\logs ", Level.ALL);
try {
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory)
Platform.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY);
engine = factory.createReportEngine(config);
engine.changeLogLevel(Level.ALL);
} catch (Exception e) {
e.printStackTrace();
IReportRunnable design = null;
try {
design = engine.openReportDesign(designName);
} catch (EngineException e) {
System.err.println("Design " + designName + " not found");
tearDown();
System.exit(-1);
System.out.println("Opened .rptdesign file " + designName + "
correctly.");
// Just check something in the file to make sure we opened it
correctly, and can correctly fetch fields.
String author = (String) design.getProperty(IReportRunnable.AUTHOR);
System.out.println("Design author fetch = " + author);
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
RenderOption renderOption = new RenderOption();
renderOption.setOutputFormat("HTML");
renderOption.setOutputFileName(this.OUTPUT_FILE_LOCATION_RUN _RENDER);
// Set the context
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory("image");
renderContext.setSupportedImageFormats("JPG;PNG;BMP;SVG");
//apply rendering context to the task
HashMap appContext = new HashMap();
appContext.put(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T,
renderContext);
task.setAppContext(appContext);
renderOption.setOutputStream(System.out);
task.setRenderOption(renderOption);
//task.validateParameters();
try {
long beginTime = System.currentTimeMillis();
task.run();
long endTime = System.currentTimeMillis();
long timeSpan = endTime - beginTime;
System.out.println("Report Runtime: " + timeSpan);
} catch (EngineException ee) {
ee.printStackTrace();
task.close();
tearDown();
public void tearDown() {
engine.shutdown();
Platform.shutdown();
new BIRTStandaloneTest();
System.out.println("HTML should have been generated.");
Thanks for any / all advice.
-Rich
Jason Weathersby wrote:
> Rich,
> Jason
>> Thanks,
>> -R
>> Rich Court wrote:
>>> Hi-
>>> something wrong.
>>> Thanks,
>>> -Rich
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363769 is a reply to message #363764] |
Tue, 08 July 2008 16:05 |
Rich,
Try replacing this code:
> // Set the context
> renderContext);
With:
HTMLRenderOption options = New HTMLRenderOption();
options.setOutputFileName(this.OUTPUT_FILE_LOCATION_RUN_REND ER);
options.setOutputFormat("html");
//options.setHtmlRtLFlag(false);
options.setEmbeddable(true);
//options.setImageDirectory("C:\\test\\images");
//PDFRenderOption options = new PDFRenderOption();
//options.setOutputFileName("c:/temp/test.pdf");
//options.setOutputFormat("pdf");
task.setRenderOption(options);
Do not use the RenderContext class.
Jason
> try {
> try {
> tearDown();
> System.exit(-1);
> correctly.");
> // Set the context
> renderContext);
> try {
> task.run();
> task.close();
> tearDown();
> engine.shutdown();
> public static void main(String[] args) {
> -Rich
>> Rich,
>> Jason
>>> Thanks,
>>> -R
>>> Rich Court wrote:
>>>> Hi-
>>>> something wrong.
>>>> caused by a null return value when I am testing whether the emitter
>>>> is an instance of IContentEmitter...]
>>>> Thanks,
>>>> -Rich
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363787 is a reply to message #363769] |
Tue, 08 July 2008 18:04 |
First off, thank you for your time and your help.
I still receive the same error even when I take out all the
RenderContext references.
I did try changing the code from an HTMLRenderOption to a
PDFRenderOption using the code you provided that was commented out. In
that case, I get a Report engine fails to initialize pdf emitter rather
than an html emitter.
With the stack trace:
SEVERE: Report engine can not create pdf emitter.
org.eclipse.birt.report.engine.api.EngineException: Report engine fails
to initialize pdf emitter, please make sure required libraries for this
emitter are installed.
at
org.eclipse.birt.report.engine.api.impl.EngineTask.createCon tentEmitter(EngineTask.java:1176)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:94)
at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:72)
at
net.mirrorimage.cc.birt.standalone.BIRTStandaloneTest.<init >(BIRTStandaloneTest.java:141)
at
net.mirrorimage.cc.birt.standalone.BIRTStandaloneTest.main(B IRTStandaloneTest.java:159)
pointing to the fact that the call to the extManager.createEmitter seems
to be coming back null in both cases could there be a configuration
issue that I am missing? Is there a good way to debug my environment?
The fact that I am getting past the loading and parsing of the
..rptdesign file -- does that imply anything about the status of my
libraries and plugins?
Thanks again for any information,
-Rich
> Rich,
> > // Set the context
> > renderContext);
> With:
> Jason
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363792 is a reply to message #363787] |
Tue, 08 July 2008 18:51 |
Rich,
I assume the org.eclipse.report.engine.emitter.pdf plugin is in your
BIRT_HOME/plugins directory? Did you add all the ReportEngine/lib jars
to your classpath?
Jason
> at
> at
> at
> at
> at
> -Rich
> > Rich,
> > > // Set the context
> > > renderContext);
> > With:
> > Jason
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363799 is a reply to message #363792] |
Tue, 08 July 2008 21:31 |
Yes, I just double checked and I do have the
org.eclipse.birt.report.engine.emitter.pdf_2.3.0.v20080606.j ar in my
ReportEngine\plugins directory. [The html library is in there also.]
I also have the ReportEngine/lib/*.jar files (21 of them) in my classpath.
I did notice a bit of a disconnect between the setting of BIRT_HOME in
the genReport.bat versus what is expected in the source code.
In the source code, one uses the setBIRTHome method on an EngineConfig
to set the home to a path including the 'ReportEngine' suffix; whereas
in the genReport.bat script it expects the directory one up from the
'ReportEngine' as its home. I assume I am correct on this, as when I
try to setBIRTHome with the 'ReportEngine' suffix in the code, I get a
'Cant startup the OSGI framework.'
I believe that the issue is with something either in the source code,
which at this point is fairly short and simple, or my eclipse
environment; as when I set a shell environment variable of BIRT_HOME to
the same location (without the ReportEngine path) and run the included
genReport.bat script on my test report, it correctly generates both
..html and .pdf output; so the issue is not with the report.
Any other suggestions as to what to look for?
Thanks again,
-Rich
> Rich,
> to your classpath?
> Jason
>> In that case, I get a Report engine fails to initialize pdf emitter
>> rather than an html emitter.
>> fails to initialize pdf emitter, please make sure required libraries
>> for this emitter are installed.
>> at
>> at
>> at
>> at
>> at
>> seems to be coming back null in both cases could there be a
>> configuration issue that I am missing? Is there a good way to debug
>> my environment? The fact that I am getting past the loading and
>> parsing of the .rptdesign file -- does that imply anything about the
>> status of my libraries and plugins?
>> -Rich
>> > Rich,
>> > > // Set the context
>> > > renderContext);
>> > With:
>> > Jason
Re: Trying to use REAPI: Report engine can not create HTML emitter [message #363837 is a reply to message #363799] |
Wed, 09 July 2008 15:32 |
Rich,
If you set the log level to FINEST, are you getting a more detailed
error in the log file?
Jason
> Thanks again,
> -Rich
>> Rich,
>> jars to your classpath?
>> Jason
>>> at
>>> at
>>> at
>>> at
>>> at
>>> -Rich
>>> > Rich,
>>> > > // Set the context
>>> > > renderContext);
>>> > With:
>>> > Jason
Current Time: Fri Apr 26 17:23:37 GMT 2024
Powered by FUDForum. Page generated in 0.03766 seconds
