Re: http 401 error (xml data source) with viewer deployed in tomcat [message #363469 is a reply to message #363468] |
Wed, 25 June 2008 02:55 |
Originally posted by: keitha.spam.gmail.com
Hi Tianli
I created a data source using the url which you supplied. (I tried 'Test
Connection') and got the message 'Ping succeeded'.
However when I tried to create a data set using this data source I got the
following error:
XML data source cannot be retrieved. XML data source is invalid or the
file doesn't exist.
Details:
org.eclipse.datatools.connectivity.oda.OdaException: XML data source
cannot be retrieved.XML data source file is invalid or the file doesn't
exist.
at
org.eclipse.datatools.enablement.oda.xml.ui.wizards.XPathCho osePage.populateXMLTree(XPathChoosePage.java:320)
at
org.eclipse.datatools.enablement.oda.xml.ui.wizards.XPathCho osePage.createPageCustomControl(XPathChoosePage.java:98)
at
org.eclipse.datatools.connectivity.oda.design.ui.wizards.Dat aSetWizardPage.createControl(DataSetWizardPage.java:123)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:170)
at
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:669)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:1083)
at
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1142)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1139)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1128)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1126)
at
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:820)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1002)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3821)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3420)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at
org.eclipse.birt.report.designer.ui.actions.NewDataSetAction .createNewDataSet(NewDataSetAction.java:185)
at
org.eclipse.birt.report.designer.ui.actions.NewDataSetAction .run(NewDataSetAction.java:170)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
at
org.eclipse.birt.report.designer.ui.rcp.DesignerApplication. run(DesignerApplication.java:38)
at
org.eclipse.equinox.internal.app.EclipseAppContainer.callMet hodWithException(EclipseAppContainer.java:574)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:195)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
I know the structure of the XML file you gave me is OK as I also saved a
local copy to run the test and that worked fine.
So I am not actually able to run the test you asked me to check.
Keith
Tianli wrote:
> Hi Keith
> I got the same issue, it works in designer bug failed in deployment
> please try this xml url which I used:
> https://bugs.eclipse.org/bugs/attachment.cgi?id=79863
> If you can reproduce it by this url it should be a bug. Please log a bug
> on bugzilla
> Thanks
> Tianli
Re: http 401 error (xml data source) with viewer deployed in tomcat [message #363506 is a reply to message #363469] |
Wed, 25 June 2008 22:25 |
I retried the test you asked me to do at home and it worked perfectly.
I used https://bugs.eclipse.org/bugs/attachment.cgi?id=79863 as the URL
for my datasource, created a report in RCP designer, deploy to tomcat and
it worked fine.
I think maybe my original problem is that IIS is serving the XML and maybe
it is needing some credentials? I will see if I can retest by using the
URL in firefox later.
But even if it is an IIS problem the fact still remains that everything is
working fine in in the designer, it is only deploying to the birt viewer
in tomcat that is giving me the problem.
Any suggestions still gratefully received.
Keith
keitha wrote:
> Hi Tianli
> following error:
> file doesn't exist.
> Details:
> exist.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Keith
> Tianli wrote:
>> Hi Keith
>> on bugzilla
>> Thanks
>> Tianli
Re: http 401 error (xml data source) with viewer deployed in tomcat [message #363509 is a reply to message #363506] |
Thu, 26 June 2008 00:44 |
OK, I found a workaround.
To start tomcat I run tomcat5.exe from the command line (instead of
running as a service where it is running as user SYSTEM). Once tomcat is
running as me the birt report displays just fine.
> it worked fine.
> Keith
> keitha wrote:
>> Hi Tianli
>> following error:
>> file doesn't exist.
>> Details:
>> exist.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks
>> Keith
>> Tianli wrote:
>>> Hi Keith
>>> on bugzilla
>>> Thanks
>>> Tianli
FUDForum. Page generated in 0.03819 seconds
