Reports are not rendered in Firefox 3? [message #363373] |
Thu, 19 June 2008 20:49 |
Originally posted by: kasper.eobjects.dk
Hi BIRT people
I'm the developer of a portlet for browsing BIRT reports and recently I've
experienced that the reports in my showcase portal
(http://www.eobjects.dk/portal/) are not renderable in my browser (Firefox
3, ubuntu hardy version). I've tested the reports in IE and they work fine
(or with expected errors at least) there. Here's a really simple report,
which is shown correctly in IE, but just as a blank report in Firefox:
http://www.eobjects.dk/birt/frameset?__report=/opt/reports/F oobar.rptdesign
I've tried updating the birt runtime to the latest RC but no luck. I've
also tried searching bugzilla for a report on this, but found none?
Other than that - thanks for the best Open Source report engine around! :)
Re: Reports are not rendered in Firefox 3? [message #363377 is a reply to message #363373] |
Fri, 20 June 2008 02:31 |
Originally posted by: mdavis.pashllc.com
FYI, when I used the link you provided, the report rendered for me in
FF 3. I'm on Windows XP.
I got the following:
Foobar
This is a test of birt 2.3.
Jun 20, 2008 3:30 AM
- Malcolm
Kasper Sørensen wrote:
> Hi BIRT people
> I've experienced that the reports in my showcase portal
> (Firefox 3, ubuntu hardy version). I've tested the reports in IE and
> they work fine (or with expected errors at least) there. Here's a really
> simple report, which is shown correctly in IE, but just as a blank
> report in Firefox:
Re: Reports are not rendered in Firefox 3? [message #363411 is a reply to message #363380] |
Fri, 20 June 2008 19:15 |
Kasper,
What version of BIRT are you using RC4?
Jason
Kasper Soerensen wrote:
> Yes I had the same "Version Mismatch" exception popping up - then I
> upgraded to the latest RC of BIRT 2.3 and the exception was not shown,
> but neither was the report rendered.
Re: Reports are not rendered in Firefox 3? [message #363420 is a reply to message #363377] |
Sat, 21 June 2008 04:27 |
Originally posted by: brian.kuhn.urukhairemovethispart.org
Likewise, I was able to view the report in FF3 on a Mac (OS X Tiger).
--brian
malcolm davis wrote:
> FYI, when I used the link you provided, the report rendered for me in FF
> Foobar
> - Malcolm
>> Hi BIRT people
>> really simple report, which is shown correctly in IE, but just as a
>> I've also tried searching bugzilla for a report on this, but found none?
>> around! :)
Re: Reports are not rendered in Firefox 3? [message #363426 is a reply to message #363373] |
Sat, 21 June 2008 19:06 |
OK now this is very weird. Suddenly the reports are rendered as they
should. I have no idea what sparked this since I did not change anything
on the server. The server restarted earlier today - maybe that caused
something?
Re: Reports are not rendered in Firefox 3? [message #363427 is a reply to message #363426] |
Sat, 21 June 2008 19:21 |
Could have been a classpath conflict issue. This is common when the
system restarts and everything suddenly starts working. You may want
to look at your environment, web server, and project classpath. [BTW:
keeping the environment classpath empty helps avoid these problems.]
> something?
FUDForum. Page generated in 0.03717 seconds
