Home » Archived » BIRT » Change visibility of series programmatically
Change visibility of series programmatically [message #362366] Fri, 09 May 2008 06:40 Go to next message
Hallo!
How can I hide the siries per Scripting?
Following script don't work:
function beforeRendering(gcs, icsc)
icsc.getChartInstance().getAxes().get(0).getSeriesDefinition s().get(1).setVisible(false);
Were can I read about Chart object model? Axes, Series, SeriesDefinitions
etc.
Re: Change visibility of series programmatically [message #362384 is a reply to message #362366] Fri, 09 May 2008 12:40 Go to previous messageGo to next message
Andre,
You can do it the beforedrawseries like:
function beforeDrawSeries(series, isr, icsc)
if( series.getSeriesIdentifier() == "seriestwo" ){
series.setVisible(false);
}else{
series.setVisible(true);
Jason
Andre Dubrovsky wrote:
> Hallo!
> SeriesDefinitions etc.
Re: Change visibility of series programmatically [message #362619 is a reply to message #362384] Mon, 19 May 2008 12:52 Go to previous messageGo to next message
Thans for your help, Jason.
But if I combine your solution with legend, this produce corrupted chart.
If I hide "seriesone" the legend show even "seriesone" and not "seriestwo"
as expected.
Bug?
What can I use as workaround for this?
My BIRT version is 2.2.2 (stable)
Jason Weathersby wrote:
> Andre,
> }else{
> Jason
>> Hallo!
Re: Change visibility of series programmatically [message #362625 is a reply to message #362619] Mon, 19 May 2008 15:28 Go to previous message
Andre,
It may be good to log this as a bug.
As a work around do this in the beforeGeneration
function beforeGeneration(chart, icsc)
importPackage( Packages.org.eclipse.birt.chart.model.attribute );
xAxis = chart.getBaseAxes()[0];
yAxis = chart.getOrthogonalAxes( xAxis, true)[0]
//use 0 in the following for the first series and 1
//for the second series
seriesDef = yAxis.getSeriesDefinitions().get(0)
runSeries = seriesDef.getRunTimeSeries();
firstRunSeries = runSeries.get(0);
firstRunSeries.setVisible(false);
Jason
> "seriestwo" as expected.
> Bug?
>> Andre,
>> }else{
>> Jason
>>> Hallo!
Previous Topic:How to have toc items indented ?
Next Topic:experienced developers ask dummy questions too : resolve oneToMany
Current Time: Sun Oct 26 09:20:48 EDT 2025
Powered by FUDForum. Page generated in 0.03893 seconds
