Home » Archived » BIRT » How to pass a connection to viewerServlet
How to pass a connection to viewerServlet [message #362094] Tue, 29 April 2008 23:11 Go to next message
Originally posted by: arunpjohny.aol.com
I'm using org.eclipse.birt.report.servlet.ViewerServlet to generate my
reports.
My problem is I've to pass a connection object to the BIRT Engine at
runtime.
I've written a extension point to set the connection object. But it
seems that the new connection is working, instead the birt report is
using the default connection object for fetching parameter values.
Here is my code.
web.xml
<servlet>
<servlet-name>ViewerServlet</servlet-name>
<servlet-class>org.eclipse.birt.report.servlet.ViewerServlet </servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/frameset</url-pattern>
</servlet-mapping>
Redirecting to /frameset
private void doReport(ServletRequest request, ServletResponse response,
String reportName)throws ServletException, IOException {
Connection conn = DataSourceUtils.getConnection(dataSource);
String paramString = getParameterString(request);
try {
request.setAttribute("AppContextKey",
"org.eclipse.birt.report.data.oda.subjdbc.SubOdaJdbcDriver");
request.setAttribute("AppContextValue", conn);
request.getRequestDispatcher("/frameset?__report=" + reportName +
paramString).forward(request, response);
} finally {
try {
DataSourceUtils.doReleaseConnection(conn, dataSource);
} catch (SQLException e) {
e.printStackTrace();
My extension
public class SpringOdaJdbcDriver extends OdaJdbcDriver {
private Connection passedInConnection;
public void setAppContext(Object context) throws OdaException {
HashMap ctx = (HashMap) context;
passedInConnection = (java.sql.Connection) ctx
.get("org.eclipse.birt.report.data.oda.subjdbc.SubOdaJdbcDriver ");
public IConnection getConnection(String connectionClassName)
if (passedInConnection != null) {
return new appContextDBConnection();
} else {
return new org.eclipse.birt.report.data.oda.jdbc.Connection();
private class appContextDBConnection extends
org.eclipse.birt.report.data.oda.jdbc.Connection {
public void open(Properties connProperties) throws OdaException {
super.jdbcConn = passedInConnection;
public void close() throws OdaException {
if (jdbcConn == null) {
return;
jdbcConn = null;
plugin.xml
<?eclipse version="3.2"?>
<plugin>
<extension
id="org.eclipse.birt.report.data.springjdbc"
point=" org.eclipse.datatools.connectivity.oda.consumer.driverBridge ">
<bridge
driverType="org.eclipse.birt.report.data.oda.jdbc.OdaJdbcDriver "
bridgeId="org.eclipse.birt.report.data.springjdbc">
</bridge>
</extension>
<extension
point="org.eclipse.datatools.connectivity.oda.dataSource">
<dataSource
odaVersion="3.0"
driverClass="org.eclipse.birt.report.data.springjdbc.SpringOdaJdbcDriver "
defaultDisplayName="Spring Jdbc Driver Bridge"
setThreadContextClassLoader="false"
id="org.eclipse.birt.report.data.springjdbc"/>
</extension>
</plugin>
Can anyone tell me what is wrong in my configuration.
I'm using BIRT 2.3M6
Thank you
Re: How to pass a connection to viewerServlet [message #362112 is a reply to message #362094] Wed, 30 April 2008 11:43 Go to previous message
Arun,
I just logged a bug for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=229649
It appears the appcontext is not being pushed prior to getting parameter
information. Take a look at the last couple of comments on this page:
http://birtworld.blogspot.com/2005/10/birt-examples.html
for a modification you can make to the viewer code to get it working.
Also can you verify that your connection is working for a report that
contains no parameters?
Jason
Arun P Johny wrote:
> reports.
> runtime.
> Here is my code.
> web.xml
> <servlet>
> </servlet>
> <servlet-mapping>
> </servlet-mapping>
> try {
> } finally {
> try {
> My extension
> } else {
> return;
> jdbcConn = null;
> plugin.xml
> <plugin>
> <extension
> <bridge
> </bridge>
> </extension>
> <extension
> <dataSource
> odaVersion="3.0"
> </extension>
> </plugin>
> Thank you
Previous Topic:Birt inside web start app
Next Topic:Birt 2.1.3 Viewer Fails with ClassNotFoundException when attempting to use a ScriptedDataSet that ac
Current Time: Mon Nov 03 10:31:34 EST 2025
Powered by FUDForum. Page generated in 0.02837 seconds
