Home » Archived » BIRT » define a cascading parameter in a library
define a cascading parameter in a library [message #361621] Wed, 09 April 2008 01:36 Go to next message
Originally posted by: orinakar.inter.net.il
I defined a cascading parameter inside a library (because I want to use it
in several reports) but coudn't drag it from the library to other reports.
Is there a way to do it?
Ori
Re: define a cascading parameter in a library [message #361637 is a reply to message #361621] Wed, 09 April 2008 12:36 Go to previous messageGo to next message
Ori,
After creating the cascaded parameter in the library, publish it to the
resource folder. Then create the new report, and open the library view.
It is best to move the library view to the same pane as the outline
view . This will allow you to drag the parameter from the library view
to the Data Explorer view where parameters for the new report are created.
Jason
Ori wrote:
> Hello,
> Ori
Re: define a cascading parameter in a library [message #361658 is a reply to message #361637] Thu, 10 April 2008 03:13 Go to previous messageGo to next message
Sorry but I need more instructions - how do I publish a parameter to the
resource folder?
Thanks.
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:ftir31$nr7$1@build.eclipse.org...
> Ori,
> It is best to move the library view to the same pane as the outline view .
> This will allow you to drag the parameter from the library view to the
> Jason
> Ori wrote:
>> Hello,
>> it in several reports) but coudn't drag it from the library to other
>> reports.
>> Thanks,
>> Ori
Re: define a cascading parameter in a library [message #361660 is a reply to message #361637] Thu, 10 April 2008 04:07 Go to previous message
I managed to do it without the publish operation, I just moved the panel and
dragged from the library to the data explorer
> Ori,
> Jason
> Ori wrote:
>> Hello,
>> reports.
>> Thanks,
>> Ori
Previous Topic:Acessing the reportDocument Name from a Java event handler
Next Topic:Read / Parse Excel generated by BIRT
Current Time: Mon Nov 03 04:19:14 EST 2025
Powered by FUDForum. Page generated in 0.03941 seconds
