Using locale in BIRT API [message #360814] |
Mon, 25 February 2008 07:10 |
Originally posted by: beret25.rediffmail.com
I am trying generate reports in different Locale using BIRT. I suppose I
am missing on a very small thing for using I am not getting the required
report in specific locale. The code I have written is below, could someone
help me out in where I am making a silly mistake.
// Set IRenderOption
PDFRenderOption renderOptions = new PDFRenderOption();
renderOptions.setBaseURL("UTF-8");
renderOptions.setOutputFormat("pdf");
renderOptions.setOutputFileName(getOutputFile().getAbsoluteP ath());
renderOptions.setOption(PDFRenderOption.LOCALE, new
Locale("ar"));
renderOptions.setOption(HTMLRenderOption.URL_ENCODING,
"UTF-8");
renderOptions.setOption(PDFRenderOption.BASE_URL, "UTF-8");
renderOptions.setEmbededFont(true);
// pdfRenderOptions.set
IRunAndRenderTask task;
task = birtReportEngine.createRunAndRenderTask(design);
task.setRenderOption(renderOptions);
task.setLocale(new Locale("ar"));
String [] abc = Locale.getISOLanguages();
task.addScriptableJavaObject("data", data);
task.run();
I have added the following in my .rptdesign
<property name=\"includeResource\">Report0019</property>"
which indicates the default properties file and will add _ar for arabic or
_ru for russian.
I also have the following
<label>
<text-property name="text"
key="rpt.criteria.label.expiryduedays"></text-property>
</label>
Still i dont get the PDF in the locale specified, but when i see it from
BIRT designer I see the required PDF and if I generate a HTML for the same
API with the output format as HTML I also get the required output.
Could someone Help me out
Its very urgent
Thanks in advance
Arijit
Re: Using locale in BIRT API [message #360816 is a reply to message #360814] |
Mon, 25 February 2008 08:58 |
The properties file was in UNICODE when i tried in BIRT designer but while
trying it in API I tried with unicode as well as in the specific language
FUDForum. Page generated in 0.03380 seconds
