nullException [message #36866] |
Fri, 30 January 2004 12:47 |
Originally posted by: niemaz.xrce.xerox.com
I'm getting a nullException exception when loading a particular schema
file.
After investigating, it appears that it crashes on restricted enumerations
based on xs:positiveInteger. See xsd code below.
--mike
<xs:attribute name="layer">
<xs:simpleType>
<xs:restriction base="xs:string">
<xs:enumeration value="1"/>
<xs:enumeration value="2"/>
<xs:enumeration value="3"/>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:element name="root">
<xs:complexType>
<xs:attribute ref="layer"/>
</xs:complexType>
</xs:element>
Re: nullException [message #36934 is a reply to message #36866] |
Fri, 30 January 2004 13:34 |
--------------E7DFBC8757621574A8A5840F
Content-Type: text/plain; charset=us-ascii
Mike,
Your example doesn't use positiveInteger and even if I change it and build a
complete schema like this:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:simpleType>
<xs:restriction base="xs:positiveInteger">
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:complexType>
</xs:complexType>
</xs:element>
</xs:schema>
I can't reprodue a null pointer exception.
> file.
> --mike
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> <xs:complexType>
> </xs:complexType>
> </xs:element>
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Mike,
<p>Your example doesn't use positiveInteger and even if I change it and
build a complete schema like this:
<blockquote><?xml version="1.0" encoding="UTF-8"?>
<br><xs:schema xmlns:xs="<A HREF="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</A>">
<br><xs:attribute name="layer">
<br> <xs:simpleType>
<br> <xs:restriction base="xs:positiveInteger">
<br> <xs:enumeration value="1"/>
<br> <xs:enumeration value="2"/>
<br> <xs:enumeration value="3"/>
<br> </xs:restriction>
<br> </xs:simpleType>
<br></xs:attribute>
<p><xs:element name="root">
<br> <xs:complexType>
<br> <xs:attribute ref="layer"/>
<br> </xs:complexType>
<br></xs:element>
<br></xs:schema></blockquote>
<br>
<p>mike wrote:
<blockquote TYPE=CITE>I'm getting a nullException exception when loading
a particular schema
<br>file.
<br>After investigating, it appears that it crashes on restricted enumerations
<br>based on xs:positiveInteger. See xsd code below.
<p>--mike
<p><xs:attribute name="layer">
<br> <xs:restriction base="xs:string">
<br></xs:attribute>
<br></xs:element></blockquote>
</html>
--------------E7DFBC8757621574A8A5840F--
Re: nullException [message #583323 is a reply to message #36866] |
Ed Merks Messages: 33141 Registered: July 2009 |
Mike,
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:attribute>
<xs:complexType>
</xs:complexType>
</xs:element>
</xs:schema>
> file.
> --mike
> <xs:simpleType>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> <xs:complexType>
> </xs:complexType>
> </xs:element>
<html>
Mike,
<br></xs:attribute>
<br></xs:element>
<br>
a particular schema
<br>file.
<p>--mike
<br></xs:attribute>
</html>
Ed Merks
FUDForum. Page generated in 0.05928 seconds
