Home » Eclipse Projects » Nebula » Gallery JAR failure?
Gallery JAR failure? [message #36778] |
Tue, 26 June 2007 01:44 |
Syed Tirmizi Messages: 11 Registered: July 2009 |
I am working with nebula gallery. When I include the JAR file into my
project, I don't get any exceptions but my GUI fails to load as soon as
I try to construct any gallery related object (Gallery, Galery Item,
Renderer etc). However, if I include the whole source into my project,
it works fine.
Also, upon including source, GalleryDragSourceEffect file is unable to
import org.eclipse.swt.dnd.DragSourceEffect and thus gives errors ...
when I delete GalleryDragSourceEffect.java, my project works fine.
Can anyone tell me why I cant just use the JAR, and how can I get rid
of this error with GalleryDragSourceEffect?
Hamid
Re: Gallery JAR failure? [message #36813 is a reply to message #36778] |
Tue, 26 June 2007 08:02 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
What's your target env? I'd guess that nebula widgets are compiled
against 3.3 and the class you mention is from maybe from 3.3.
If you include the source this works because the eclipse compiler
produces half compiled .class files and if you programm is not running
into the code part that caused the error it works :-)
Tom
Syed Tirmizi schrieb:
> it works fine.
> Can anyone tell me why I cant just use the JAR, and how can I get rid of
> Hamid
Re: Gallery JAR failure? [message #36847 is a reply to message #36813] |
Tue, 26 June 2007 08:46 |
Nicolas Richeton Messages: 179 Registered: July 2009 |
The Drag source effect is indeed a new feature of SWT 3.3.
Could you check if you can use the jar with the latest RC of SWT 3.3 ?
Are you using SWT alone or RCP ?
Nicolas
> Tom
>> Hi,
>> as I try to construct any gallery related object (Gallery, Galery
>> Item, Renderer etc). However, if I include the whole source into my
>> project, it works fine.
>> Thanks,
>> Hamid
Re: Gallery JAR failure? [message #36881 is a reply to message #36847] |
Tue, 26 June 2007 11:31 |
I am using Eclipse 3.2 on Mac OS X (and Windows, since my application
needs to run on both). I am building an RCP application.
Should I migrate to 3.3? What would it change?
Thanks for your help.
Hamid
On 2007-06-26 03:46:11 -0500, Nicolas Richeton
> Nicolas
>> Tom
>>> Hi,
>>> it works fine.
>>> Thanks,
>>> Hamid
Re: Gallery JAR failure? [message #36914 is a reply to message #36881] |
Tue, 26 June 2007 12:07 |
Not much. You should be able to run you app in Eclipse 3.3 without
changing anything in your code. Maybe some dependencies problems in some
case that can be easily fixed. Give a try on a separate eclipse install.
Eclipse 3.3 has a real better OSX support (realtime window resizing,
tray icon, search style for text widget, ...).
I'm developping the Gallery Widget on Eclipse 3.3 / OSX since M1.
Appart from the DragSourceEffect, I'm surprised you have problems with
the Gallery and SWT 3.2. I see no more dependency problems in the code
and the jar seems ok. This should work as far as you don't use the
DragSourceEffect.
Did you add the Gallery plugin jar to your feature and checked that the
run config was correctly updated ?
Nicolas
> Hamid
>> Nicolas
>>> running into the code part that caused the error it works :-)
>>> Tom
>>>> Hi,
>>>> my project, I don't get any exceptions but my GUI fails to load as
>>>> soon as I try to construct any gallery related object (Gallery,
>>>> Galery Item, Renderer etc). However, if I include the whole source
>>>> into my project, it works fine.
>>>> to import org.eclipse.swt.dnd.DragSourceEffect and thus gives errors
>>>> ... when I delete GalleryDragSourceEffect.java, my project works fine.
>>>> rid of this error with GalleryDragSourceEffect?
>>>> Thanks,
>>>> Hamid
Re: Gallery JAR failure? [message #583284 is a reply to message #36778] |
Tom
> it works fine.
> Hamid
Re: Gallery JAR failure? [message #583291 is a reply to message #36813] |
Nicolas
> Tom
>> Hi,
>> Thanks,
>> Hamid
Re: Gallery JAR failure? [message #583307 is a reply to message #36847] |
Hamid
> Nicolas
>> Tom
>>> Hi,
>>> it works fine.
>>> Thanks,
>>> Hamid
Re: Gallery JAR failure? [message #583320 is a reply to message #36881] |
DragSourceEffect.
Nicolas
> Hamid
>> Nicolas
>>> Tom
>>>> Hi,
>>>> Thanks,
>>>> Hamid
Current Time: Fri Apr 26 02:48:38 GMT 2024
Powered by FUDForum. Page generated in 0.04538 seconds
