Home » Eclipse Projects » Plugin Development Environment (PDE) » Exported product doesn't contain Eclipse dependencies - only my features
Exported product doesn't contain Eclipse dependencies - only my features [message #36728] Wed, 10 December 2008 08:05 Go to next message
Originally posted by: michael.zend.com
Hi All!
I'm trying to export my product using the PDE headless build.
1. My build.properties file is as follows:
# Product file path
product=/com.my/MyProduct.product
# Prefix of the final archive
archivePrefix=MyProduct
collectingFolder=${archivePrefix}
# The list of {os, ws, arch} configurations to build.
configs=linux,gtk,x86 & linux,gtk,x86_64 & win32,win32,x86 &
macosx,carbon,ppc
# Specify the output format of the compiler log when eclipse jdt is used
logExtension=.log
2. I have ${buildDirectory}/plugins and ${buildDirectory}/features
containing all of my plugins and features
3. I have ${baseLocation} containing the Eclipse Platform, RCP delta pack
and all the dependencies.
The resulted Zip files are placed into ${buildDirectory}/${buildLabel},
called ${buildId}-${os}.${ws}.${arch}.zip.
The problem is that these Zip files contain only my features not the
dependencies.
How this can be solved?
Thanks!
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #36763 is a reply to message #36728] Wed, 10 December 2008 10:39 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Michael Spector wrote:
> Hi All!
> # Product file path
> macosx,carbon,ppc
> logExtension=.log
> dependencies.
Is your product feature or plug-in based ;)? If feature-based, are you
remembering to include the features you need? ie,. RCP feature...
~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #36797 is a reply to message #36763] Wed, 10 December 2008 10:44 Go to previous messageGo to next message
Yes, my product is features based.
All features that are written between <features> section in .product file
present in the ${baseLocation}.
Anything else that I'm missing?
Thanks!
"Chris Aniszczyk" <zx@code9.com> wrote in message
news:ghonri$lcm$1@build.eclipse.org...
>> Hi All!
>> # Product file path
>> macosx,carbon,ppc
>> logExtension=.log
>> dependencies.
> Cheers,
> ~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #36831 is a reply to message #36797] Wed, 10 December 2008 11:57 Go to previous messageGo to next message
> Thanks!
>>> Hi All!
>>> # Product file path
>>> macosx,carbon,ppc
>>> logExtension=.log
>>> dependencies.
>> Cheers,
>> ~ Chris
Does any of your features include the RCP feature?
~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #36865 is a reply to message #36831] Wed, 10 December 2008 13:02 Go to previous messageGo to next message
None of my features include RCP feature. Should they?
news:ghose1$i9u$1@build.eclipse.org...
>> Thanks!
>>>> Hi All!
>>>> # Product file path
>>>> macosx,carbon,ppc
>>>> used
>>>> logExtension=.log
>>>> pack and all the dependencies.
>>>> dependencies.
>>> Cheers,
>>> ~ Chris
> Cheers,
> ~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #36899 is a reply to message #36831] Wed, 10 December 2008 15:26 Go to previous messageGo to next message
>> Thanks!
>>>> Hi All!
>>>> # Product file path
>>>> macosx,carbon,ppc
>>>> used
>>>> logExtension=.log
>>>> dependencies.
>>> Cheers,
>>> ~ Chris
I've tried to include RCP feature in one of my features - that didn't work
either.
The final archive still contains just plug-ins and features from
$buildDirectory/plugins, $buildDirectory/features, not the dependencies.
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #36933 is a reply to message #36899] Wed, 10 December 2008 17:18 Go to previous messageGo to next message
>>> Thanks!
>>>>> Hi All!
>>>>> # Product file path
>>>>> macosx,carbon,ppc
>>>>> used
>>>>> logExtension=.log
>>>>> dependencies.
>>>> Cheers,
>>>> ~ Chris
> either.
Make sure your build.properties has "runPackager=true".
(You also need to include the RCP feature, but you've already done that).
-Andrew
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #36966 is a reply to message #36933] Thu, 11 December 2008 03:55 Go to previous message
Ok, that wasn't the problem. My problem was a missing line in
build.properties:
runPackager=false
"Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
news:ghpf6r$f0s$1@build.eclipse.org...
>>>> file present in the ${baseLocation}.
>>>> Thanks!
>>>>>> Hi All!
>>>>>> # Product file path
>>>>>> macosx,carbon,ppc
>>>>>> used
>>>>>> logExtension=.log
>>>>>> ${buildDirectory}/${buildLabel}, called
>>>>>> dependencies.
>>>>> Cheers,
>>>>> ~ Chris
>> work either.
> -Andrew
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #586818 is a reply to message #36728] Wed, 10 December 2008 10:39 Go to previous message
> Hi All!
> # Product file path
> macosx,carbon,ppc
> logExtension=.log
> dependencies.
~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #586836 is a reply to message #36763] Wed, 10 December 2008 10:44 Go to previous message
Thanks!
>> Hi All!
>> # Product file path
>> macosx,carbon,ppc
>> logExtension=.log
>> dependencies.
> Cheers,
> ~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #586846 is a reply to message #36797] Wed, 10 December 2008 11:57 Go to previous message
> Thanks!
>>> Hi All!
>>> # Product file path
>>> macosx,carbon,ppc
>>> logExtension=.log
>>> dependencies.
>> Cheers,
>> ~ Chris
~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #586860 is a reply to message #36831] Wed, 10 December 2008 13:02 Go to previous message
>> Thanks!
>>>> Hi All!
>>>> # Product file path
>>>> macosx,carbon,ppc
>>>> used
>>>> logExtension=.log
>>>> dependencies.
>>> Cheers,
>>> ~ Chris
> Cheers,
> ~ Chris
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #586870 is a reply to message #36831] Wed, 10 December 2008 15:26 Go to previous message
>> Thanks!
>>>> Hi All!
>>>> # Product file path
>>>> macosx,carbon,ppc
>>>> used
>>>> logExtension=.log
>>>> dependencies.
>>> Cheers,
>>> ~ Chris
either.
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #586882 is a reply to message #36899] Wed, 10 December 2008 17:18 Go to previous message
>>> Thanks!
>>>>> Hi All!
>>>>> # Product file path
>>>>> macosx,carbon,ppc
>>>>> used
>>>>> logExtension=.log
>>>>> dependencies.
>>>> Cheers,
>>>> ~ Chris
> either.
-Andrew
Re: Exported product doesn't contain Eclipse dependencies - only my features [message #586895 is a reply to message #36933] Thu, 11 December 2008 03:55 Go to previous message
build.properties:
runPackager=false
>>>> Thanks!
>>>>>> Hi All!
>>>>>> # Product file path
>>>>>> macosx,carbon,ppc
>>>>>> used
>>>>>> logExtension=.log
>>>>>> dependencies.
>>>>> Cheers,
>>>>> ~ Chris
>> work either.
> -Andrew
Previous Topic:Exported product doesn't contain Eclipse dependencies - only my features
Next Topic:problems with a RCP extension point
Current Time: Sun Nov 09 17:19:20 EST 2025
Powered by FUDForum. Page generated in 0.05275 seconds
