Home » Archived » OHF » using bridge build Nov1, log entry about "AuditSourceID"
using bridge build Nov1, log entry about "AuditSourceID" [message #36432] Thu, 08 November 2007 14:21 Go to next message
With the Nov 1 version of the bridge installer I get log entries that seem
to be warnings when I submit a document:
<ns2:log xmlns:ns2="http://type.bridge.ohf.eclipse.org"><ns3:item
xmlns:ns3="http://localhost/bridge/services/ohf-bridge-wrapped">2007-11-08T11:04:48.497-08:00
Defaulting to IP Address for AuditSourceID. This should be set by calling
setAuditSourceId.</ns3:item><ns4:item
xmlns:ns4="http://localhost/bridge/services/ohf-bridge-wrapped">2007-11-08T11:04:52.753-08:00
setAuditSourceId.</ns4:item><ns5:item
xmlns:ns5="http://localhost/bridge/services/ohf-bridge-wrapped">2007-11-08T11:04:52.783-08:00
setAuditSourceId.</ns5:item></ns2:log>
This "setAuditSourceId" seems to be something you can only do through the
API. I can't find anything in the Bridge's wsdl to indicate you can set
this. I checked the rhio.xsd to see if there was a way to set it for a
rhio, but there isn't (which makes sense because it doesn't seem like it
should be a rhio setting).
Maybe the level of this message could be lower so when we turn the log
level to WARN, we don't get this message in the bridge? Or specifically
call the setAuditSourceID in the bridge2API code so it doesn't generate
the warning message at all- since maybe WARN is the right level message
for API users?
thanks,
Jesse
Re: using bridge build Nov1, log entry about "AuditSourceID" [message #36461 is a reply to message #36432] Thu, 08 November 2007 14:45 Go to previous messageGo to next message
Hi Jesse,
This was an oversight on our part and you should be able to submit the
audit source ID via the bridge. Please submit a bug to bugzilla with the
information below. This will not inhibit your MESA testing what-so-ever.
Being able to set the audit source ID is "nice" but not required for
these tests.
Thanks!
- Sarah
Jesse Pangburn wrote:
> seem to be warnings when I submit a document:
> calling setAuditSourceId.</ns3:item><ns4:item
> calling setAuditSourceId.</ns4:item><ns5:item
> calling setAuditSourceId.</ns5:item></ns2:log>
> the API. I can't find anything in the Bridge's wsdl to indicate you can
> set this. I checked the rhio.xsd to see if there was a way to set it
> for a rhio, but there isn't (which makes sense because it doesn't seem
> like it should be a rhio setting).
> for API users?
> thanks,
> Jesse
Re: using bridge build Nov1, log entry about "AuditSourceID" [message #36517 is a reply to message #36461] Thu, 08 November 2007 15:43 Go to previous messageGo to next message
Hi Sarah,
Bug is submitted as "Bug 209258"
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209258
Thanks for the clarification that it won't impact any tests!
Jesse
Sarah Knoop wrote:
> Hi Jesse,
> these tests.
> Thanks!
> - Sarah
>> for API users?
>> thanks,
>> Jesse
Re: using bridge build Nov1, log entry about "AuditSourceID" [message #37605 is a reply to message #36517] Tue, 20 November 2007 18:28 Go to previous message
Right now, the AuditSourceId is being set from the
SessionContext.UserApplicationName value.
However, since this is only really relevant for the HL7-based
transactions, I have added a new field to SessionContext:
AuditSourceId. This will now call ATNA and set the value within the
context scope.
I have also renamed the SessionContext.User field to
SessionContext.InitiatingUser. This makes the usage of the field now
align more directly with the ATNA API.
Both of these changes constitute an API change in the Bridge and will
require a regeneration of any WSDL proxies that you may be using.
-Matt
> Hi Sarah,
> Jesse
> Sarah Knoop wrote:
>> Hi Jesse,
>> the information below. This will not inhibit your MESA testing
>> what-so-ever. Being able to set the audit source ID is "nice" but not
>> required for these tests.
>> Thanks!
>> - Sarah
>>> Hi,
>>> can set this. I checked the rhio.xsd to see if there was a way to
>>> set it for a rhio, but there isn't (which makes sense because it
>>> doesn't seem like it should be a rhio setting).
>>> log level to WARN, we don't get this message in the bridge? Or
>>> specifically call the setAuditSourceID in the bridge2API code so it
>>> doesn't generate the warning message at all- since maybe WARN is the
>>> right level message for API users?
>>> thanks,
>>> Jesse
Re: using bridge build Nov1, log entry about "AuditSourceID" [message #582869 is a reply to message #36432] Thu, 08 November 2007 14:45 Go to previous message
Hi Jesse,
these tests.
Thanks!
- Sarah
> for API users?
> thanks,
> Jesse
Re: using bridge build Nov1, log entry about "AuditSourceID" [message #582892 is a reply to message #36461] Thu, 08 November 2007 15:43 Go to previous message
Hi Sarah,
Jesse
Sarah Knoop wrote:
> Hi Jesse,
> these tests.
> Thanks!
> - Sarah
>> for API users?
>> thanks,
>> Jesse
Re: using bridge build Nov1, log entry about "AuditSourceID" [message #583322 is a reply to message #36517] Tue, 20 November 2007 18:28 Go to previous message
context scope.
-Matt
> Hi Sarah,
> Jesse
> Sarah Knoop wrote:
>> Hi Jesse,
>> Thanks!
>> - Sarah
>>> Hi,
>>> thanks,
>>> Jesse
Previous Topic:Hash, Size and URI missing in metadata
Next Topic:Bridge: secured connection forced with public XDS registry
Current Time: Wed Nov 05 14:38:09 EST 2025
Powered by FUDForum. Page generated in 0.04245 seconds
