Home » Archived » XML Schema Definition (XSD) » Possible errors in the XSD facet item providers
Re: Possible errors in the XSD facet item providers [message #36099 is a reply to message #36062] |
Fri, 16 January 2004 17:25 |
Frank Budinsky Messages: 478 Registered: July 2009 |
Hi Dennis,
Ed is on vacation until next Wednesday.
I think you are right about the bug. It looks like a copy/modify error from when
the code was written (the XSD item providers predate the EMF.Edit code
generator, so they were coded by hand). I noticed the same thing in several
other classes (e.g., XSDMaxLengthFacetItemProvider).
Did you try to make the change, to see if it works then? Do you know why this
doesn't show up in the XSD Sample Editor? Does it never display these item
providers?
Could you please open a bugzilla defect for this.
Frank.
dfuglsang wrote:
> Ed,
> I have been diagnosing a problem associated with the "Value" EAttribute on
> XSD facets via the Eclipse properties view. The problem ultimately stems
> from calling the XSD facet's eIsSet method with the wrong EStructuralFeature
> reference resulting in the following exception
> java.lang.IllegalArgumentException: The feature 'value' is not a valid
> feature
> at
> org.eclipse.emf.ecore.impl.EObjectImpl.eDynamicIsSet(EObject Impl.java:480)
> at
> org.eclipse.xsd.impl.XSDMinLengthFacetImpl.eIsSet(XSDMinLeng thFacetImpl.java
> :305)
> at
> org.eclipse.emf.edit.provider.ItemPropertyDescriptor.getProp ertyValue(ItemPr
> opertyDescriptor.java:658)
> at
> org.eclipse.emf.edit.ui.provider.PropertySource.getPropertyV alue(PropertySou
> rce.java:95)
> at
> com.metamatrix.modeler.internal.ui.properties.ModelObjectPro pertySource.getP
> ropertyValue(ModelObjectPropertySource.java:224)
> at
> org.eclipse.ui.views.properties.PropertySheetEntry.refreshVa lues(PropertyShe
> etEntry.java:489)
> at
> org.eclipse.ui.views.properties.PropertySheetEntry.refreshCh ildEntries(Prope
> rtySheetEntry.java:455)
> at
> org.eclipse.ui.views.properties.PropertySheetEntry.setValues (PropertySheetEn
> try.java:611)
> at
> org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetVi
> ewer.java:776)
> at
> org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertyS
> heetPage.java:377)
> As I have been tracking through this is seems that the PropertyDescriptor
> for the "Value" feature is not constructed with the correct
> EStructuralFeature reference. For example, for an XSDMinLengthFacet the
> logic shown below uses the XSDMinFacet's EStructuralFeature reference
> instead of the one for XSDMinLengthFacet. Is this an error ?
> The logic in XSDMinLengthFacetItemProvider ...
> public List getPropertyDescriptors(Object object)
> if (itemPropertyDescriptors == null)
> super.getPropertyDescriptors(object);
> XSDMinLengthFacet xsdMinLengthFacet = ((XSDMinLengthFacet)object);
> // This is for the value feature.
> itemPropertyDescriptors.add
> (new ItemPropertyDescriptor
> (((ComposeableAdapterFactory)adapterFactory).getRootAdapterF actory(),
> XSDEditPlugin.getString("_UI_Value_label"),
> XSDEditPlugin.getString("_UI_ValueMinLengthFacet_description "),
> xsdPackage.getXSDMinFacet_Value(), <==== FIX ???? Should this
> be xsdPackage.getXSDMinLengthFacet_Value(),
> true,
> ItemPropertyDescriptor.INTEGRAL_VALUE_IMAGE));
> return itemPropertyDescriptors;
Re: Possible errors in the XSD facet item providers [message #36302 is a reply to message #36099] |
Mon, 19 January 2004 16:42 |
Dennis Fuglsang Messages: 77 Registered: July 2009 |
Member |
Frank,
I ended up creating a local patch for the xsd.edit code, specifically the
XSDMaxLengthFacetItemProvider and XSDMinLengthFacetItemProvider classes.
Those two classes, I believe, are the only item providers with the error in
the getPropertyDefinitions(Object) method. Frank, you and Ed may want to
check the other xsd item providers to verify the problem is confined to only
those two classes but my patch does seem to fix the problems I have had
working with facets. (bugzilla defect #50222)
Thanks for your help,
Dennis
"Frank Budinsky" <frankb@ca.ibm.com> wrote in message
news:40081EA4.DCCFF172@ca.ibm.com...
> Hi Dennis,
from when
several
this
> providers?
> Frank.
> dfuglsang wrote:
> > Ed,
on
stems
EStructuralFeature
> > feature
> > at
> > at
> > :305)
> > at
> > at
> > rce.java:95)
> > at
> > at
> > etEntry.java:489)
> > at
> > at
> > try.java:611)
> > at
> > ewer.java:776)
> > at
> > heetPage.java:377)
PropertyDescriptor
this
> > true,
Re: Possible errors in the XSD facet item providers [message #582851 is a reply to message #36062] |
Hi Dennis,
providers?
Frank.
dfuglsang wrote:
> Ed,
> feature
> at
> at
> :305)
> at
> at
> rce.java:95)
> at
> at
> etEntry.java:489)
> at
> at
> try.java:611)
> at
> ewer.java:776)
> at
> heetPage.java:377)
> true,
Re: Possible errors in the XSD facet item providers [message #582977 is a reply to message #36099] |
Member |
Frank,
Dennis
> Hi Dennis,
from when
several
this
> providers?
> Frank.
> dfuglsang wrote:
> > Ed,
on
stems
EStructuralFeature
> > feature
> > at
> > at
> > :305)
> > at
> > at
> > rce.java:95)
> > at
> > at
> > etEntry.java:489)
> > at
> > at
> > try.java:611)
> > at
> > ewer.java:776)
> > at
> > heetPage.java:377)
PropertyDescriptor
this
> > true,
Current Time: Wed Sep 18 23:07:21 GMT 2024
Powered by FUDForum. Page generated in 0.04313 seconds
