Home » Archived » XML Schema Definition (XSD) » use="required"/use="optional"
Re: use="required"/use="optional" [message #35594 is a reply to message #35487] |
Tue, 13 January 2004 13:19 |
Originally posted by: crscca.bol.net.in
We seem to be done with our code's xsd portion. Having some trouble with
the compositors when we are extending complex types. Will sort it out
later.
Have 1 question
1. Does xsd plugin work fine inside M6? So far used it inside M5.
Thanks.
Raster
Dave Steinberg wrote:
> raster wrote:
> > Hi!
> > OK how does one get the following:-
> Hi Raghu,
> XSDAttributeUse.getUse() returns an instance of the XSDAttributeUseCategory
> enum, with value OPTIONAL_LITERAL, PROHIBITED_LITERAL, or REQUIRED_LITERAL.
> XSDAttributeUse represents a use of an attribute (by declaration, by
> reference, or via an attribute group). Its role is analogous to XSDParticle.
> XSDAttributeUses are generally accessed from an XSDComplexTypeDefinition or
> XSDAttributeGroupDefinition via their attributeUses references.
> Cheers,
> Dave
Re: use="required"/use="optional" [message #35763 is a reply to message #35661] |
Wed, 14 January 2004 06:34 |
Hi Dave,
What do you mean by- "we're stretched very thing right now"?
Raster
> Raster wrote:
> > Have 1 question
> Hi Raster,
> EMF doesn't yet work in M6, so XSD doesn't either. You'll have to stick with
> M5 until we get it working. Unfortunately, we're stretched very thing right
now.
> Cheers,
> Dave
Re: use="required"/use="optional" [message #35797 is a reply to message #35661] |
Wed, 14 January 2004 06:38 |
Hi Dave,
I hope eclipse team plans to continue with xsd beyond M5. (No need for me
to panic I hope on that count.)
Raster
> Raster wrote:
> > Have 1 question
> Hi Raster,
now.
> Cheers,
> Dave
Re: use="required"/use="optional" [message #35898 is a reply to message #35864] |
Thu, 15 January 2004 13:21 |
Thank Goodness 4 that.
> Hi Raster,
> Sorry, I didn't mean to alarm you. I just meant that the EMF/XSD team isn't
> at full strength right now, due to vacations and to other responsibilities.
> Things should be picking up again in the coming weeks. Yes, we certainly
> intend to continue with XSD well beyond M5.
> Oh, and "thing" was a typo; I meant "thin." :)
> Cheers,
> Dave
Current Time: Fri Apr 26 15:21:52 GMT 2024
Powered by FUDForum. Page generated in 0.06810 seconds
