Home » Eclipse Projects » Equinox » BundleContext#installBundle parameters
BundleContext#installBundle parameters [message #34894] Tue, 10 February 2004 00:02 Go to next message
Originally posted by: igorf.ca.ibm.com
What are the expected parameters of BundleContext#installBundle(String,
InputStream)? Does anyone have example code that uses this call?
Igor
Re: BundleContext#installBundle parameters [message #35011 is a reply to message #34894] Tue, 10 February 2004 09:37 Go to previous message
Originally posted by: jeff_mcaffer_REMOVE.ca.ibm.com
Example of installing bundles is in org.eclipse.update.configurator.
Doc is in the OSGi spec (http://www.osgi.org)
first arg is the "location" of the bundle to install. Second is an input
stream on the bundle's jar. In general we do not use this pattern but
rather installBundle(String) where the arg is a URL pointing ot the bundle.
If the URL is a reference: URL then the target is not copied into the
framework's private storage area.
Jeff
"Igor Fedorenko" <igorf@ca.ibm.com> wrote in message
news:c09oft$3u3$1@eclipse.org...
> Igor
Previous Topic:What happened to Export-Package, etc.?
Next Topic:How to provide all packages
Current Time: Mon Nov 03 14:29:18 EST 2025
Powered by FUDForum. Page generated in 0.03514 seconds
