| turn off php syntax checker [message #34818] | Tue, 10 July 2007 10:18  |  |
| Eclipse User  |  |  |  |  | Originally posted by: pobox.verysmall.org
 Is it possible to turn off the php syntax checker?
 It seems it checks the syntax virtually after every pressed key and
 since in Europa PDT is quite slow, I was wondering if this is going to
 speed things up.
 Iavor
| Re: turn off php syntax checker [message #37232 is a reply to message #36028] | Thu, 19 July 2007 08:58  |  |
| Eclipse User  |  |  |  |  | I guess you can use the latest integration build.
 Guy.
 "Iavor Raytchev" <pobox@verysmall.org> wrote in message
 news:f7i6un$a8u$1@build.eclipse.org...
 > Guy Gurfinkel wrote:
 >> What you call syntax checker, is actually builds the data for the
 >> outlines, code assist etc.
 >> The bad news is you can't disable it, and the good news is that the
 >> mechanism was changed and it should work better now.
 >> The next build will be ready tomorrow.
 > Yes, you are completely right.
 > Since Europe on every pressed key everything seems to be re-build (I
 > noticed how the Subclipse icons get constantly re-drawn).
 > Is 'tomorrow' the 16th?
 > The Eclipse updater still does not get any updates, or do you mean it's in
 > the nightly? If yes, do you know when it is going to be released?
 > Iavor
FUDForum. Page generated in 0.53866 seconds
