Home » Eclipse Projects » Paho » Paho Client 'onMessageArrived' Not Called In Javascript(Using Javascript to connect to Mosquitto)
Paho Client 'onMessageArrived' Not Called In Javascript [message #1872680] Thu, 14 November 2024 08:20 Go to next message
I've finally managed to connect, using Paho and browser Javascript, to a local computer that's running Mosquitto.
I can publish messages which I know the broker is receiving and distributing thanks to using the MQTT Explorer app. I can also see a Terminal window that's subscribed to the topic printing out the messages that are sent from the browser.
unfortunately, the same browser refuses to trigger 'onMessageArrived'. Here's my .js code:
let client = null;
let connected = false;
let connectionAttempt = 1;
const clientId = "vFwKg";
const REMOTE = false;
let hostname = "192.168.1.186"
const port = 8080;
let path = "";
const mainTopic = "train_control";
const user = "1731445474889";
const pass = "5180YRZIQbdSfeca<,.>";
const keepAlive = 60;
const timeout = 30;
const tls = REMOTE;
const cleanSession = true;
const lastWillTopic = `Test/LastWills/${clientId}`;
const lastWillQos = 0;
const lastWillRetain = true;
const lastWillMessageVal = `${clientId}:closed`;
let connectOptions;
var messageElement;
document.addEventListener("DOMContentLoaded", (event) => {
  messageElement = document.getElementById('message');
  // body...
  client = new Paho.MQTT.Client(hostname, Number(port), path, clientId);
  logMessage(`INFO    Connecting to Server: [Host: ${hostname}, Port: ${port}, Path: ${client.path}, ID: ${clientId}]`);
  // set callback handlers
  client.onConnectionLost = onConnectionLost;
  client.onMessageArrived = onMessageArrived;
  client.onConnected = onConnected;
  let lastWillMessage = new Paho.MQTT.Message(lastWillMessageVal);
  lastWillMessage.destinationName = lastWillTopic;
  lastWillMessage.qos = lastWillQos;
  lastWillMessage.retained = lastWillRetain;
  connectOptions = {
    invocationContext: {
      host: hostname,
      port: port,
      path: client.path,
      clientId: clientId
    timeout: timeout,
    keepAliveInterval: keepAlive,
    cleanSession: cleanSession,
    useSSL: tls,
    onSuccess: onConnect,
    onFailure: onFail,
    userName: user,
    password: pass,
    willMessage: lastWillMessage
  // connect the client
  client.connect(connectOptions);
No errors at all are displayed in the Console of the browser.
Is there anyone who's had luck with 'hearing' messages via a browser? Is it something I've missed? I'm using Firefox and Safari with the same results.
Re: Paho Client 'onMessageArrived' Not Called In Javascript [message #1872689 is a reply to message #1872680] Thu, 14 November 2024 13:02 Go to previous message
The problem was actaully in my subscription line - which I hadn't posted here as I thought it was working!
Instead of:
client.subscribe('*{mainTopic}/#', { qos: Number(0) });
I just needed:
client.subscribe(mainTopic);
The QoS value seemed to block the messages incoming despite all my code contain QoS values of 0 and MQTT Explorer confirmed the messages as having that value.
Previous Topic:Using Paho 2.+ Python MQTT with TPM
Next Topic:Where to ask beginner question in year 2025 onward
Current Time: Sun Nov 02 22:52:34 EST 2025
Powered by FUDForum. Page generated in 0.04997 seconds
