Home » Eclipse Projects » Plugin Development Environment (PDE) » ecipse rcp4 main plugin cannot load the sub plugins(ecipse rcp4 main plugin cannot load the sub plugins)
ecipse rcp4 main plugin cannot load the sub plugins [message #1872560] Thu, 07 November 2024 01:32
On the basis of the project (based on Eclipse rcp4.0), I created a sub plugin and added it to the project in the "Included Plug ins" tab of the feature.xml file. However, the views and other functions defined in the sub plugin were not reflected in the main plugin, as if the sub plugin was not successfully loaded
Previous Topic:PDE build failing with java 11.
Current Time: Tue Sep 09 23:40:10 EDT 2025
Powered by FUDForum. Page generated in 0.61857 seconds
