The meaning of the PHP Version. [message #1870401] |
Sun, 25 August 2024 16:19 |
Eclipse: 2024 06
OS: Debian 12
I am new to Ecplise and I have some questions about the meaning of
some configurations.
Here are my questions:
1) The form presented when creating a new PHP project ( New > PHP Project )
contains a section named PHP Version with two options: 1) Use default PHP
settings and b) Use project specific settings.
What are "the default PHP settings"? The default PHP settings are not based
on the version of the PHP interpreter accessible through the PATH variable
because if I change my PATH to point to a different PHP interpreter the
project will always be created with the PHP Language Library 8.2 (info
shown in Project Explorer).
2) What is the purpose of the PHP Version set during the creation of the
project ?
3) How can I change the PHP Version of a project ? I've tried to modify
the project properties accessible from Project Explorer. I was not able
to find any option with a resonable name that changes the PHP Version.
The only option was that was specfying a PHP Version was in the "Project
facets" section but it does not have any effect over the "PHP version"
associated with the project. What is the purpose of the Project facets
section?
4) Shouln't the "PHP version" of a project be based on the PHP Version used
to run the current configuration?
Thank you
Chris
FUDForum. Page generated in 0.03191 seconds
