Home » Eclipse Projects » EGit / JGit » Conflicting File compare text(Conflicts can occur after pull or merging branches. I would like to solve conflicts manually by comparing the two versions of the file)
Conflicting File compare text [message #1869654] Wed, 21 August 2024 01:52
Conflicts can occur after pull or merging branches. I would like to solve the conflicts programatically, by comparing the two versions of the file which are conflicting.
I can do this by looking into the MergeResult.
But if my sofware is restarted, I no longer have access to the MergeResult.
The git.status() command is also listing the conflicting files. But how can I get the two versions of the conflicting file from the status command?
ChatGPT indicate a solution like this, but DirCacheEntry is empty and the method dirCache.getEntry(filePath, DirCacheEntry.STAGE_2) currently accepts only one parameter.
public class JGitConflictObjectIds {
    public static void main(String[] args) throws IOException {
        try (Repository repository = new FileRepositoryBuilder().setGitDir(new File("/path/to/repo/.git")).build()) {
            Git git = new Git(repository);
            Status status = git.status().call();
            Set<String> conflictingFiles = status.getConflicting();
            for (String filePath : conflictingFiles) {
                DirCache dirCache = repository.readDirCache();
                DirCacheEntry ourEntry = dirCache.getEntry(filePath, DirCacheEntry.STAGE_2);
                DirCacheEntry theirEntry = dirCache.getEntry(filePath, DirCacheEntry.STAGE_3);
                ObjectId ourId = ourEntry.getObjectId();
                ObjectId theirId = theirEntry.getObjectId();
                System.out.println("File: " + filePath);
                System.out.println("Our version ObjectId: " + ourId.name());
                System.out.println("Their version ObjectId: " + theirId.name());
                String ourContent = readFileContent(repository, ourId, filePath);
                String theirContent = readFileContent(repository, theirId, filePath);
                System.out.println("Our version:\n" + ourContent);
                System.out.println("Their version:\n" + theirContent);
    private static String readFileContent(Repository repository, ObjectId commitId, String filePath) throws IOException {
        try (RevWalk revWalk = new RevWalk(repository)) {
            TreeWalk treeWalk = TreeWalk.forPath(repository, filePath, revWalk.parseCommit(commitId).getTree());
            ObjectId blobId = treeWalk.getObjectId(0);
            ObjectLoader loader = repository.open(blobId);
            ByteArrayOutputStream out = new ByteArrayOutputStream();
            loader.copyTo(out);
            return out.toString();
Loading the file original text from MergeResult can be done using:
for (Map.Entry<String, int[][]> entry : mergeResult.getConflicts().entrySet()) {
                String filePath = entry.getKey();
                try {
                    String ourContent = readFileContent( repo.resolve("HEAD:" + filePath) );
                    String theirContent = readFileContent( repo.resolve("MERGE_HEAD:" + filePath) );
                    conflictVersions.put( filePath, new ConflictVersions(ourContent, theirContent) );
                } catch ( Exception ex ){
                    Log.error( ex );
    private String readFileContent(ObjectId objectId) throws IOException {
        ObjectLoader loader = repo.open(objectId);
        loader.copyTo(out);
        return out.toString( StandardCharsets.UTF_8 );
Previous Topic:How to overide the maxObjectSize in FetchCommand
Next Topic:Not able to login on github (not authorized)
Current Time: Sun Jul 27 00:35:18 EDT 2025
Powered by FUDForum. Page generated in 0.06883 seconds
