Home » Language IDEs » Java Development Tools (JDT) » Codeium will not install on 2024-06 (4.32.0)(Codeium will not install on 2024-06 (4.32.0))
Codeium will not install on 2024-06 (4.32.0) [message #1867194] Wed, 19 June 2024 03:35 Go to next message
I have tried to install Codeium twice and get the message "The following solutions are not available: Codeium 1.8.25 Proceed with installation anyway?". When I select "Yes", at the end of installation I get the message "Could not install see error log". I do not know where the error log referred to is.
Can anyone please guide me on how to install Codeium.
Kind regards,
Glyn
Re: Codeium will not install on 2024-06 (4.32.0) [message #1867197 is a reply to message #1867194] Wed, 19 June 2024 06:14 Go to previous messageGo to next message
The Error Log is a view. On Windows, you can display it via Window -> Show View -> Error Log or Window -> Show View -> Other and then either type in "err" or navigate to General -> Error Log.
If you're lucky, the error log will have a stack trace.
[Updated on: Wed, 19 June 2024 06:15] by Moderator
Re: Codeium will not install on 2024-06 (4.32.0) [message #1867311 is a reply to message #1867197] Fri, 21 June 2024 02:45 Go to previous messageGo to next message
Hi Erik,
The error log contains:
Message:
Invalid preference category path: org.eclipse.ui.preferencePages.Root (bundle: com.codeium.eclipse.plugin, page: com.codeium.eclipse.PreferencesPage)
Exception Stack Trace:
An exception stack trace is not available.
Session Data:
eclipse.buildId=4.32.0.20240606-1231
java.version=22.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
Does anyone have any idea on how I can fix this please?
Kind regards,
Glyn
Re: Codeium will not install on 2024-06 (4.32.0) [message #1867461 is a reply to message #1867311] Wed, 26 June 2024 09:09 Go to previous message
The log contents are showing you problems from having a forced installation that wasn't expected to work. What you need to find is the original message
and details for why you couldn't install Codeium in the first place, from inside that set of dialogs.
Previous Topic:I cannot find a background color setting
Next Topic:Problem With Play Background Music in Android Application
Current Time: Sun Nov 09 12:13:29 EST 2025
Powered by FUDForum. Page generated in 0.04149 seconds
