Home » Modeling » Epsilon » How to import java libraries to .eol files?
How to import java libraries to .eol files? [message #1866753] Thu, 06 June 2024 08:23 Go to next message
I'm trying to import java libraries to get some user input or work with dates but I get the error 'Importing java.util.Scanner is not supported in this language'. The same error applies to java.util.Date. How can I import them in a project?
import 'java.util.Scanner';
import 'java.util.Date';
operation Passenger hello() : String {
 return('Hello world');
Re: How to import java libraries to .eol files? [message #1866756 is a reply to message #1866753] Thu, 06 June 2024 08:28 Go to previous message
Hi Fatma,
You can achieve this using EOL's Native type as shown below:
var dateFormat = new Native("java.text.SimpleDateFormat")("MM-dd-yyyy");
dateFormat.format(new Native("java.util.Date")).println();
Dimitris
Previous Topic:Data retrieval from models through Java and EOL
Next Topic:Issue with protected region since Eclipse 2024-03
Current Time: Fri Oct 31 19:14:07 EDT 2025
Powered by FUDForum. Page generated in 0.04417 seconds
