Question about C/C++ Project Page [message #1866009] |
Fri, 17 May 2024 10:25  |
For the C++ code generation in the tool I am developing, I call a class that opens a popup to select the project. Until now, this would open the Papyrus selection page (C++ Project Page) to choose the desired toolchain: Cygwin, MinGW, etc.
Now, when I select the project and confirm the selection, the code generation is automatically launched using Cross GCC.
Have there been any recent changes?
What changes need to be made to retrieve the C++ Project Page ?
I'm using the nightly Papyrus Designer target:
"https://ci.eclipse.org/papyrus/job/papyrus-designer-2023-03/lastSuccessfulBuild/artifact/releng/org.eclipse.papyrus.designer.p2/target/repository/"
If you have any ideas, I would appreciate them!
Thank you.
Antoine
Moreover, even though I have selected the Cygwin toolchain as the "preferred Toolchains" in the preferences ("Make toolchain(s) preferred" in C/C++ -> New C/C++ Project Wizard), it is not being taken into account.
Re: Question about C/C++ Project Page [message #1866765 is a reply to message #1866747] |
Thu, 06 June 2024 09:03  |
Hi Antoine,
thanks for the swift reply and the remark related to the default option. The new plugin.xml that registers the default initializer was not in the binary build (missing in build.properties). I will correct that asap.
FUDForum. Page generated in 0.14117 seconds
