Home » Eclipse Projects » DSDP - Target Management » Is TM/RSE right for us?
Re: Is TM/RSE right for us? [message #2995 is a reply to message #2979] |
Fri, 12 January 2007 16:37 |
Originally posted by: torkildr.resheim.no
Hi Robert
Robert Norton wrote:
[snip]
> The basic problem is that setting up a debugging environment for us is
> much more complicated than the default CDT (+ Zylin patches) launch
> configuration allows. In particular it might involve starting several
> different processes (each with specific options, sometimes on a remote
> target) in the correct order and finally connecting a gdb process.
This should not be a problem. You can subclass the CDT launch delegate and
do all of the starting before letting it continue with gdb.
> From scanning the available documentation I get the impression that TM
> and RSE provide a basic framework which could be used to automate much
> of this, but I'm still unclear on exactly how it could be achieved. For
TM provides the remote capabilities.
> example might it be possible to create a new debug configuration type
> tailored to each of our debugging scenarios and leveraging the RSE
> functionality? I'm keen to create as general a framework as possible for
Yes, this is what you'd want to do.
> starting auxiliary process and would love to contribute back any code I
> produce (subject to the agreement of management / legal bods.).
> Does anyone have the slightest idea what I am talking about? If so, can
> you offer any comments or suggestions?
Yes, I've implemented something very similar to what you want. I'm not at
liberty to reveal any details but I know it's possible using the
aforementioned methods.
> Cheers,
> Robert Norton
> DSL Unit, Broadcom UK
Med vennlig hilsen / Kind regards
Torkild Ulvøy Resheim
Advanced Remote Launching (was: Is TM/RSE right for us?) [message #3049 is a reply to message #2979] |
Mon, 15 January 2007 16:21 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hi Robert,
it's great to hear that you want to extend the TM / RSE Launching
mechanism, and also think about contributing back your enhancements.
As Torkild has already pointed out, adding Shell Operations to a Launch
by adding them to the LaunchDelegate "hardcoded" should be fairly easy.
If you want to have your shell commands independent of the protocol
(ssh, telnet, dstore, or whatever contributed), you might want to
consider extending
org.eclipse.rse.subsystems.shell.core.model.SimpleCommandOpe ration .
For some sample code that deals with running commands on the remote
side, see org.eclipse.rse.examples.tutorial/ShowJarContents
as well as the MontaVista ssh processes contribution, which is currently
available from Bugzilla at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=159522
With respect to making such shell (or download) actions as part of a
Launch generic, we already have a concept for this. The idea is to have
an additional tab in the Launch, where you see a list of entries. Each
entry is of type ILaunchAction, where implementations of ILaunchAction
can be contributed through plugin.xml. Each ILaunchAction brings an
associated UI for configuring it.
Examples of ILaunchAction could be a RunShellCommandLaunchAction, or a
DownloadFileLaunchAction, each of which could use RSE services in turn.
The LaunchActionSequencer, which runs one action after the other can
even be generic (independent of RSE), just like the LaunchActionManager
which would be responsible for persisting the ILaunchAction data into
ILaunchConfiguration instances.
Unfortunately, this excellent idea isn't currently being implemented due
to lack of resources. If you like this idea, please get in touch with us
on the dsdp-tm-dev@eclipse.org mailing list for further exchange of
concrete design ideas. It would be great if you could work in this
direction and contribute some code. The online place for more details is
at http://wiki.eclipse.org/index.php/DSDP/TM/Launching
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> Greetings All!
> I've been given the task of adapting Eclipse to the needs of our
> developers and have identified that one of our requirements is to
> simplify the process of configuring and launching a debug session on an
> embedded target (or simulator). Since this is exactly the sort of thing
> that TM/RSE is supposed to handle I thought I would give a shout on this
> mailing list to see if anyone can offer any suggestions.
> Cheers,
> Robert Norton
Re: Is TM/RSE right for us? [message #565469 is a reply to message #2979] |
Hi Robert
[snip]
> Cheers,
> Robert Norton
Advanced Remote Launching (was: Is TM/RSE right for us?) [message #565536 is a reply to message #2979] |
Hi Robert,
consider extending
Martin Oberhuber
> Greetings All!
> Cheers,
> Robert Norton
Current Time: Fri Apr 26 07:26:57 GMT 2024
Powered by FUDForum. Page generated in 0.03008 seconds
