Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » 4Diac IDE open source
4Diac IDE open source [message #1864588] Wed, 27 March 2024 09:39 Go to next message
Hello, it's possible to change the 4Diac IDE to make a ladder logical ou FBD? Have some documentation about that?
Thanks.
Re: 4Diac IDE open source [message #1864593 is a reply to message #1864588] Wed, 27 March 2024 11:47 Go to previous message
The only place where IEC 61499 would allow ladder logic or FBD would be for implementing Algorithms of Function Blocks. In order to do that change you would need to:
1. define the storage format of LD or FBD for FBs
2. update the internal storage format of 4diac IDE to support LD and FBD
3. change our XML parser and writer to understand the storage format defined in 1
4. implement a dedicated editor for LD or FBD
I would expect for an MVP more then 12 PM effort, if you have a good understanding of the Eclipse Platform, EMF and GEF Classic.
Previous Topic:dynamic type loader
Next Topic:Create FB instance failed LUAJIT
Current Time: Wed Aug 27 23:31:01 EDT 2025
Powered by FUDForum. Page generated in 0.04802 seconds
