Home » Modeling » TMF (Xtext) » Tree view on model file on the first run not working
Tree view on model file on the first run not working [message #1863820] Wed, 28 February 2024 04:25 Go to next message
I defined an EMF metamodel (1st Eclipse instance), and a Xtext project for having a textual language for it (2nd Eclipse).
On the 3rd Eclipse, then I:
1. create a modeling project
2. create a textual file with the required extension
3. manually insert the minimum required content to get a parsable model
Issue: in the model explorer, it is not possible to expand it (seeing the contained model elements) unless I close the project and reopen it.
Am I doing something wrong on the Xtext or EMF side? Any way to overcome this?
Thank you in advance for any answer
Re: Tree view on model file on the first run not working [message #1863821 is a reply to message #1863820] Wed, 28 February 2024 04:29 Go to previous messageGo to next message
Hello Francesco!
Are you talking about the Modeling Project from Sirius?
If yes, there could be some shortcomings using that one, in that case you can also raise your question on the Sirius forum.
Hope that helps!
Tamás
Re: Tree view on model file on the first run not working [message #1863822 is a reply to message #1863821] Wed, 28 February 2024 05:00 Go to previous messageGo to next message
Tamas Miklossy wrote on Wed, 28 February 2024 09:29
Hi Tamás,
yes, it is a Sirius modeling project.
In particular, I am referring to this:
index.php/fa/44016/0/
Sirius also adds stuff in there (the available diagrams), but I actually don't know if Sirius is the main responsible for generating that (I would say, the metamodel.edit/editor plugin is)
  • Attachment: tree.png
    (Size: 14.68KB, Downloaded 216 times)
[Updated on: Wed, 28 February 2024 05:03] by Moderator
Re: Tree view on model file on the first run not working [message #1863823 is a reply to message #1863822] Wed, 28 February 2024 05:20 Go to previous messageGo to next message
this would be the emf forum
Re: Tree view on model file on the first run not working [message #1863824 is a reply to message #1863823] Wed, 28 February 2024 07:03 Go to previous message
I will crosspost this on the EMF forum then (edit: here).
Edit 2: it seems not to be a EMF thing, also trying on Sirius, here.
Here is more data about the problem:
Video showing the issue.
See the attached zip file for a reproducible example (Xtext only, with implicit EMF metamodel).
[Updated on: Wed, 28 February 2024 08:44] by Moderator
Previous Topic:Xtext 2.34.0 is out
Next Topic:Standalone Custom Validation Not Being Called
Current Time: Wed Sep 03 01:36:45 EDT 2025
Powered by FUDForum. Page generated in 0.25421 seconds
