Question about DLTK's build management tools [message #34610] |
Wed, 26 November 2008 15:14 |
Originally posted by: brunodomedeiros.gmail.com
Hi there. This is not directly related to DLTK, but I would like to ask
which software do you use for DLTK's build management and continuous
integration. I'm specifically thinking about what is used to produce this:
http://download.eclipse.org/technology/dltk/downloads/
(that is able to show errors, warnings, running unit tests and
collecting its results)
Is is TPTP based or something else? Is it a different tool than JDT's
and other Eclipse projects?
Thanks.
Bruno Medeiros - Software Developer, MSc. in CS/E graduate
Re: Question about DLTK's build management tools [message #34682 is a reply to message #34648] |
Fri, 28 November 2008 20:35 |
Andrei Sobolev wrote:
> Hi Bruno,
> Out build system are based on Eclipse Base builder infrastructure
> (org.eclipse.releng.basebuilder).
> And Cruise Control to monitor cvs changes and start
> builds.(http://cruisecontrol.sourceforge.net/)
> You can look at following plugins from DLTK CVS
> (dev.eclipse.org/cvsroot/technology/).
> org.eclipse.dltk/releng.dltkbuilder - contain builder configuration for
> all DLTK components.
> org.eclipse.dltk/releng.control - contains configuration for Cruise
> Control to start and monitor builds.
> Base builder are in eclipse cvs: dev.eclipse.org/cvsroot/eclipse
> Best regards,
> Andrei Sobolev.
>> ask which software do you use for DLTK's build management and
>> continuous integration. I'm specifically thinking about what is used
>> to produce this:
>> Thanks.
Thank you, that info should get me started.
FUDForum. Page generated in 0.04268 seconds
