Home » Language IDEs » C / C++ IDE (CDT) » Using Eclipse CDT with Docker
Using Eclipse CDT with Docker [message #1863133] Wed, 17 January 2024 14:33
Hi has anyone attempted to build inside a docker container using Eclipse CDT? I installed the Eclipse Docker Tooling plugin and expected this to "just work," but I got the below error trying to run a test bash command instead of make. Eclipse is connecting to the container on unix:///var/run/docker.sock, and the connection is valid. It's apparently trying to run java -jar agent.jar and I do not know why.
12:15:24 **** Build of configuration Default for project S2VMS Github ****
[Running in image <devopsacicontainerregistry.azurecr.io/jenkins/netbox-bionic-aks-agent:latest>]
echo testing
WARNING: A terminally deprecated method in java.lang.System has been called
WARNING: System::setSecurityManager has been called by hudson.remoting.jnlp.Main (file:/usr/share/jenkins/agent.jar)
WARNING: Please consider reporting this to the maintainers of hudson.remoting.jnlp.Main
WARNING: System::setSecurityManager will be removed in a future release
At least one -url option is required.
java -jar agent.jar [options...] <secret key> <agent name>
-agentLog FILE                        : Local agent error log destination
                                         (overrides workDir)
-cert VAL                             : Specify additional X.509 encoded PEM
                                         certificates to trust when connecting
                                         to Jenkins root URLs. If starting with
                                         @ then the remainder is assumed to be
                                         the name of the certificate file to
                                         read.
-credentials USER:PASSWORD            : HTTP BASIC AUTH header to pass in for
                                         making HTTP requests.
-direct (-directConnection) HOST:PORT : Connect directly to this TCP agent
                                         port, skipping the HTTP(S) connection
                                         parameter download. For example,
                                         "myjenkins:50000".
-disableHttpsCertValidation           : Ignore SSL validation errors - use as
                                         a last resort only. (default: false)
-failIfWorkDirIsMissing               : Fails the initialization if the
                                         requested workDir or internalDir are
                                         missing ('false' by default) (default:
                                         false)
-headless                             : Run agent in headless mode, without
                                         GUI (default: false)
-help                                 : Show this help message (default: false)
-instanceIdentity VAL                 : The base64 encoded InstanceIdentity
                                         byte array of the Jenkins controller.
                                         When this is set, the agent skips
                                         connecting to an HTTP(S) port for
                                         connection info.
-internalDir VAL                      : Specifies a name of the internal files
                                         within a working directory ('remoting'
                                         by default) (default: remoting)
-jar-cache DIR                        : Cache directory that stores jar files
                                         sent from the controller
-loggingConfig FILE                   : Path to the property file with
                                         java.util.logging settings
-noKeepAlive                          : Disable TCP socket keep alive on
                                         connection to the controller.
                                         (default: false)
-noreconnect                          : If the connection ends, don't retry
                                         and just exit. (default: false)
-protocols VAL                        : Specify the remoting protocols to
                                         attempt when instanceIdentity is
                                         provided.
-proxyCredentials USER:PASSWORD       : HTTP BASIC AUTH header to pass in for
                                         making HTTP authenticated proxy
                                         requests.
-tunnel HOST:PORT                     : Connect to the specified host and
                                         port, instead of connecting directly
                                         to Jenkins. Useful when connection to
                                         Jenkins needs to be tunneled. Can be
                                         also HOST: or :PORT, in which case the
                                         missing portion will be auto-configured
                                         like the default behavior
-url URL                              : Specify the Jenkins root URLs to
                                         connect to.
-version                              : Shows the version of the remoting jar
                                         and then exits (default: false)
-webSocket                            : Make a WebSocket connection to Jenkins
                                         rather than using the TCP port.
                                         (default: false)
-webSocketHeader NAME=VALUE           : Additional WebSocket header to set, eg
Previous Topic:can't build an avr project
Next Topic:C/C++ Console not display results
Current Time: Mon Aug 04 16:43:27 EDT 2025
Powered by FUDForum. Page generated in 0.04148 seconds
