Home » Modeling » QVT-OML » Remove object in place transformation
Remove object in place transformation [message #1861672] Thu, 26 October 2023 10:20 Go to next message
I have been trying to remove and object in an in place transformation in. QVTo but apparently there is not an expression that can directly do that. Any workarounds? thanks!
Re: Remove object in place transformation [message #1861679 is a reply to message #1861672] Fri, 27 October 2023 03:32 Go to previous messageGo to next message
I addressed this be using the excluding() operation and returning the new set of elements excluding the one I wanted to remove. Not sure if it is the best way, but it seems to work :)
Re: Remove object in place transformation [message #1861798 is a reply to message #1861679] Sat, 04 November 2023 05:43 Go to previous messageGo to next message
In truly declaration transformations there is no delete; just a deliberate failure to create/copy.
I tend to think of QVTo as semi-declarative. In this case the don't create/copy approach is applicable and so excluding from a copy is a sensible approach.
Re: Remove object in place transformation [message #1862122 is a reply to message #1861672] Tue, 14 November 2023 03:38 Go to previous message
Klarise Hund wrote on Thu, 26 October 2023 10:20
There is a removeElement(...) operation that you can invoke on the respective Model to remove a given Element from it. It should do what you want.
Kind regards
Christopher
Previous Topic:Create QVTo project programmatically
Next Topic:Propagate warning information to ExecutionDiagnostic
Current Time: Tue Sep 23 05:27:40 EDT 2025
Powered by FUDForum. Page generated in 0.03618 seconds
