HTTP ERROR 500 org.apache.jasper.JasperException: PWC6349: Cannot find a java compiler for compilati [message #1861447] |
Thu, 12 October 2023 15:41  |
I don't use the help system much, but I did today and got the error below when it launched
I'm not sure what changed.
My default JVM is Java 8 but I have eclipse configured to run with Java 20.
I can't find any settings to define which JVM the help system uses.
Any suggestions?
David
HTTP ERROR 500 org.apache.jasper.JasperException: PWC6349: Cannot find a java compiler for compilation. If running with JDK 5 or before, Ant or JDT compiler can be used, if the corresponding jars and bridge classes (org.apache.jasper.compiler.AntJavaCompiler or org.apache.jasper.compiler.JDTJavaCompiler) are included
URI: /help/index.jsp
STATUS: 500
MESSAGE: org.apache.jasper.JasperException: PWC6349: Cannot find a java compiler for compilation. If running with JDK 5 or before, Ant or JDT compiler can be used, if the corresponding jars and bridge classes (org.apache.jasper.compiler.AntJavaCompiler or org.apache.jasper.compiler.JDTJavaCompiler) are included
SERVLET: org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet-630f116b
CAUSED BY: org.apache.jasper.JasperException: PWC6349: Cannot find a java compiler for compilation. If running with JDK 5 or before, Ant or JDT compiler can be used, if the corresponding jars and bridge classes (org.apache.jasper.compiler.AntJavaCompiler or org.apache.jasper.compiler.JDTJavaCompiler) are included
Caused by:
at org.apache.jasper.compiler.DefaultErrorHandler.jspError(DefaultErrorHandler.java:92)
at org.apache.jasper.compiler.ErrorDispatcher.dispatch(ErrorDispatcher.java:378)
at org.apache.jasper.compiler.ErrorDispatcher.jspError(ErrorDispatcher.java:119)
at org.apache.jasper.compiler.Compiler.initJavaCompiler(Compiler.java:783)
at org.apache.jasper.compiler.Compiler.<init>(Compiler.java:140)
at org.apache.jasper.JspCompilationContext.createCompiler(JspCompilationContext.java:288)
at org.apache.jasper.JspCompilationContext.compile(JspCompilationContext.java:624)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:375)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:473)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:377)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:584)
at org.eclipse.equinox.jsp.jasper.JspServlet.service(JspServlet.java:164)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.HttpServiceRuntimeImpl$LegacyServlet.service(HttpServiceRuntimeImpl.java:1457)
at org.eclipse.equinox.http.servlet.internal.registration.EndpointRegistration.service(EndpointRegistration.java:159)
at org.eclipse.equinox.http.servlet.internal.servlet.ResponseStateHandler.processRequest(ResponseStateHandler.java:67)
at org.eclipse.equinox.http.servlet.internal.context.DispatchTargets.doDispatch(DispatchTargets.java:118)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.dispatch(ProxyServlet.java:147)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.preprocess(ProxyServlet.java:115)
at org.eclipse.equinox.http.servlet.internal.servlet.ProxyServlet.service(ProxyServlet.java:104)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:308)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:764)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:529)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
at java.base/java.lang.Thread.run(Thread.java:1623)
FUDForum. Page generated in 0.03467 seconds
