| plugin dependency issues in eclipse 2023-06 [message #1860256] |
Tue, 25 July 2023 06:56  |
Upgraded software which is built on Eclipse APIs EMF and GMF using eclipse 2023-06
I am getting following plug-in dependency issue. Attached complete log file
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.emf.parsley; bundle-version="1.14.0.v20221201-1038"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.runtime; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.emf.parsley.runtime; bundle-version="1.14.0.v20221201-1038"
No resolution report for the bundle. Bundle was not resolved because of a uses constraint violation.
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.emf.parsley.dsl because it is exposed to package 'com.google.common.util.concurrent.internal' from resources com.google.guava and com.google.guava.failureaccess via two dependency chains.
Chain 1:
require: (osgi.wiring.bundle=org.eclipse.xtext)
provide: osgi.wiring.bundle: org.eclipse.xtext
com.google.guava
Chain 2:
require: (osgi.wiring.bundle=org.eclipse.emf.parsley)
provide: osgi.wiring.bundle; bundle-version:Version="1.14.0.v20221201-1038"; osgi.wiring.bundle="org.eclipse.emf.parsley"; singleton:="true"
com.google.guava
import: (&(osgi.wiring.package=com.google.common.util.concurrent.internal)(&(version>=1.0.0)(!(version>=2.0.0))))
export: osgi.wiring.package: com.google.common.util.concurrent.internal
at org.eclipse.osgi.container.Module.start(Module.java:463)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1852)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1845)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1786)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1750)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1672)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
!ENTRY org.eclipse.emf.parsley.dsl.additional.builder 4 0 2023-07-25 16:14:19.612
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.parsley.dsl.additional.builder
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.dsl
-> Bundle-SymbolicName: org.eclipse.emf.parsley.dsl; bundle-version="1.14.0.v20221201-1038"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe2.launch; resolution:="optional"
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.emf.parsley.dsl.additional.builder because it is exposed to package 'com.google.common.util.concurrent.internal' from resources com.google.guava and com.google.guava.failureaccess via two dependency chains.
Chain 1:
require: (osgi.wiring.bundle=org.eclipse.xtend.lib)
provide: osgi.wiring.bundle: org.eclipse.xtend.lib
com.google.guava
Chain 2:
require: (osgi.wiring.bundle=com.google.guava)
provide: osgi.wiring.bundle; bundle-version:Version="31.1.0.jre"; osgi.wiring.bundle="com.google.guava"
com.google.guava
!ENTRY org.eclipse.emf.parsley.dsl.ide 4 0 2023-07-25 16:14:19.647
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.parsley.dsl.ide
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.emf.parsley.dsl.ide because it is exposed to package 'com.google.common.util.concurrent.internal' from resources com.google.guava and com.google.guava.failureaccess via two dependency chains.
Chain 1:
require: (osgi.wiring.bundle=org.eclipse.emf.parsley.dsl)
provide: osgi.wiring.bundle: org.eclipse.emf.parsley.dsl
com.google.guava
Chain 2:
provide: osgi.wiring.bundle; bundle-version:Version="1.14.0.v20221201-1038"; osgi.wiring.bundle="org.eclipse.emf.parsley.dsl"; singleton:="true"
com.google.guava
!ENTRY org.eclipse.emf.parsley.dsl.ui 4 0 2023-07-25 16:14:19.734
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.parsley.dsl.ui
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.dsl.additional.builder
-> Bundle-SymbolicName: org.eclipse.emf.parsley.dsl.additional.builder; bundle-version="1.14.0.v20221201-1038"; singleton:="true"
No resolution report for the bundle. Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.dsl.ide
-> Bundle-SymbolicName: org.eclipse.emf.parsley.dsl.ide; bundle-version="1.14.0.v20221201-1038"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.views
-> Bundle-SymbolicName: org.eclipse.emf.parsley.views; bundle-version="1.14.0.v20221201-1038"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.views.common; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.emf.parsley.views.common; bundle-version="1.14.0.v20221201-1038"
No resolution report for the bundle. Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley; visibility:="reexport"
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.dsl; visibility:="reexport"
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.wizards
-> Bundle-SymbolicName: org.eclipse.emf.parsley.wizards; bundle-version="1.14.0.v20221201-1038"; singleton:="true"
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.emf.parsley.dsl.ui because it is exposed to package 'com.google.common.util.concurrent.internal' from resources com.google.guava and com.google.guava.failureaccess via two dependency chains.
Chain 1:
com.google.guava
Chain 2:
com.google.guava
!ENTRY org.eclipse.emf.parsley.editors 4 0 2023-07-25 16:14:19.753
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.parsley.editors
Unresolved requirement: Require-Bundle: org.eclipse.emf.parsley.editors.common; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.emf.parsley.editors.common; bundle-version="1.14.0.v20221201-1038"; singleton:="true"
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.emf.parsley.editors because it is exposed to package 'com.google.common.base' from resources com.google.guava and com.google.guava via two dependency chains.
Chain 1:
com.google.guava
Chain 2:
com.google.inject
import: (&(osgi.wiring.package=com.google.common.collect)(&(version>=30.1.0)(!(version>=31.0.0))))
export: osgi.wiring.package: com.google.common.collect; uses:=com.google.common.base
export: osgi.wiring.package=com.google.common.base
com.google.guava
!ENTRY org.eclipse.emf.parsley.views 4 0 2023-07-25 16:14:19.802
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.parsley.views
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.emf.parsley.views because it is exposed to package 'com.google.common.base' from resources com.google.guava and com.google.guava via two dependency chains.
Chain 1:
com.google.guava
Chain 2:
com.google.inject
com.google.guava
!ENTRY org.eclipse.emf.parsley.wizards 4 0 2023-07-25 16:14:19.835
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.emf.parsley.wizards
org.apache.felix.resolver.reason.ReasonException: Uses constraint violation. Unable to resolve resource org.eclipse.emf.parsley.wizards because it is exposed to package 'com.google.common.base' from resources com.google.guava and com.google.guava via two dependency chains.
Chain 1:
com.google.guava
Chain 2:
com.google.inject
com.google.guava
!ENTRY org.eclipse.gmf.ecore.editor 4 0 2023-07-25 16:14:20.564
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.gmf.ecore.editor
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.ui.printing.render
-> Bundle-SymbolicName: org.eclipse.gmf.runtime.diagram.ui.printing.render; bundle-version="1.9.0.202305230839"
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.draw2d.ui.render.awt; bundle-version="
Unresolved requirement: Require-Bundle: org.apache.batik.bridge; bundle-version="1.16.0"
Unresolved requirement: Require-Bundle: org.apache.batik.transcoder; bundle-version="1.16.0"; visibility:="reexport"
-> Bundle-SymbolicName: org.apache.batik.transcoder; bundle-version="1.16.0.v20221027-0840"
Unresolved requirement: Import-Package: org.apache.batik.bridge; version="
Unresolved requirement: Import-Package: org.apache.batik.dom.svg; version="
Unresolved requirement: Import-Package: org.apache.batik.parser; version="
No resolution report for the bundle. Unresolved requirement: Import-Package: org.apache.batik.dom.svg12; version="
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.ui.render
-> Bundle-SymbolicName: org.eclipse.gmf.runtime.diagram.ui.render; bundle-version="1.8.0.202305230839"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.ui.printing.render; bundle-version="
Unresolved requirement: Require-Bundle: org.apache.batik.bridge; bundle-version="[1.6.0,1.7.0)"
!ENTRY org.eclipse.gmf.tooling.simplemap.diagram 4 0 2023-07-25 16:14:20.595
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.gmf.tooling.simplemap.diagram
Unresolved requirement: Require-Bundle: org.eclipse.gmf.tooling.simplemap.diagram; bundle-version="0.1.0"
-> Bundle-SymbolicName: org.eclipse.gmf.tooling.simplemap.diagram; bundle-version="1.0.0.201409171321"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.ui.printing.render; bundle-version="1.8.0"
No resolution report for the bundle. Unresolved requirement: Import-Package: org.apache.batik.dom.svg12; version="[1.16.0,2.0.0)"
-> Export-Package: org.apache.batik.dom.svg12; bundle-symbolic-name="org.apache.batik.dom.svg"; bundle-version="1.16.0.v20221027-0840"; version="1.16.0"
Unresolved requirement: Import-Package: org.apache.batik.parser; version="[1.16.0,2.0.0)"
-> Export-Package: org.apache.batik.parser; bundle-symbolic-name="org.apache.batik.parser"; bundle-version="1.16.0.v20221027-0840"; version="1.16.0"; uses:="org.apache.batik.ext.awt.geom,org.apache.batik.i18n,org.apache.batik.util.io,org.w3c.dom"
Unresolved requirement: Require-Bundle: org.apache.batik.anim; bundle-version="1.16.0"
-> Bundle-SymbolicName: org.apache.batik.anim; bundle-version="1.16.0.v20221027-0840"
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.ui.render; bundle-version="1.7.1"
org.eclipse.gmf.runtime.diagram.ui.render [832]
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.draw2d.ui.render.awt; bundle-version="[1.2.0,2.0.0)"
-> Bundle-SymbolicName: org.eclipse.gmf.runtime.draw2d.ui.render.awt; bundle-version="1.11.0.202305230839"; singleton:="true"
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.draw2d.ui.render.awt; bundle-version="1.10.0"
!ENTRY org.eclipse.jface 2 0 2023-07-25 16:15:05.571
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2023-07-25 16:15:05.571
!MESSAGE A conflict occurred for CTRL+SHIFT+T:
Binding(CTRL+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.jdt.ui.navigate.open.type,Open Type,
Open a type in a Java editor,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
WorkbenchHandlerServiceHandler("org.eclipse.jdt.ui.navigate.open.type"),
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.lsp4e.symbolinworkspace,Go to Symbol in Workspace,
Category(org.eclipse.lsp4e.category,Language Servers,null,true),
WorkbenchHandlerServiceHandler("org.eclipse.lsp4e.symbolinworkspace"),
,,true),null),
!ENTRY org.eclipse.egit.ui 2 0 2023-07-25 16:16:22.573
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'Z:\'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
Attachment: .log
(Size: 94.50KB, Downloaded 105 times)
FUDForum. Page generated in 0.07586 seconds
