Home » Eclipse Projects » Mosquitto » SSL/TLS or Username and Password Authentication
SSL/TLS or Username and Password Authentication [message #1859702] Thu, 22 June 2023 17:20 Go to next message
I have some devices that needs to authenticate with a certificate but does not have a username or password.
Then I have devices that needs to authenticate with a Username and Password but does not have a certificate.
I'm not sure what is the correction configuration to achieve this.
This is my current configuration:
password_file PathToPasswordFile
cafile PathToCAFile
certfile PathToCertFile
keyfile PathToKeyFile
require_certificate false
use_identity_as_username false
Re: SSL/TLS or Username and Password Authentication [message #1859747 is a reply to message #1859702] Sat, 24 June 2023 12:03 Go to previous message
It seems like the Mosquitto broker does not allow this:
https://github.com/eclipse/mosquitto/issues/1839#issuecomment-707656348
So the next best option will be to run two listeners on the same broker. Each listener having its own authentication configuration. I still need to verify that my message handler can subscribe to messages published from both types of devices. But I guess this should work since it is on the same broker.
Here is my working configuration:
# SSL/TLS with certificate authentication
listener port
use_identity_as_username true
require_certificate true
cafile pathtocafile
certfile pathtocertfile
keyfile pathtokeyfile
# Username and Password authentication
listener port
per_listener_settings true
password_file pathtopasswordfile
[Updated on: Sat, 24 June 2023 12:03] by Moderator
Previous Topic:QOS 0 question
Next Topic:no stable connection with client
Current Time: Wed Nov 05 19:01:25 EST 2025
Powered by FUDForum. Page generated in 0.02513 seconds
